Question about Breezaire WKL 4000 Wine Cooler
WKE 3000 temperature panel has stopped working - unit still turns on and off properly.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 50 Answers
IF YOUR UNIT IS A WKL IT SHOULD HAVE A SENTRI III CONTROLLER(BOARD) THAT HAS A LCD DISPLAY GREEN NUMBERS ON IT WITH BUTTONS(SET, WARMER, COLLER) IF SO THE ONLY OTION IS TO REPLACE THAT BOARD, A VERY SIMPLE PROCESS 10 TO 15 MINUTES MINIMU TOOLS, CONTACT BREEZAIRE AT 858-566-7473 THEY WILL SELL YOU A BOARD OR CONECT YOU WITH A DEALER TO BUY THE REPLACEMENT BOARD ARROUND $150 APROX
Posted on Sep 16, 2011
How can I rest the controller?
I'll take a shot and say by pressing and holding simultaneously
all three buttons, SET, WARMER and COOLER for at least one
second. The display will momentarily show some numbers maybe "8.8.", then "°F", then the storage temperature. If this action is taken before the unit has been OFF for about ten minutes, it will not restart for five minutes, regardless of storage temperature at the time of RESET. Also, I think all user settings and parameters will be retained in memory upon a manual RESET operation. Good luck!
Apr 08, 2016 | Breezaire WKE 3000 Wine Cooler
Breezaire wke 3000. What kind of refrigerant does it take and how much do I put in?
Refrigerant for homes is not like cars. Only licensed HVAC tech can add refrigerant in a home unit.
Aug 15, 2015 | Heating & Cooling
We have a profile General Electric model PTHS22LHS. The temperature control panel turned off. The refrigerator does not cool. Once the control panel stopped working the temperature just dropped.
Check the main board on the back of the refrigerator. Remove the cover and check for a burnt spot on the back of the board. UNPLUG THE UNIT FIRST
Dec 28, 2014 | Refrigerators
Refrigerant lose
YOU WILL NEED TO REPLACE THE CONDENSER COIL(HOT SIDE OR BACK OF THE UNIT) AND RECHARGE THE UNIT SAME AS IF THE UNIT HAD A REFRIGERANT LEAK.
COIL IS ABOUT $95
Feb 27, 2014 | Breezaire WKE 4000 Wine Cooler Unit - 1000...
Breeze air wkl 3000 blinking temperature al
NEW UNITS HAVE A VISUAL ALARM PRE SET TO KICK ON AT 62 DEGREES OR ABOVE, WHE THE WINE COOLING UNIT READS 62 OR ABOVE IT WILL FLASH "AL" AND THE TEMPERATURE NUMBER THAT FORVED IT TO KICK ON, IT IS JUST A VISUAL ALARM IT WILL NOT TURN UNIT OFF OR STOP IT .
THIS FEATURE WILL SHUT OFF ONCE THE UNIT READS ANY TEMPERATURE BELOW 62 DEGREES.
Dec 27, 2013 | Breezaire WKL-2200 Wine Cellar Cooling...
How do i change out the control board to Breezaire WKE 8000
A WKE 8000 IS PROBABLY THE EASIEST UNIT TO REPLACE THE BOARD ON, REMOVE THE TOP FRONT GRILL(COLD AIR DISCHARGE) AND BOARD WILL BE RIGHT THERE BEHIND THE GRILL, USE NEEDLE NOSE PLIERS TO REMOVE WIRES FROM BOARD, MAKE SURE YOU MARK THE WIRES BEFORE YOU DISCONNECT THEM(USE BLUE TAPE WITH NUMBERS) AND TAKE A PHOTO WITH YOUR PHONE OF THE WIRES WITH THE NUMBERS ON THEM,ONCE WIRES ARE REMOVED PULL THE OLD BOARD UP AWAY FROM THE 6 PLASTIC PEGS IT IS SITTING ON AND INSTALL THE NEW WKE CONTROL BOARD(IT SHOLUD BE BLUE IN COLOR) PRESS IT ON THE PLASTIC PEGS, AND RECONNECT THE WIRES USING THE NUMBERS AS GUIDE
Oct 13, 2012 | Breezaire WKE8000 Wine Cellar Cooling Unit
Whirlpool AD70USR0 Dehumidfier - Our basement is extremely humid and the dehumidfier sounds and looks like its running but collects no humidity...any suggestions why?
If it is very cold some of these consumer units will not turn on the compressor. If the unit suddenly stopped working and the temperature is room temperature I would guess a refrigeration issue- either a leak or bad compressor. Make sure the "full bucket" indicator light is not on- the condensate bin may not be plugged into the unit properly.
Sep 25, 2011 | Whirlpool Dehumidifiers
I have a Breezaire WK6000 which froze up and then stopped working. I am looking for someone to replace and install a new unit
DEPENDING ON AGE OFTHE WK IF IT IS AN R-134 UNIT(CHECK TAG ON BACK OF UNIT) AND IF ITS NOT RUSTED OUT IT SHOULD BE REPARABLE , BUT IF YOU WANT TO REPLACE I WOULD RECOMMEND A WKL MODEL OVER A WKE
Dec 11, 2010 | Breezaire WKE 6000 Wine Cooler
Got a hoover washer /dryer wdm 1300 , it wouldnt empty properly, watched the impellor on the pump and some times it would run and then stop , a quick flick with a screw driver and away it went again ,also...
HI CHECK THESE....
Step 1: Make sure the washer is receiving power. Check the cord, the plug, and the outlet. If a wall switch controls the outlet, make sure the switch is working. Look for blown fuses or tripped circuit breakers at the main entrance panel. If the unit is receiving power and still won't run, press the reset button on the control panel (if the washer has one).
Step 3: Make sure that both water faucets are turned on and that the drain and soap-saver return hoses are properly extended, without kinks. If the washer has a water-saver button, make sure the button is depressed; water may not circulate through the filter nozzle if the basket is not full and the button is not depressed.
Step 4: To make sure the water is the proper temperature, check the temperature selector switches on the control panel to make sure they're properly set. Also check the water heater temperature control. It should be set no lower than 120 degrees F.
THANKS
Sep 12, 2008 | Washing Machines
Breezaire WKL 4000 Wine Cooler Logo
156 people viewed this question
Top Breezaire Refrigerators Experts
mike cooper
maniman
Are you a Breezaire Refrigerator Expert? Answer questions, earn points and help others
