Question about D-Link AirPlus DI-524 Wireless Router
I had plugged the 110 - 120 V 0.5 A - 50 - 60 Hz power chord in to a 220 - 230 V power socket. The router worked for some time later went off. There is a leak in the power adopter. Is there a way I can replace the adopter ? Is there a solution for 110 V to 220 V conversion.
  • D-Link Master
  • 4,338 Answers
Power adapter replacement:
http://www.google.com/#q=D-Link++DI-624+power+adapter&hl=en&prmd=ivs&source=univ&tbs=shop:1&tbo=u&ei=_VvbTPuHDsSblgegquyuCQ&sa=X&oi=product_result_group&ct=title&resnum=3&ved=0CEIQrQQwAg&fp=68bffe149d85ccd7
Converters:
http://www.dvdoverseas.com/voltage_converters.htm
Good luck.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Nov 11, 2010
Reset a Honeywell HZ-709 portable electric oil room heater?
I'm going to ask the first "obvious" question: are you sure the socket you're plugging into is delivering power? (Sorry to ask but it's an Occam's Razor kind of situation) Have you tried a different socket in the same room? Next, does the main power switch for the heater have different settings i.e. high, medium, low, high-high, high-low, low-low and have you tried those combinations? Next, pick up the heater (if it won't hurt your back) and give it a robust shake. Try the power again. Any luck? Keep us posted.
Mar 06, 2015 | Honeywell HZ-709 Oil Filled Radiator...
I have an epilator (Remington Model # EP-6025). I have been using it in US and now, I would like to use it in India. Can I just use an adoptor for the chord and use this epilator
Yes, India uses 230 Volts at 50 Hz alternating current as the power source. Plugs and sockets have either grounded earthed 3 Pin connections (Type D) or ungrounded 2 pin connections (Type C).
All you need is an adaptor like the one in the picture.
Dec 27, 2014 | Remington Ep6025 Epilator
Hz-789
If the sockets are hot (electrically, plug in something to confirm that sockets operation) and you are pushing the right button on the heater, then the unit is defective. There is no type of resettable sensor to my knowledge (not consumer accessible).
Nov 28, 2013 | Honeywell HZ-709 Oil Filled Radiator...
We lost power for a few hours .The cable company ( charter ) had to reboot the modem to reestablish the internet connection. Since then I cannot get the Cisco router to work.. I've done all the plug,...
1. if the power went out and then back on it is possibly due to a "power surge" and it possibly damaged the power supply to the Cisco router and or to the router itself.
2. check the routers power supply and replacement is needed if the router was not plugged into a surge protected socket.
Jul 15, 2011 | Computers & Internet
Power cord has to be held inat an angle to run and
I would suggest it`s a bad solder connection to the board on your laptop or a small break inside the power chord wire right at the neck of the wire plug.If you can find an identical notebook to try the plug in...that may narrow your problem as to the power chord or the notebook plug,good luck:)
Apr 11, 2010 | Compaq Presario R3000 Notebook
Wired, router, modem and internet light comes on but i am not allowed to browse...why is that? if i connect the modem directly to the pc then i can browse just fine...
Well , the problem is with the router , we can powercycle the complete network and if that does'nt work then router's setting's has to be re-configured.
Steps to powercycle the network:-
1)Turn off or shut down the computer.
2)Take the power chord out from the router.
3)Take the power chord out from the modem and the wait for 60 to 90s.
4)Plug the power back to the modem first and wait until all the lights gets stabilized on it.
5)Once the lights get stabilized then Plug the power back to the router and wait for the lights to get stabilized.
6)Turn on the computer and it might work else re-configure the setting's of the router.
Nov 23, 2009 | Computers & Internet
No power. T light does not illuminate.he monitor is plugged in 110 volt as usual. Now when I press the power button nothing happens. power on
1. Check whether power is there
2. Check the power sockets receives the power supply
3. Check the Female socket on power chord is fix with male socket on monitor
4. Check the power chord is leak free.
Nov 17, 2009 | LG L1932TQ LCD Monitor
Will not power on
Simply try another power chord, if you are sure the chord is not faulty, try to plug in the monitor to another wall socket. If the monitor is not working on any wall socket, call customer service of the manufacturer and get it repaired
Aug 26, 2009 | Computers & Internet
2 wire Router is not working
I had a similar problem when the power went out and the router got hooped, the solution was to UNPLUG the power CONVERTER from the wall and wait ten minutes before plugging it in again.
Dec 09, 2008 | 2wire (1000-400108-001) Router
Power
hi,
try this
> connect the power chord directly to the wall socket.
> check with different wall sockets.
> unplug and plug in back the power chord. make sure that it is securely plugged in.
> check whether there is a light on the box which comes between the printer and the wall socket.
> if there is light and you hav the problem u need to service the unit else power chord may be the problem.
thanks and regards
agnel
Feb 23, 2008 | HP OfficeJet 7410 All-In-One InkJet...
D-Link AirPlus DI-524 Wireless Router Logo
96 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
