Question about Acer AL1917W LCD Monitor
Monitor wont come on i only get a green-orange-off flash on the power button
  • 11,361 Answers
Unless the problem is inside the monitor, you should try it with another PC and check the video cable first to make sure it is not PC or cable problem. If it still does not work, then you will have to open it up and do the in-depth troubleshooting down to component level.
Please read below if you decide to DIY repair.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://en.wikipedia.org/wiki/Capacitor_plague
Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Nov 11, 2010
Monitor wont come on the power button light turns from green to orange and nothing on the screen
check your display card .. remove the memory ..clean the contacts and put it back.
Aug 30, 2014 | Compaq Computers & Internet
Monitor model 1702FP wont start. lights keep cycling
The flashing power and signal lights are caused by 4 bad capacitors on the main driver board. Here is a link to information showing where they are and how to replace them.
http://www.instructables.com/id/FREE-17%22-LCD-Monitor---How-to-do-it%3F/
Sep 23, 2012 | Dell 1702FP 17" 1280x1024 .264mm Midnight...
Monitor problem
The power light is flashing green can indicate start/restart of the power supply due to shorts circuits or failing power supply due to bad caps, look for bad caps with bulging top first, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you furhter.
Feb 20, 2010 | Acer 17" AL1706B LCD Monitor
Monitor will not stay on
Generally Monitors have a single light in fron pannel, with dual mode colors as Green and Orange.
Green: Everything is OK .
Orange: Everything is OK, except it is not getting
any signals from computer or other source.
Try with any other monitor with your CPU, it may happen that CPU actually not providing any signal to Monitor. Try checking the "NUM LOCK" button on and off, whether it makes the light on keyboard to flash on or off.
If NUM LOCK is woking OK, there is surely some problme with your monitor and you need to get is checked physically with an engineer.
Jan 21, 2010 | Westinghouse 22" Widescreen LCD Flat Panel...
Sir Help me with my Compaq monitor MV520 it won't turn the power led flashing orange to green continously
it could be th epower supply and it could be the monitor.
power ON button should not flash orange regardless what you do. it should stay green. then orange. not orange to green to orange.
try the monitor on another PC if you can fine one.
the other thing is are the 2 monitor similar (CRT to CRT and LCD to LCD), you can't mix the the two, they will work but need different video driver to function correctly.
Oct 20, 2008 | Compaq MV 540 15" CRT Monitor
Monitor wont turn on, just green flashing light.
double check that all yor connections are tight. Open your PC case (unplug it) and ensure that all your fans are clean. It appears that your problem is due to loose cable connections, but this may be a good time to do some computer spring cleaning.
Apr 29, 2008 | Acer AL1916B 19" LCD Monitor
Printer Problem
This was not the sollution for my pinter..
My Magneta is half full and my error led is also blinking 15 times
I found this service manual for the IP4200 but this methode also doen not solve my error led..
Is their someone who has the sollution for this strange error?
1) With the printer power turned off, while pressing
the Resume/Cancel button, press and hold the Power
button. (DO NOT release the buttons. The Power LED
lights in green to indicate that a function is
selectable.)
2) While holding the Power button, release the
resume/Cancel button. (DO NOT release the Power
button.)
3) While holding the Power button, press the
Resume/Cancel button 2 times, and then release both
the Power and Resume/Cancel buttons. (Each time the
Resume/Cancel button is pressed, the Alarm and
Power
LEDs light alternately, Alarm in orange and Power
in
green, starting with Alarm LED.)
4) When the Power LED lights in green, press the
Resume/Cancel button the specified number of
time(s)
setting) (THEN HIT THE POWER BUTTON >AFTER THIS< TO SET).
Time(s) LED indication Function Remarks
0 times Green (Power) Power off When the print head is
not installed, the carriage returns and locks in the
home position capped.
1 time Orange (Alarm) Service test print .
2 times Green (Power) EEPROM information print
3 times Orange (Alarm) EEPROM initialization
>>>>>>>>THIS ONE
4 times Green (Power) Waste ink counter resetting<<<<<<<<<<<<
5 times Orange (Alarm) Destination settings After
entering the destination settings mode, press the
Resume/Cancel button the specified number of time(s)
to select the destination. For detail, see
"Destination settings procedures" below.
6 times Green (Power) Print head deep cleaning
(Cleaning of both black and color)
7 times Orange (Alarm) Reserved
8 times Green (Power) CD / DVD check pattern
9 times Orange (Alarm) CD / DVD print position
correction (horizontal: X direction)
10 times Green (Power) CD / DVD print position
correction (vertical: Y direction)
11 to 13 times Orange, Green, Orange(Alarm,
Power,Alarm) Return to the menu selection
14 times Green (Power) Left margin correction Not used
in servicing.
15 times Orange (Alarm) Return to the menu selection
Time(s) LED indication Destination CD / DVD print
0 times Green (Power) No change of the destination
1 time Orange (Alarm) Japan Supported
2 times Green (Power) Korea Not supported
3 times Orange (Alarm) US Not supported
4 times Green (Power) Europe Supported
5 times Orange (Alarm) Australia Supported
Oct 30, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
Acer AL1917W LCD Monitor Logo
67 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
