Question about HP Officejet 5610 All-In-One InkJet Printer
I bought a new ink cartridge, but cannot find my manual. How do you change the cartridge???
  • 270 Answers
TO REPLACE THEprint CARTRIDGES 1. Make sure that the HP all in one is on. Caution: If theHP all in one is off when you open the print-cartridge access door to accessthe print cartridges, the HO all in one will not release the cartridges forchanging. You might damage the HP all in one if the print cartridges are nordocked safely on the right side when you try to remove them. 2. Open the print cartridge access door bypulling it forward. The print cartridge moves to the far right side of the HPall in one. 3. Wait until the print cartridge is idle andsilent, end then lightly press down on a print cartridge to release it. If youare replacing the tri color print cartridge, remove the print cartridge fromthe slot on the left. If you are replacing the black or photo cartridge, removethe print cartridge from the sloth on the right. 4. Pull the cartridge toward you out of itsslot. 5. If you are removing the black printcartridge in order to install the photo print cartridge, store the black printcartridge in the print cartridge protector. 6. Remove the new print cartridge from itspackaging and be careful to touch only the black plastic, gently remove theplastic tape bay using the pink pull tab. 7. Slide the new print cartridge forward intothe empty slot. Then gently push on the upper part of the print cartridgeforward until it clicks into the socket. If you are installing the tri colorprint cartridge, slide it into the left slot. If you are installing the black,slide it into the right slot. 8. close the print carriage access door.
Posted on Nov 11, 2010
  • HP Master
  • 4,338 Answers
Here is the manual, see pages 79-81
http://h10032.www1.hp.com/ctg/Manual/c00461378.pdf
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
    Sergeant:
  • 358 Answers
Changing an HP Ink Cartridge
  • 1
    Open the lid of the printer. Depending on the model, there will be two cartridges on the right, one for black and one for color.
  • 2
    Find the cartridge that is running low on ink. The black cartridge will be in black, the color cartridge will have a patch of color (usually green) on it.
  • 3
    Pull down on the black clamp that is holding the cartridge in place and slide out the used cartridge.
  • 4
    Open the package of the new ink cartridge. Remove the protective tape and slide the new cartridge into the printer.
  • 5
    Snap the black protective case back into place and close the lid.
  • techbelkin
    2 Suggested Answers
    • 313 Answers
    SOURCE: How do I change my ink cartridge for my HP2610. I
    check your user manual
    Posted on Mar 23, 2010
    My HP photosmart 7510 does not recognize the presence of any color cartridges. I use only HP 564 cartridges. It prints only black. What can I do with it?
    Check this link for ink cartridge problems. The part on "older generation cartridges" is very interesting. It is located on page 39 of the manual (page 40 of the pdf).
    http://h10032.www1.hp.com/ctg/Manual/c03011756.pdf
    Jan 06, 2015 | HP Photosmart 7510 e-All-in-One Printer
    I don't know how to change the ink bought this printer from a guy at work no manual
    Lift the scanner cover from the right-hand side of the MFC until
    it locks securely into the open position.
    If one or more ink cartridges are empty, for example Black, the
    LCD shows Ink Empty Black and Cover is Open.
    Pull the ink cartridge hook toward you and remove the ink
    cartridge for the color shown on the LCD.
    Open the new ink cartridge bag for the color shown on the LCD,
    and then take out the ink cartridge.
    Remove the cartridge covers.
    Each color has its own correct position. Keep the ink cartridge
    in an upright position when you insert it into slot. Press down on
    the ink cartridge until the hook snaps over it.
    Lift the scanner cover to release the lock. Gently push the
    scanner cover support down and close the scanner cover.
    If you replaced an ink cartridge while Near Empty was
    displayed on the LCD, the LCD may ask you to verify that it was
    a brand new one. Example: Did You Change Blck? 1.Yes
    2.No. For each new cartridge you installed, press 1 on the dial
    pad to automatically reset the ink dot counter for that color. If the
    ink cartridge you installed is not a brand new one, please be
    sure to select 2.
    If you wait until Ink Empty message is displayed on the LCD,
    the MFC will automatically reset the ink dot counter.
    If the Install message is on the display after you have
    installed ink cartridges, check that the ink cartridges are
    installed properly.
    Hope that helps you!
    Aug 12, 2009 | Brother MFC 420CN All-In-One InkJet...
    Giant blobs of ink on every photo...
    If you aren't currently, use the cartridge that the printer's manual says is for photos. Photo paper requires a different kind of ink.
    Jun 26, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
    Why won't my CX9400F recognize Epson ink cartridges
    The Epson CX9400F printer seems to require replacement of all the color ink cartridges, even if only the Black is empty.
    I print almost exclusively in Black, but with my first change of Black, I was forced to change all the color. At the time I thought Epson did not provide completely filled color ink cartridges.
    Just yesterday, I replaced Black and the printer complained it did not recognize the rest of color cartridges. So I replaced all the other color ink cartridges and now it works fine.
    You might want to check out www.clickinks.com for cheaper, mail order alternatives which are Epson ink compatible, if you are not in a hurry.
    ew
    Feb 23, 2009 | Epson Stylus CX9400 Photo Printer
    Lexmark x5490 Right /left cartridge incorrect
    If you brought new cartridges and printer detecting it empty ,then you get it
    replaced as the Lexmark cartridges comes with a 6 months warranty ..
    Good luck....
    Feb 13, 2009 | Lexmark X4530 InkJet Printer
    Changed cartidges & now black and blue don't print on C88+
    Try to remove and reinstall the blue and black cartridge and check if you punctured the plastic cap underneath the cartridge itself. then reinstall it and make sure you hear a click or it snaps in. try head cleaning cycle from the utility and print a nozzle check pattern. If same output maybe carts are bad. If that is a genuine epson ink cartridge, call epson and have the ink cartridges replace since they are new ones and for sure epson will send inks since you just bought it. make sure you have date of purchase handy.
    pls dont 4get to rate solution if it helps... thanks!!
    Apr 16, 2008 | Epson Stylus C88 InkJet Photo Printer
    Can't figure out how to change ink in HP PSC 1410
    heres the link for the manual for this printer , it will inform you
    how to change the ink cartridges , hope it helps, just click here:
    http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=441115&lc=en&cc=us&dlc=en&lang=en&cc=us
    Mar 30, 2008 | HP PSC 1410 All-In-One InkJet Printer
    Dell 725 printer no manual need to change ink cartridge
    Here is the manual
    http://support.dell.com/support/edocs/systems/725/en/index.htm
    Replacing an Ink Cartridge
    1. Turn on your printer.
    2. Lift the front cover.
    The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
    1. Press down on the ink cartridge lever to raise the ink cartridge lid.
    1. Remove the old ink cartridge.
    1. Dispose of the old cartridge properly.
    2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
    1. Insert the new ink cartridge.
    1. Snap the lid closed.
    1. Close the front cover.
    Feb 09, 2008 | Dell 725 InkJet Printer
    HP Officejet 5610 All-In-One InkJet Printer Logo
    195 people viewed this question
    Seeker5211
    Seeker5211
