Question about HP OfficeJet 6210 All-In-One InkJet Printer
How do I clear the spool? - HP OfficeJet 6210 All-In-One InkJet Printer
  • 1,218 Answers
There are several ways to resolve printer spooler error, probably because there are many variations of this error. The error caused by faulty software can be resolved by deleting all the information found in the directory. Thereafter, navigate to the Control Panel, click on Administrative Tools and then services icon. Find the service labeled Print Spooler, highlight it and restart the process. If that doesn't work, the program might be corrupted. Click on start, then Run. Search for the document labeled services.msc, and this will trigger the opening of another window. On this window, scroll down and click "Print Spooler". Check its setting and turn on automatic mode. Click Okay, and restart the machine. If you're lucky, this might be all you have to do. Still doesn't work? Navigate to the Add/Remove Programs screen of the Control Panel. Find the all the software responsible for making the printer run including the drivers, and uninstall them. Be sure to be thorough about it, or the problem may not be solved. Download the latest copy of your printer's software from the manufacturer and reinstall it.
Posted on Nov 11, 2010
How do I clear a document stuck in the print que?
If you are on a network and the printer is shared by others, you are only allowed to clear documents you have spooled to the printer. If someone else has a file jammed in the queue, then they (or an administrator) must remove it.
Aug 03, 2014 | HP Deskjet D4260 InkJet Printer
Tip
How to clear printer not spooling error on windows xp system.
this error comes in many terms on the monitor screen as such
" printer spooling error"
" printer not spooling"
" printer spooling service"
if any of such message shows up on your monitor on windows xp operating system.
to make spooling work its necessary to make it work
this is the procedure .if you do this it will work properly. till it is not done it will just ignore printing
1)click the start in the left side of your computer screen
2)go to control panel
3)click performance and maintenance
4)click system
5)click data execution prevention
6)turn on DEP for essential windows program and services only.
7)click the spooling services a tick mark sign will appear beside that means it has enabled.
now your printer will work properly.
on Dec 02, 2009 | Office Equipment & Supplies
Juki sc320 material stuck
if your fabric is stuck the liklihood is that the spool underneath is jammed up with threads take out spool and clear threads replace spool, it should be ok then
Jan 05, 2013 | Juki Sewing Machines
Just bought a TE475. can't figure out how to replace the line compared to the traditional one-line configuration I am used to
Here is the info from the manual, the replacement line is put in near the center of the spool on the top of it, you simply feed it in. I have included a link to the manual so you can see the pictures. Look at page 10 for these instructions.
http://www.weedeater.com/ddoc/WEEO/WEEO2009_USen/WEEO2009_USen_TE475-952711797_545186833.pdf
LINE REPLACEMENT Pre--wound spools offer the most convenient method for replacing line and ensuring optimum performance. S Replacement spools are color--coded to ensure use of the correct spool with your unit. Be sure to use the same color spool as the existing spool. NOTE: Always clear dirt and debris from cutting head components when performing any type of maintenance. S Hold spool and unscrew cap by turning in the direction shown on top of the cap. S Remove line guide ring and spool. NOTE:When removing and/or installing spool, ensure dust cup remains installed over shaft. Use a pre--wound spool or refill spool with line. If using a pre--wound spool, remove tape strip from line and spool. REFILLING THE SPOOL WITH LINE WARNING: Use only 0.080" (2 mm) diameter round line. Other sizes and shapes of line will not advance properly and will result in improper cutting head function or can cause serious injury. Do not use other materials such as wire, string, rope, etc. Wire can break off during cutting and become a dangerous missile that can cause serious injury. 1. Cut a length of 25 feet of 0.080" (2 mm) diameter round WEED EATER brand line. Feed line in direction shown on spool. Spool 2. Insert one end of line into center cavity of empty spool. Ensure line will feed into spool in the direction shown on the spool (counterclockwise). 3. Continue feeding line into spool, leaving 4 -- 6 inches (10 -- 15 cm) unwound from center of spoo
Aug 25, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I don't know how to restring the weed eater
LINE REPLACEMENT Pre--wound spools offer the most convenient method for replacing line and ensuring optimum performance. S Replacement spools are color--coded to ensure use of the correct spool with your unit. Be sure to use the same color spool as the existing spool. NOTE: Always clear dirt and debris from cutting head components when performing any type of maintenance. S Hold spool and unscrew cap by turning in the direction shown on top of the cap. S Remove line guide ring and spool. NOTE:When removing and/or installing spool, ensure dust cup remains installed over shaft. Use a pre--wound spool or refill spool with line. If using a pre--wound spool, remove tape strip from line and spool. REFILLING THE SPOOL WITH LINE WARNING: Use only 0.080" (2 mm) diameter round line. Other sizes and shapes of line will not advance properly and will result in improper cutting head function or can cause serious injury. Do not use other materials such as wire, string, rope, etc. Wire can break off during cutting and become a dangerous missile that can cause serious injury. 1. Cut a length of 25 feet of 0.080" (2 mm) diameter round WEED EATER brand line. Feed line in direction shown on spool. Spool 2. Insert one end of line into center cavity of empty spool. Ensure line will feed into spool in the direction shown on the spool (counterclockwise). 3. Continue feeding line into spool, leaving 4 -- 6 inches (10 -- 15 cm) unwound from center of spool
Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
How do i rewind the spool on a Black & Decker 14" dual-string trimmer/edger. the manual isn't exactly clear
When you pull off the spool it will have arrows embedded,
on the spool to show you which direction to wind it.
good luck!
Jul 17, 2011 | Electrical Supplies
The string on my spool ran out.
• Turn off the trimmer and remove the battery
• Press the release tabs on the line spool cover and remove the cover by pulling it straight off. replacement spool is AF-100
• Lift the spool of nylon line out of the hub and clear any broken line and debris
• In case of jams and tangled line unwrap about one foot (30cm) of line to ensure that it is undamaged. If it is OK rewind it and insert the line end through the eyelet in the spool hub.
• Pull the line through the hole to maintain tension while placing the
spool down into the hub with the notched side exposed.
• Press the spool down GENTLY and rotate it until you feel it drop into place. (When in place, the spool will turn a few degrees left and right freely.)
• Snap the spool cover back on.
Jul 06, 2010 | Black & Decker String Trimmer Cordless 12"...
Will not reel the line back in. Line was twisted and there are some knots behind the spinner head and the spool. How do I remove the spinnerhead assembly to clear/clean this out?
there should be a knob on the front of the spool that unscrews to remove the spool. this is probably the drag adjustment too. hope this helps
Oct 05, 2009 | Sport & Outdoor - Others
How do I clear an incomplete print operation?
Try clearing your spooler queue:
Delete the spool printer files loadTOCNode(2, 'resolution'); In safe mode, delete the spool printer files. To do this, start Microsoft Windows Explorer, and then delete all the files in the following folder (where C: is the drive where Windows XP is installed):
  • C:\Windows\System32\Spool\Printers
Dec 08, 2008 | Lexmark Z600 InkJet Printer
Spool pin
Spool pin is usually on the top Right hand side of the machine. It is sometimes not clearly visible (it looks like a small metal rod protuding out, but not long enough to hold your thread). You will have to pull it up so that it extended and then you can use it.
Dec 27, 2007 | Brother LS-1217 Mechanical Sewing Machine
HP OfficeJet 6210 All-In-One InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
