Question about Jenn-Air JJW9527C Expressions Collection Electric Single Oven
My Jenn Air jjw9527cas single, electric wall oven started beeping non-stop when not in use. I had to throw the breaker to make it stop. I wonder what the problem is.
  • 1314 Answers
SOURCE: Jenn-Air single electric wall oven #JJW9530DDS
try to open the door see if the door latch is extended if it is locate the light switch on the oven cavity and hold it in then hit start then cancel or stop the latch rod should go back
Posted on Dec 29, 2007
eagle338
  • 4889 Answers
SOURCE: F2 fault, continuous fan after clean cycle for Jenn-Air electric convection wall oven
The "F2" means the oven control senses runaway temperature. The cause of the problem could be the oven sensor, the oven sensor wire harness or the power relay board.
PS:please disconnect your oven from power supply completely before continuing.
Open the control panel and measure the oven sensor resistance at the control board. It suppose to be about 1100 Ohms at the room temperature.
If the reading is wrong do the same test at the oven sensor connection (where the sensor wires goes through the back panel).
If the reading is still wrong - replace the oven sensor.
If the reading is correct, check the wire harness and the connector itself (it's better to eliminate the plastic plug and hardwire the oven sensor).
If there is nothing wrong then the power relay board has to be replaced.
Posted on Nov 07, 2008
taran_2005
  • 10515 Answers
SOURCE: Jenn-air electric double control does not work - clock is on
Disconnect the Power Supply for few minutes, say 30 minutes and then Turn the Oven ON.
Do you see any Error Message?
How old the Unit is?
Do you have any Experience to Fix this?
Do you have all the tools?
Let me know, so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 30, 2010
SOURCE: 7 yr old jenn-air wall oven locked shut, shut down
It will remain locked until the temperature is safely as low as it should be. You just have to wait and be patient.
Posted on Feb 13, 2010
mc1bean
  • 3053 Answers
SOURCE: my 27" jenn air single
Hello, dowd
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and farther back, It appeared that no one answered some of them, So, I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your oven, from repair to trouble shooting it. Even pictures and video's. Just scroll around and you will see tons of information to almost any question you might have on your Oven. If you go to this link and click around, I am sure you will find out so much about your oven, you will know more than the company that made it. The good thing about this link is, then you can make the decision of DIY or hiring a pro. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Thanks,Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
What does F1 mean on my oven
F1 code for Jenn Air is related to the main electronic control board. If you can turn your breaker off for a few minutes then back on it may reset. If not you will most likely need a new control board. Depending on your model number and age there may be extended warranty on the parts, check with Jenn Air to be sure
Apr 24, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Jan 31, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
I HAVE A JENN AIR WALL OVEN AND WAS CLEANING AND MY JENN AIR MICROWAVE STOP WORKING DO YOU HAVE ANY IDEA'S
Check for a tripped breaker or blown fuse in your fuse box. Assuming they are separate units there is no common connection other then the power source.
Good Luck,
Gilshultz
Dec 03, 2009 | Jenn-Air JJW8530C Expressions Collection...
Beeping and displaying F1. Press stop and 30 seconds later it starts again.
too high temp F1 fault code its either the keypad, or the control board.if the thermostat or oven sensor is bad,it could have got the keypad or control board too hot, and caused the F1
Aug 30, 2009 | Jenn-Air 30 in. Pro-Style Electric Single...
Jenn air touch panel on oven beeping and flashing
throw the jenn-air out.
purchase something from another company that cares about their products.
I have had the same issue, twice. my wife managed to melt the touch pad by baking and using the burner at the same time. this has happened to countless purchasers of jenn-air **** appliances. they should be sued and forced to fix their faulty design
Aug 29, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
WW30430
lower oven gives Fr code when turned on
Jun 23, 2008 | Jenn-Air JJW8527C Expressions Collection...
Jenn-Air Electric Oven - F-1 Code
You can disconnect the beeper so its not so annoying. turn oven off at breaker first. pull out oven a little so you can get at the top 2 screws on each side. The speaker is between the boards on the display module.
look for a red wire connected to a gold disc like speaker. remove this wire and you won't hear the beeping anymore.
Nov 27, 2007 | Jenn-Air JGW8130A Electric Single Oven
My older jenn air double wall oven
shooter, F1 is usually the touchpad failure. You can try disconnecting the touchpad ribbon from the control and cleaning the ends with an eraser. See if the F1 stops. Catriver.
May 24, 2007 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air JJW9527C Expressions Collection Electric Single Oven Logo
46 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
