Question about Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer
So just got a used bosh and it shows erroe message E13 and there is no water going into the drum what have I dont wrong
  • Bosch Master
  • 2,605 Answers
Welcome to FixYa.
The E13 error code on the WFMC series Bosch washer`s refer to a drainage problem, as you may or may not already know. ( or in Bosch terms "pump time exceeded" )
Anyway, here`s the most likely way to remedy a E13 code.
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, that sucks...hopefully you won't get too wet. ( maybe you`re lucky enough to be close to a floor drain )
  1. Locate the round door on the front of the machine (about 6" in diameter, lower right corner) so just got a used - macmarkus_26.jpg
  2. Find a drill bit or small screwdriver that fits in the hole in the round door.
3. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful).
4. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand. ( you should also see a red ring with a string attached, if you pull this the door should unlatch, but getting the water out first is usually a good plan )
There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out
5. Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap. Hopefully you'll find the item/debris that initiated the error code.macmarkus_28.jpg
6. After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test.
7. Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks.
Ultimately you may have a faulty drain pump, but I would certainly start by performing the things I listed first.
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "FixYa" and good luck.
Regards,
Macmarkus :)
Posted on Nov 11, 2010
  • Sol Young Feb 10, 2011
    How difficult is a drain pump replacement
My dell laptop has over 7000 error messages
dont belive all that you get told,,some one might be out to make money from you.you need to ask your self,,how did some one from india get your phone number..please dont belive them.
May 30, 2014 | Dell Inspiron Computers & Internet
Hi, I am not able to open the door of my Whirlpool washer dryer AWZ 5140 E after it finishes the cycle. It shows up E13 with ticking noise. There is no water left at this stage and I am able to open the...
E13 is a dispenser error the appliance diagnostic believes the appliance is full of water so won't release the lock first thing to try is the drain filter bottom right hand corner at the front unscrew it clean and refit just be prepared it's likely u will get some water out it when u remove it.
Dec 08, 2013 | Washing Machines
An error occured we cannot print a document which the orange light was blink semoustanousely
Damage canon printers, can be identified from the number of lights blinking in orange. So, you calculate, how many times the orange light is blinking. Example E2, E3, E4, E5, E8, E9, E13, E14, E15, etc.
Problem
For
the error code E13 = The following ink may have run out black/color
Solution
Press and hold the Reset button about 10 second. E13 error on canon pixma, occurs twice. E13 for black cartridges, and E13 for the color cartridges
Nov 25, 2011 | Canon Pixma iP2700 InkJet Photo Printer
E13 erro keeps coming up what does this mean ?
I have found this manual on the internet but your code of e13 is not listed the error codes only go up to e7.
To check out this manual which also lists contact information in the UK go to:-
www.tlc-direct.co.uk/Technical/.../Baumatic.../BMBDW13.pdf
Regards
Alan Hood
ami-man
UK
Mar 24, 2010 | Baumatic 23 in. BDW13 Built-in Dishwasher
Brother mfc490cw printer show offline and erro
Hello there:
for the document you want to print click on print and your printer should show up now just click on the printer and look down where it says use printer offline and click on it again and than it will say use printer online and just print from there ok please dont forget to rate this solution for me
best regards mike
Aug 06, 2009 | Office Equipment & Supplies
Samsung SMH 8165 ST E13 Error message. Oven
I own the same Microwave and it just gave me the same error code E-13. I was heating a large plastic coffee mug of cold water using the "beverage" control. The only thing out of the ordinary was I used very cold water from the Fridge. Maybe this had something to do with the Max time error. Hopefully this was a one off error.
Jun 24, 2009 | Samsung Microwave Ovens
Bosh axxis filter. how do i clean it? soap and
First of all the item I referred to in my question is actually a heat exchanger located below the dryer drum.
The maintenance man in the condo said remove it and clean it with soap and water. I did have a garden hose with a sprayer so I used the bath tube to give it a good cleaning.
It now looks clean and I cleaned the housing where this part is located with vaccuum and wet cleaning.
jtoolan 6-12-09 7:45 AM
Jun 11, 2009 | Bosch Axxis WTA4400 Dryers
How do I reset the error message on a dell 1710 after I replaced the drum? I held down the reset keys. Where do I know where the erroe is?
If reseting the unit power the reset button does not work then try to unplug it for 60 seconds. Also to your question are you trying to find out what the error code means or what is exactly wrong? If you just replaced your drum then I would uninstall it and reinstall it again to make sure that it is sitting in there correctly. Sometimes you may think it is and it is not seated right
Feb 20, 2009 | Dell 1710n Laser Printer
Bosh 1200 classixx does not finish the program, conditioner stays in the dispenser
I have cleaned the pipes going for rinsed water,plus the plumbing stuff like vertical pipe which has on top something like coupler for washing machine and dishwasher, here was problem. It was cloged up with rubish and becouse the pump could not make enugh pressure the machine has stopped in the moiddle of washing as it could not rinse.(Spin)
cheers
Sep 23, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer Logo
363 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
