Question about Canon Office Equipment & Supplies
I am trying to install software for a Pixma MX340 printer on a Windows 7 laptop. I get an error message saying I must log on as an administrator but when I go to control panel and check account settings it says I have adminstrator priviledges. I am stuck please help.
  • dkroll993 Nov 11, 2010
    thanks but when I log out or change user I only see two choices, one is me, and the other is guest. so how do I log in as administrator?
    Sergeant:
  • 358 Answers
Try to log-in in administrator account first. Even though you do have a privilege like an administrator but when it comes to installing software you need to log-in manually in admin account. If this not work, try to download a driver that compatible to windows 7 OS.
Just clink the link below to download the driver for the Pixma MX340 printer:
techbelkin
Posted on Nov 11, 2010
  • Canon Master
  • 3,530 Answers
Welcome to Fixya!
In order to log in as an administrator, you need to activate the hidden administrator account.
What to do?
You need to open the command prompt.
  1. Go to Start > All Programs > Accessories > (right click) Command Prompt > Run as administrator.
  2. Type net user administrator /active:yes and then press Enter
3. Restart the computer
4. Log in as an administrator
5. Re install the software.
If you have any questions, please feel free to come back.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
When i scan it does not have a programe to save to
Hi Ben,
You can download the Drivers for your Canon Printer from the link below.
Download Canon Pixma MX340 Drivers
Click on the link above and choose Drivers and Software and Select Win 7 from the O/S list below.
From the list below on the webpage - click on the First Option under Drivers Section to download and then run the file once it is downloaded to start the installation.
Regards,Suhail
Nov 13, 2011 | Canon PIXMA MX340 Wireless Office...
As long as i have my usb cable hooked up to my printer and laptop it works but when i disconnect the cord its offline.what should i do?
It may not be configured to the correct port.The port selected could have been the USB port that's why when you disconnect the USB cable printer goes offline and would not print wireless. Follow the steps below if you are using a WINDOWS computer: For windows XP :
  • Click on start then go to printers and faxes.
  • right-click on the default printer canon pixma mx340 series
  • go down to properties
  • click the ports tab
  • check to see which box is checked.If the usb port box is checked,that answers the reason why printer goes offline and would not print wireless when USB cable is disconnected.
  • In the list of ports ,look for tcp/ip with the correct ip (192 number) address of the computer.
  • when you find it,tick the box,click on apply then ok.
  • if you do not see it anywhere on the list ,you need install the software.
For win vista
  • click on start,in the search box key in printer then hit enter on the keyboard
For win 7
  • click on start,in the search box put in devices and printers and hit enter
  • click on printer properties
Let me know if you need assistance in configuring wireless connection and installation.
Jul 17, 2011 | Canon PIXMA MX340 Wireless Office...
Cant download skype, problem with toolbar, error 2738
Take a look in Event Viewer I looked in Event Viewer to find out what MSI-file that generated the error message and found:
Log Name: Application
Source: MsiInstaller
Date: 23.09.2010 21:58:26
Event ID: 1040
Description:
Beginning a Windows Installer transaction: C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}\SkypeToolbars.msi. Client Process Id: 6564.
2. Running MSIEXEC with logging options I started a "Command Promt" and used the command: "cd C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}" to navigate into the folder containing the MSI-file.
Now using the command: "msiexec /i SkypeToolbars.msi /lv log.txt" (msiexec options: /i = Install, /lv = Log + Verbose output).
After clicking away the error message I just wrote "log.txt" in my "Command Promt" to open the log-file. Near the bottom of the log-file I found this line:
DEBUG: Error 2738: Could not access VBScript runtime for custom action
3. DEBUG: Error 2738 After a quick search at Google I found out this error indicates that the VBScript engine is not registered on the computer.
The solution for a Windows Vista or Windows 7 32bit:
- Click Start -> All Programs -> Accessories
- Right click "Command Promt" and click on "Run as administrator"
- Write "cd %windir%\system32" and hit Enter
- Write "regsvr32.exe vbscript.dll" and hit Enter
- You should now get a message that says: "DllRegisterServer in vbscript.dll succeeded."
- Click "OK"
The solution for a Windows Vista or Windows 7 64bit:
- Write "cd %windir%\syswow64" and hit Enter
- Click "OK"
4. Try again... Now I tried once more to run "msiexec /i SkypeToolbars.msi /lv log.txt" (I kept the /lv log.txt option to look for changes if the installer would fail again).
If you still get the same Error than continue to step 5.
5. Cleanup registry first, then re-reg My installation still gave me the same error, so after some more searching and reading on Google I found a solution that explained what I tried before (with the regsvr32.exe) and also an alternative step if that one should fail. The alternative step was to remove the Registry Key pointing to vbscript.dll.
The alternative solution for a Windows Vista or Windows 7 32bit is then:
- Write "reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Click "OK"
The alternative solution for a Windows Vista or Windows 7 64bit:
- Write "reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Write "cd %windir%\ syswow64" and hit Enter
- Click "OK"
Now using the command "msiexec /i SkypeToolbars.msi /lv log.txt" the installer started perfectly, ran all the way thru and Finished.
Conclusion This message indicates that VBScript engine is not currently registered on the Computer running the installer.
Vbscript.dll must get registered to solve the problem.
Ref: http://community.spiceworks.com/how_to/show/1577
Apr 25, 2011 | Computers & Internet
I have a computer with windows xp connected with usb to my canon pixma mp780 and connected to my network my laptop with windows 7 is connected with wlan to the network.the laptop see the printer but i...
I've had a similar problem trying to print to a printer that was not on my laptop but connected to the network through a desktop that was connected to the WiFi router and a cable modem.
If you can see the printer, maybe the driver is already installed.
In my experience, I had to log on as the administrator to print to the printer but I have windows 7 on all 4 of my computers.
I don't have xp anymore.
Maybe xp is the problem.
Jul 02, 2010 | Canon PIXMA MP780 All-In-One InkJet...
SOFTWARE CANNOT BE INSTALLED USING THE RUN AS COMMAND I have brought a new Compaq laptop & I'm now trying to install my HP psc 1315 all-in-one printer/scanner/copier. I'm loading the Windows CD &...
try restarting the system, after a few seconds BEFORE windows load press F8 continuously until a selection screen appears, select safe mode, wait for it to load, select ADMINISTRATOR ACCOUNT not your name or your account log in, install printer driver, restart. Your driver is installed.
Jul 02, 2010 | HP PSC 1315 All-In-One InkJet Printer
I keep getting a message saying I need to have administrator rights to install it on my new laptop with Windows 7. I have gone into the control panel created a new acct. With my name restarted my computer...
Dear Friend,
There is one default account in system by name Administrator. Log from that account. (Administrator account is having all rights to perform any process in the computer.)
Or you can do delete all your user account so only administrator account will remain. Then Log off.. and while login you will able to see that account.
Please rate the answer.
Jun 09, 2010 | HP PSC 1315 All-In-One InkJet Printer
Installed usb to db26F converter to use printer
Ok reinstall as Administrator, use "Compatibility mode" for install and the run .exe, also run software as Administrator. too. Often these devices, USB - Serial Ports are NO GOOD for a printer. Either install a real Serial Port. or get a new printer. Windows 7 will NOT help either, it doesn't like older equipment.
Mar 24, 2010 | HP LaserJet 1100 Printer
Error message : You need to install or run device software for this feature
Make sure you are logged in as Administrator when installing drivers, in order to write files in the system area.
RDO
Nov 07, 2008 | HP OfficeJet 6210 All-In-One InkJet...
305 people viewed this question
old marine
old marine
