Question about Viking Designer DDRB364SS Stainless Steel Refrigerator
I have a viking DDRB36RSS all refrigerator. there is ice built up on the back wall and the door will not seal. i replaced the door seal but it still will not seal and there seems to be no air moving inside.
  • 4 more comments
  • damonhollis1 Nov 11, 2010
    the door hinge isnt corroded away but it is rusted. i oiled it and it seems to work fine but what does that have to do with the ice on the back wall. i also noticed that the long cyclinder shaped fan isnt working thats above the small radiator on the back wall thats also iced up. is there any checks i need to be doing?
  • damonhollis1 Nov 18, 2010
    need additional help diagnosing my viking refrigerator.
  • damonhollis1 Nov 19, 2010
    i know nothing about refrigerators. where would i find these item you are talking about to check. if you have any diagrams please email them to damonhollis1@yahoo.com.
  • damonhollis1 Nov 22, 2010
    first, this is not a freezer. its a viking all refrigerator. no freezing takes place in this unit. i have a viking all freezer thats right next to the frig but they are both seperate units. if pics will make this easier please leave an email address so that i may send you pics of the unit and the problem. because your reply about closing the door as tight as possibe does not tell me much on how to fix the problem. i dont know if there is a fan that creates vacuum when the door closes but my freezer seems to work that way and my frig use to. so any help with a viking all refrig would be really helpful. thanx in advance. my email address is nextlevelcycles@yahoo.com
  • damonhollis1 Dec 02, 2010
    Maybe this will help, I missed a number in the model number, it a Viking DDRB364RSS. There is no thermostat attached to the coil, however there looks like a sensor attached to the cover that covers the coil. Would that be the thermostat? This is an all refrigerator. There is no freezer within this unit. So the problem is that the refrigerator is building up ice on the coil, the tubular shaped fan above the coil isn't working, the thermostat looking device attached to the cover has no continuity and the door doesn't seal. Please remember this is a refrigerator only model with no freezer at all.
    That sensor I was telling you about has no continuity when cold but does when hot. Hope this helps.
  • 4,070 Answers
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Nov 22, 2010
  • 2,418 Answers
I just found your post. After 10 days I would hope you have fixed this. So heres what to do if you are still fighting your fridge. Get a large cooler, you will need some dry ice approx 2 -3 lbs. Remove all the food, even the ice (dump the ice). put the food in the bottom of the cooler, lay a good layer of news paper over it all and put the dry ice on top. Next, pull the plug and removed all the shelves from the freezer. Look closely at the rear wall and figure out which panel you need to remove and how it comes out. Most are held in with small screws. Get the panel out, you may scratch some paint or bend the panel but its ok. Once you are in to the coil, get a hair drier and run it on the coil to defrost the ice build up. Be sure you clear the drain area also (must drain or you will have same problem again) Due to the amount of frost you may make a mess in the floor under the fridge once the pan over fills. (Look out for that). Now once the coil is clear, look for any thing out of place, You may not know much about freezers, but look for wires that are loose (not hooked up), look for a (klixon) this is a switch that clips on to the tubing at the top of the coil if it is not still clipped to the coil try and re-clip it on to the line. If the klixon is loose that is the problem and the fridge is fixed. If you do not find any thing wrong, or do not see any thing that is ok. Clearing the coil and drain may fix the problem. Put it all back together. But leave out the food for now, will last for days in the cooler. Put a plastic cup w/ water in the middle of the shelves. Plug it back up and see how well it works. Should freeze the water in 4 - 6 hours. If you have a temp gage or Plup thermometer. Put it on the shelf close to the cup. You freezer should get to around -5 and no frost build up. Run it for 1-2 days. If all is well you fixed it. Put it all back together.
Posted on Nov 21, 2010
  • John Fourteen Six Nov 22, 2010
    I see a your comment dated 10 days ago about the door, {the door hinge isnt corroded away but it is rusted. i oiled it and it seems to work fine but what does that have to do with the ice on the back wall. i also noticed that the long cyclinder shaped fan isnt working thats above the small radiator on the back wall thats also iced up. is there any checks i need to be doing?} The freezer door being open just a crack, lets in outside air that can cause the frost you are having the problem with. Plus You mention a fan not turning. That also causes frost build up, due to no air moving over the coil. I was thinking that you may have had a defrost problem, get that door closed as tight as it can no leaks.
You refrigerator is not defrosting. Check the defrost timer/control board, defrost heater (in freezer)
and the thermo switch with a multimeter and check for continuity. Replace the part that is not receiving power. Unplug the machine and let the ice melt overnight with the door open. Check the fan and see if it's working to move the air, if not then replace the fan.
Posted on Nov 19, 2010
  • 22,413 Answers
Check the lower door hinge as they corrode away around the pivot point allowing the door to stay open ,if it is then take it off and to a workshop and get then to braze a piece of metal into the lower door hinge so its then secure .this is better than buying a new fridge just for this weak point
Posted on Nov 11, 2010
Samsung refrigerator is freezing up on back panel of refrigerator . Will defrosting the whole unit do any good? The unit is 2 years old
well yes and no , defrosting it will temporally make it work , but main problem is there isn't proper air flow over evaporator coils id clean them with soap and water while defrosting out unit , if low airflow is allowed to continue then refrigerant gas will build to high press and escape and render unit a total replacement
Sep 29, 2016 | Samsung RB215ACBP 20.0 cu. ft. Bottom...
LEC L6046W FRIDGE - ICE/FROST INSIDE THE BACK WALL. MOTOR IS RUNNING CONSTANTLY.CLEANED ALL THE ICE OFF BUT WHEN SWITCHING BACK ON, WITHIN 10MINS THE ICE,FROST IS BACK?
1.I think you might have a thermostat problem it is over cooling the system and doesn't shut off when it is suppose to. Replace the thermostat
2.If the door seal is broken or the door is not closed shut with the seal magnet nice and tight against the fridge it will form ice inside the fridge as well. Replace the door seal. (this is very common with old fridges)
Sep 06, 2009 | Refrigerators
I have ice forming on back wall above top drawer in refrigerator. Belive seal may need to be replaced. Any other suggestions?
The gasket would be the last thing I would suspect. Is the ice a ball to the left side or is it all the way across? Could be a sealed system issue or a bad thermistor. I would recomend calling a factory authorized servicer for proper diagnosis before putting the money into a gasket. Besides look at the gasket all the wat around for any damage and make sure the door is closeing properly. Isee units with torn gaskets all the time and it doesn't cause ice build up in th refrigerator side.
Jul 02, 2009 | Sub-Zero 642
Ice built up in the freezer compartment
We have a possible defrost problem or the seal around your doors are pulling moist air air inside. I believe now would be a good time to unplug the refrigerator and check the coils and defrost system. Inside the fresh food compartment you have a defrost timer that I want you to turn clockwise slowly until the compressor stops. Leave it there for about 25 minutes until refrigerator either restarts or don't if it does not then turn it a little more until it starts. The part number for the timer is 482493 Also below is a picture and #6 is the defrost timer. It should be reachable through a small hole in the bottom of the control panel. If everythig is well there we will check the defrost heater and defrost thermostat. After you check these things let me know the results. Sea Breeze
http://servicepartstec.blogspot.com/
Jun 21, 2009 | Whirlpool Refrigerators
Our freezer is not cold, food is defrosting, ice is melting. Refrigerator is working, freezer is not. We hear compressor running continuously. This is a side by side Amana model with water & ice maker...
Look at the back of the freezer wall from inside the freezer. Is there frost on it? If there is, you need to replace one of the components of the defrost system. If there is no frost then you need to have a repair made to the sealed system, it is either out of gas or the compressor is running inefficiently
Jun 20, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Viking freezer leaking
you have a clogged drain, it is either clogged with ice or some kind of debris, thaw the freezer out and push a length of weed trimmer line down the drain. The drain is accessible by removing the back wall of the inside of the freezer. If there is no clog then the drain may be freezing up, if that is the case, take a piece of 14 gauge romex wire and loop it several times around the heating element at the bottom of the evaporator and push a few inches of it into the drain, this will get hot and transfer heat when it goes into a defrost cycle which is where the water is coming from in the first place
Jan 01, 2009 | Viking 42 in Built In Professional...
Ice is building up on the back wall of fridge
Option 1 defrost fridge manually by switching off power for 24 hours, allowing built up ice & frost to melt.
Option 2 Switch off mains power and using a hair drier blow hot air into the freezer supply vents. This shuold shift the ice in a couple of hours
Nov 12, 2008 | Candy CPCA240FFK Bottom Freezer...
VIKING FREEZER FROST BUILD UP
DEPENDING HOW OLD THE UNIT IS YOU MIGHT HAVE A BREAK DOWN IN THE INSALLATION ON THE SIDE WALLS OF THE APPLIANCE.ALSO CHECK THAT THE DOOR SEALS ARE SEALING OK IF ITS A BREAKDOWN WITH THE INSALLATION THAT MIGHT BE A COSTLY REPAIR BUT GET A TECH TO GIVE ADVISE.GOODLUCK.MOHAMED
Sep 15, 2008 | Refrigerators
Viking Designer DDRB364SS Stainless Steel Refrigerator Logo
407 people viewed this question
Top Viking Refrigerators Experts
Jay Finke
Jay Finke
Jose Pino
Colin Stickland
Colin Stickland
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
