Question about Philips 32MF231D Television
I have a dead set. No voltage to the off/on power button. 117 in at plug, none at filter cap. I needa schematic so I can figure out which part(s) are causing problem, where can I get download one?
  • 11,361 Answers
Try looking here for the service manuals:
http://elektrotanya.com/?q=showresult&megnev=Philips&megnev2=32MF&kategoria=tv&kat2=all
This site has allkind of sch for LG, SAMSUNG, VIEWSONIC, DELL, SHARP, TOSHIBA, and on and on.
Here is the troubleshooting guides, it sounds like you not have the 5vdc standby voltage, without it the TV can not start.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
Posted on Nov 11, 2010
  • Philips Master
  • 8,457 Answers
There are no LCD or Plasma tvs schematics out there,the tv corporations don't release them.U want to troubleshoot the power supply board must do it with ur own skills.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Power flashing on/off when plugged in
general info first and then some photos---
I see so many here with no sound/no picture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signs of damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down the problem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the generic ones like Radio Shack). Many fuses are special even aside from amperage--Don't put a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses a standby power supply that runs 7/24 and a main supply (some are combined and some not.
Here aside from checking fuses you want to examine all the filter caps on the power/standby to see if any are puffed up or buldged up in some fashion--I attach a photo of a good one---top should be silver metal and PERFECTLY flat and have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating (saves money) which causes them to fail in a year or two---the standby runs 7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over. If set is opened at least look for puffed up and bad caps like in this photo.
The standby runs 7/24 and to save money they use caps close to the actual voltage---not too smart but saves money when making and the get hot and dry out inside---hence the puff which is really nice as if have that 95% of the time if replace the caps (slightly higher working voltage please) you have a working set.
Nov 06, 2012 | Samsung Televison & Video
Rca L32WD12YX9
ls this part itself a filter cap or a fuse? If a cap it will have value, voltage rating and plus/minus marked right on it.
Dead set or what?
Jun 17, 2012 | RCA L37WD12 37 in. LCD HDTV
Hi, i have a 42inch Dynex Flat Screen, the issue i have is that when i plug in my Tv, the little red indicator comes on showing that its ready to be powered up, but when i push the Power button the Blue...
I will give you some general info and some ideas--let me know what you find or if you have questions.
I see so many here with no sound/nopicture issues:
ISSUES:
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.
May 25, 2012 | Televison & Video
How to fix my plasma after a suspected power surge.
Power supply board would be first suspect to look at.
some general info:
ISSUES:
Answers to issues:
May 18, 2012 | Panasonic Viera TH-50PZ80U Plasma TV
Samsung LN40C610N1F. When plugged in, the red standby light comes on, but when I hit the power button the unit will not power on. The light doesn't blink or anything.
ISSUES:
Answers to issues:
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.4_19_2012_3_53_26_pm.jpg
if set opened look for puffed up caps like these on the power board.
Apr 18, 2012 | Samsung 40 LN40C610 LCD TV
A big hum of 100 c/s in the output,i need the schematic for repair
You must be on 50Hz power. You don't really need a schematic to repair the unit. Since the hum is twice power line frequency, the likely cause is the electrolytic filter cap for the high voltage has failed. The cap should be obvious in the unit. It will be near rectifier diodes and have a voltage rating above 50 volts. To test, bridge the one in there with another cap observing the correct polarity. If hum changes, replace the original cap.
May 25, 2011 | Electro-Harmonix 12ay7 Tube Microphone...
ViewSonic Mod# N3260W VS11436 1M
I do not know the exact value but if you trace out the copper trace from the rectifier output, it should go to the first filter cap and then there will be an inductor and filter cap after that, you can figure out the voltage rating from there. You can get the parts here: http://www.shopjimmy.com/catalogsearch/result/?q=ViewSonic+N3260W
Look here about caps: http://en.wikipedia.org/wiki/Capacitor_plague
Pictures of the power supply will help. budmrtn@aol.com
Dec 08, 2009 | ViewSonic NextVision N3260W 32 in....
Jvc dvd/hdd recorder model dr-mh20sek
OK changing the caps only resulted in proper filtering and voltage smoothing and did very little to solve your problem. Now what swollen caps are a sign of is an over voltage condition. what I would suggest because you may have a bad voltage regulator, is that you have to get a schematic and measure the voltage levels on the power supply to determine if they are correct or not. This will tell you if the regulator is bad or not. You do have a power supply problem you just have to determine where in the power supply. This can be done with the schematic and a voltmeter.
Sep 17, 2007 | Televison & Video
Televison & Video Logo
256 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
