Question about Acer 22" X223w LCD Monitor
My acer X223W monitor has vertical lines running down both sdea of the screen. They only appear when I connect the signal cable.
  • 1,472 Answers
Vernoncharvi
If you are getting vertical line there is one of 2 things going on. Ether there is something wrong with the monitor or your computers video card.
The first thingg I would try is connecting the monitor to another computer to see if you have the same problem. Also if the monitor has another input connector I would try that as well. Most LCD monitors have a VGA and DVI input.
If you connect the monitor to another computer and it works fine then the problem is with your computers video card.
If the problem is with the monitor and it is out of warranty then you will want to look at replacing the monitor as it would be about the same cost to fix it as buying a new one.
Let me know if you have any more problems or questions.
Issken
http://www.fixya.com/users/issken
Posted on Nov 11, 2010
Red and green vertical lines appear on right side of monitor
Depending on the age of the monitor, it most likely will be Capacitors that are leaking. I have repaired many different brands of monitors and have seen problems very similar to yours. 99% of the repairs I do are capacitor Issues. It's well worth replacing them IF the screen is still in very good shape as far as brightness and contrast. most repair kits usually cost between 12 and 20 dollars.
Hope this helps!
Dec 08, 2013 | Acer 22" X223w LCD Monitor
Acer Z223w Display Problem
This is either your monitor or, more likely, your graphics card telling you it's going to fail soon.
Try another monitor, if that sorts it you're done. If not, it's the video source (graphics card).
Jan 18, 2013 | Acer 22" X223w LCD Monitor
How do I get sound from the Acer LCD monitor?
connect stereo audio cable from monitor to pc audio output
Mar 27, 2010 | Acer 22" X223w LCD Monitor
There is a Vertical Red Line and a purple line on the screen; plus sometimes it blinks yellow.
that is a cable problem check signal cable if faulty replace it if no cable problem then there must be a dry solder inside the monitor clear it
Mar 07, 2010 | Acer 22" X223w LCD Monitor
A red line in middle of screen, traded out with other monitor and thats what im using now
Usually lines, multicolored artifact etc. is indicative of a failing lcd panel or...a loose cable connector. There is no repair for this type of problem other than screen lcd panel replacement or secure the loose connection.
Jan 17, 2010 | Acer 22" X223w LCD Monitor
I am in chennai i buy one new acer 15" color monitor after 4 month that was one problem in the screen one line appear in my monitor.
It is your video card. My friend had the same problem, we got him a new video and that took care of it.
Dec 16, 2009 | Acer 22" X223w LCD Monitor
No signal keeps appearing
This message means the monitor is not getting a video signal from the computer.
This could be a loose video cable, a faulty video cable or a faulty video card.
It is possible the monitor is faulty, try connecting it to another computer with a different video cable. This will tell you if the monitor is faulty or not.
Sep 14, 2009 | Acer 22" X223w LCD Monitor
Multiple vertical color lines,i take the picture,how can i send you this photo?
There are two ways you can do this.
1. post the image to a site like photo bucket or flicker and post the link here
2. next to the You Tube on the top of the post reply window click the image. This will open a window. Browse to where you have the image saved and click it. This will insert the image to your reply.
Jun 02, 2009 | Acer 22" X223w LCD Monitor
Built own tower no signal on monitor screen
TRY NOT USING THE GRAPHICS CARD AND SEE IF IT WORKS THEN. IF SO I WOULD INSTALL THE DRIVERS AND THEN INSTALL THE GRAPHICS CARD.
Dec 26, 2008 | Acer 22" X223w LCD Monitor
1inch black line down right hand of screen
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Jan 15, 2008 | Computers & Internet
Acer 22" X223w LCD Monitor Logo
180 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
