Question about Bosch Washing Machines
Bosch Washer Can i use Oxy or anything like it in the washer. Cuz with my old one I used Oxy with every wash.
    Genius:
  • 1,036 Answers
Hi there!
Yes you can. You can also reduce the ammount of detergent you use if yoe are using that.
Try also basic Borax if it is available. It's natural, antibacterial, and biodegradable......Good news all round.
Posted on Jun 17, 2008
My maytag neptune spins water out, the tub is empty but when you turn the tub manually you can hear water sloshing and the clothes smells moldy after washing
There will always be some residual water left in the outer tub after draining. This is normal for most washers. Purchase a container of Oxy-clean and cycle the washer a few times using hot water settings with a half-cup of Oxy-clean added to each cycle. This will help remove any organic matter left behind that might be causing odors.
Oct 15, 2014 | Maytag Neptune MAH5500B Front Load Washer
Front end loader
are you using the correct detergent and not to much for this machine-try cleaning out the drain trap and filter-wipe down the door seal and tub with a bleach or oxy type cleaner -run the sanitizer cycle with a quarter cup of powdered dishwasher soap,and finally leave the door open between loads-this ain't your momma's washer-these things can be a pain in the booter-cheers Denny
Oct 26, 2013 | Samsung Washing Machines
I have a 2009 bosch 100 series washer that won't wash or spin, but will drain?
I realize that this post really old but I wanted this to be available for the next guy. I bought Bosch part number 154740 which are brushes that worked for me. They will tell you it wont work but it did for my Bosch (wfmc1001uc/09) washing machine.
Mar 06, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
My Bosch Nexxt 100 washer is making a clanking noise. I checked to see if anything was in the pockets of the clothes I was washing. It sounds like something is loose inside of the washer but not in the...
By your description of the noise<it sounds as if the bearing in the "agitator"is defective or "wornout". Or at times anymetal object could some out of pockets and get lodged under the drum of the agitator.you can check this by taking a long flat object,such as a rule,and slide it around the inside of the the machine.
Feb 12, 2011 | Bosch Washing Machines
I have a bosch washer about 3 years old. It suddenly stopped on spin cycle and water would not drain even when I put it to drain only. The motor chatters now like a car with a battery that is dead. Is this...
It does sound like the problem is related to the water pump.
The filter should be located at the bottom front right of washer, sometimes behind a removeable cover.
Locate filter, and remove by turning anti-clockwise, and clean, check inside the filter housing for anything in there as well.
Hope this helps.
Nov 30, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
My new Bosch Nexxt 500 series washer is less than 30 days old. I can turn it on any program and I can hear it initially fill with water, but it does not spin to wash or rinse. It does not have any error...
As your washer is less than 30 days old, I strongly recommend that you contact the company you purchased it from, and ask them to change it for you, under the sale of goods act, you have the right to insist upon a replacement washer.
However, before you do that, double check your handbook, and make sure it is nothing you have done wrong.
Try switching it off, and then try again to use it.
Please leave feedback.
Thankyou
Nov 13, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Why no bleach?
Simply put. It's not needed in this machine. The hole idea of a front load washer (most euro models anyway) is the old "mechanical wash" idea. Hence no need for bleach, which is solely for use in a "chemical wash" machine, i.e. top load washers.
Sep 17, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Washer won't run , push start button just beeps
in order to determine what is the cause of your problem , please provide the error codes an model number so we can figure out what is wrong with it, has anyone set anything heavy on top of the machine if is a top load machine, first guess if you have power to the machine would be look into the lid swtich an go from there....
May 28, 2009 | Bosch Washing Machines
Blue stains on laundry
I was talking toa repairmain about which washer/dryer to get and he mentioned that the Bosch can stain clothing blue. I don't know anything else about why...but I'd contact my Bosch dealer.
Jul 06, 2008 | Bosch Exxcel WFO 2264 Front Load Washer
Washing Machines Logo
65 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
