Question about Ovens
I have just moved and the wall oven is an Atlas Astoria. I need a manual to operate it as so far getting it to cook has been hit and miss.
  • judith kenna Oct 17, 2011
    hi there i have exactly the same problem just moved house and cant get the oven to work properly did you ever get a manual ive looked all over the net
  • 1314 Answers
SOURCE: door won't open after self cleaning.
it is locked the leaver has become detached from the door latch and even though the leaver moves the lock part doesn't have you tried it lately push in on the door and try to move the leaver if that doesn't work get a wire coat hanger make a Small hook and from the left hand side see if you can snag the hook and pull it over ive done that before theopen end of the hook should point up start just abve the door gasket about halfway over well i cant reamber which way the latch moves but im sure you can figure it out push slighty in on the door after you hook the latch but try to open it fist some have asensor that wont let the oven door open till its cool enough to be safe let me know
Posted on Dec 31, 2007
SOURCE: dacor cps130 wall oven f1 error
According to the manual, this is an element relay circuit failure. Call the tech.
Posted on Jun 15, 2008
barkencoa
  • 3463 Answers
SOURCE: I saw sparks? or small flame on back wall behind fan inside oven
It sounds likely that the fan motor is faulty,more so if the oven is heating to some extent.
You should be able to see or hear if the fan is working or not
Hope this helps with your prob.
Posted on Nov 26, 2009
SOURCE: my oven takes ages to cook things am i missing
We had this problem; Your thermostat is probably broken. To test this theory, buy an oven thermometer and test how accurate the oven is. My bet is you will find this to be off. Fix it now, otherwise, it might lead to other issues.
Posted on Mar 31, 2010
SOURCE: Simpson Evolution 904 wall oven cooks very unevenly
I agree, the heating is very uneven in our oven, however, when I calibrated the temperature with a thermocouple, I discovered that the temperature gauge was 25C too hot! That is, if I set the oven temperature gauge to 155C, it was actually 180C inside the oven! Taking this in to account, it is now much easier to cook things without them burning.
Posted on Dec 27, 2010
I have a Smeg Wall Oven Model No SA710X-5. When I turn the cooking selection switch to the desired cooking setting the green light comes on. But when I turn the thermostat switch to the desired temperature...
It sounds like the element is missing one side of the 240v power. One side may always be hot while other side is controlled. A qualified repairman can Start at the element and work backwards. Trace wiring back looking for burned wire, bad connections and connectors, all the way back to thermostat. Check thermostat for continuity (with power off), replace thermostat if necessary.
Oct 29, 2013 | Smeg Ovens
Smeg electric oven timer controls
first is unplug the the oven from the wall outlet, to hard reset the setting. wait for almost 20 minutes then plug it again.
please tell me if there is still problem after this, melnavz
Apr 10, 2008 | Smeg SE280X Stainless Steel Electric...
Nov 26, 2009 | Gaggenau EB 270/271 Electric Single Oven
Door locked after shutting down cleaning cycle earlier than
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
May 17, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Cook timer keeps chiming
it starts chiming every min AFTER the timer counts down the allotted time?? thats normal operation its remonding you that the timer has completed cookin and to remove food from oven.. it will continue cooking with residual heat if not removed
Nov 25, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Wiring diagram
This model of cook top needs the 4 wire install because it has both 220v and 110v circuits. The forth wire is a neutral that operates the 110v circuit. You can move the ground of the 3 wire outlet to neutral, but ONLY! if the ground wire is insulated. What this will do is give you both your 220v and 110v circuits. The problem with that is your cook top will not be grounded. The best solution is to locate a neutral wire and tap into it, this will give you your 4 wire circuit. Your missing a neutral in a 3 wire outlet.
More Asst.
eboukater@gmail.com
Sep 24, 2008 | Jenn-Air JJW8530C Expressions Collection...
Programming Belling xou181ss oven
Try Googling (belling)(xou181ss)(manual) without parens.
May 01, 2017 | Ovens
Dacor cps130 wall oven f1 error
Dec 04, 2007 | Ovens
Diplomat Oven ADP3650 Instructions
User manuals are hard to find.
The problem I had was setting the clock on a single Diplomat oven, with no clock button. Here's my solution :
DIPLOMAT OVEN OPERATING INSTRUCTIONS
The Diplomat single oven is controlled by two knobs and a set of buttons along the middle of the control panel.
The left knob sets the temperature of the oven, while the right knob selects the function to be performed, e.g. fan oven, grill, etc.
The buttons along the middle set the cooker clock, the start and end times of cooking, and the “+” and “-“ buttons will increase or decrease the time shown on the cooker’s clock.
PLEASE NOTE THAT THE OVEN WILL NOT OPERATE UNTIL THE CLOCK IS SET.
If there is any interruption to the power supply (including manually switching off at the main switch) the oven will not operate until the clock is reset.
Here’s how to set the clock:
First press simultaneously the first two buttons to the left of the control panel. They are marked as a Bell symbol (Alarm) , and a steaming Cooking Pot (Start of Cooking Time). Then immediately press the plus “+” or minus “-“ buttons to increase or decrease the time displayed. When the desired time has been reached, leave it for a few seconds, and it will remain set at this time. Any further changes to the displayed time will require this procedure to be repeated.
Hope this helps!
Oct 10, 2007 | Ovens
Ovens Logo
46 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
