Question about Intertherm Heating & Cooling
Hearter blower and furnace come on at same time
  • 43,501 Answers
I will have to assume a couple of things here that I do not know for sure....correct me if my assumptions are wrong...
The furnace and the blower come on at the same time but the heat will shut off and the blower keeps on running...when the thermostat is satisfied....
To do this either the fan switch is turned on at the thermostat.... or the "R" and the "G" wires are shorted together...
Or... the switch that turns on the fan when the heat exchanger gets hot is stuck in the "on" position or is closed...this makes the fan run all the time....
Or something is shorted in the high voltage circuit so that the fan gets power all the time....
To find the exact cause of the problem you will need to trace back and find where the power is coming from and why.... this will need to be done with an electrical meter....
Be careful and disconnect power when working with the furnace circuits...
heatman101
Posted on Nov 11, 2010
Tip
When the furnace blower runs all the time.
Usually when the furnace blower motor runs all the time
The limit switch or rollout switch is usually open or bad.
The furnace board is seeing that one of those switches is open, so it brings the blower on to try to get the heat out of the combustion chamber area, so the switch will close. But if the switch is bad and won’t close, the furnace board will keep the blower running continuously.
Make sure the fan switch on the thermostat is not in the "ON" position it should be in the "AUTO" position.
on Dec 30, 2009 | Heating & Cooling
Coleman evcon furnace
How old is your furnace? Does it have a circuit board that controls everything, or are there separate controls for each function?
Nov 19, 2013 | Heating & Cooling
Blower does not blow when hearter is on
blower motor resistor, had the same issue replaced blower motor resistor
Feb 22, 2013 | 2004 Chrysler Sebring
Goodman furnace GMP075-3 The thermostat was in the off position over night and sometime during the night, the induced blower and blower motor came on. The trouble light on board blinks 5 times. I checked...
Need your model # to check the codes but, this coming back on after turning the t-stat off is rare. You may have been in a lockout and the furnace re-started. Some furnaces try to start three times , then lock out. Time out, then re-start. The codes should be on your furnace blower door. Write back with this info and i could help.
Oct 12, 2011 | Goodman GMS90703BXA Heater
Tappan furnace blower will not shut off and furnace does not heat and red light is blinking one flash constantly.
Mar 12, 2010 | Heating & Cooling
Furnace blower won't stop running
Jan 04, 2010 | Amana Comfort Zone 12M32PBEH Air...
Citreon picasso hearter blower not working
has your picasso got climate control? if so you probably have a faulty ignition switch
the contacts in the switch which supplies the live to the heater wear and cut the supply
Dec 13, 2009 | Peugeot 505 Cars & Trucks
Heating & Cooling Logo
343 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
