DM removal
You will need to remove the entire chassis block as outlined in the manual. DM stands for digital board. It will be listed in the manual as PWB DM its sandwhiched in between other boards inside the chassis . Which is actually a metal box that will need to be disassembled then each board removed to get the DM . The DM is usually the bottom board. I dont have access to the WD65833 sertvice manual, but I am famillar with it. The DLPs are all simallar the entire Chassis block needs to be removed. Hope this helps if you need more info, let me know.
