Question about Microwave Ovens
The timer runs down and the inside lights up, but it does not heat anything and there is no sound like the emitter is working. What can we do? Purchased less than a year ago.
Could be a fuse or the magnitron is bad either one will require removing the entire case. If it is the fuse it is an easy fix for about $2. If magnatron go buy a new microwave. hope this helps.
Posted on Nov 11, 2010
Won't run.
Check the door switches, primary and secondary, to see if they are both functional. One might be open.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Sep 21, 2016 | Microwave Ovens
How can I get my microwave to actually heat when everything else (cook time, power level, clock, etc., are set and seem to be running?
Sounds like the MW Emitter is not working or the wave guide is disconnected. If it is the wave guide then you can fix it yourself if you take the rear cover off. It is the pipe, which in cross section is quite rectangle shaped with rounded corners. It should be connected to the emitter at one end and the opaque guide cover at the other with no breaks. If the emitter is faulty then seek professional help.
Oct 19, 2014 | Hamilton Beach 1.1 cu ft Digital Microwave...
How do i replace the fuse
I myself would never work on a microwave myself. I have known many people have fatal accidents due to contact with capacitors inside. Just an FYI.
Jun 23, 2014 | LG LMV1683SW 1.6 Cu. Ft. Over-The-Range...
Microwave timer works but will motor will not run/cook.
If everything works on the unit, but you do not receive any heat or possibly the turntable does not turn you have a faulty magnetron (controls heat) and a faulty motor (controls turntable). You would require service on the unit, if parts are available. Some microwaves are so small in cubic foot size, that manufacturer's do not have parts available for purchase/repairs.
Dec 24, 2012 | Frigidaire FMV156DC Microwave Oven
I got this Sunbeam SGB8901 microwave that doesn't heat anything. It turns on, rotates drink or food, and it sounds like it's working fine, but once the timer counts down, you pull out the drink and it's...
That will either be the magnetron or the power transistors inside having failed. If you get lucky a repair shop might be able to fix it reasonably but usually it is time to look for a replacement as the repairs cost more than the new one.
Jan 24, 2011 | Microwave Ovens
No Heat but everything else works
Magnetron and diode most likely. Need more info.
Nov 02, 2009 | GE XL1800 1100 Watts Microwave Oven
Hood range microwave not heating up
We had one that did the same thing. my brother got so mad at it he put a wrench in it and turned it on. It didn't do anything to it. No power surge nothing. It acted as if I put a plate of food. Lighted up turned and even beeped when done. The wrench wasn't even hot. Now I do recommend this myself. But we went and got antoher one.
There is something in there that magnifys the power inside the mircowave and it sounds like its out.
Dec 12, 2008 | Emerson MW8778 Microwave Oven
My over the stove microwave will run however no heat. Popcorn digets do not count down but set numbers do. odd odor.
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
 Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Dec 11, 2008 | Microwave Ovens
Microwave turns on, but no heat or turntable movement
The problem is that the magnatron is not getting power. Chance is that if could be a bolwn fuse inside the unit. If the fuse don't fix it then that leaves the charging diode, capacitor or the magnatron, or high voltage xformer of which without technical epertize I would not recomend attempting to replace. good luck
May 14, 2008 | Hotpoint RVM1635 Microwave Oven
Microwave not making any sound, or heating. control panel works!
This microwave probably has a serious electrical problem...a defective magnetron or rectifier. It should probably be checked by someone who is familiar with electrical repairs...there can be high voltage inside and a danger of electric shock, even when the oven is off.
Jan 18, 2008 | Microwave Ovens
Microwave Ovens Logo
19 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
