Power goes off after five minuits of play. work only after you unplug and then plug the unit back in,but then repeat the problem.
  • Tre Elkins Nov 11, 2010
    what unit is it?
    Problem Solver:
  • 19 Answers
It has a thermal coupler circuit that shuts it off because something inside is drawing too much current, best thing is to take it in for repair.
That is why it is turning off, to be safe and not burn down the house, the safety ciruit is working....so you need to take it into a repair shop to be fixed.
good luck....
Posted on Nov 11, 2010
DVD Player will not power on. Indicator light flashes repeatedly.
Since the players of this kind are not repaired because of the low cost of new, just replace it.
Jul 06, 2017 | Televison & Video
DVD Player will not power on. Power Indicator Light flashes repeatedly.
Plug out the device,Open the outer shell or strip the outer shell take a hair dryer heat up the board slightly until it feels slightly warm then plug in and switch on and remove disc.Then put outer shell back and fasten screws that where removed.
Jan 06, 2014 | Sony DVP-CX860 Multi-disc DVD Player
I have a Mitsubishi WS-55515 that was unplugged, when It's plugged back in there is power but no picture and green light flashes then the power goes off. For reading other posts I believe it is th
if set has been unplugged plug it in and try to turn on===when power light goes off in seconds:
on the front of the set press and hold both the menu and input buttons for five seconds and release both.
power light will blink a two digit error code like 2 blinks, 2 blinks pause and repeat it several times.
what error code do you find?
Apr 11, 2012 | Televison & Video
The switch button is not working..
Hi, kindly unplug the unit for five minutes. this will drain all power, and reset the main board. Once the five minutes have passed, simply plug the unit back into the power outlet. If the problem continues, the touch pad should be replaced asap.
Mar 27, 2011 | Amana RFS18MPS Microwave Oven
My hp laserjet 3330mfp reports a scanner bulb is warming up and it never goes off. I have tried to unplug then plug back in. The printer works fine.
Here is how to cold reset the machine. also I added some addtiona options below as well.
1 Unplug (or turn off) the product from the power source.
2 Press and hold down the * and menu/enter keys.
3 Continue to hold down the keys while you plug back in (or turn on) the product, through the entire power on sequence.
4 When the control panel display reads Permanent Storage Init. release the keys.
5 Allow the product to return to Ready before using the product.
If that doesn't work it can be a power related issue,
- Make sure it's NOT plugged in to a surge protector.-
- Try a different outlet on the wall.
if theses steps fail you will most likely have to replace the scanner assembly
Another Option you can try as well :
Also I found this on a HP forum NOT SURE IF IT ACTUALLY WILL WORK:
" Scanner Bulb Walkout - Unplug the power from the unit,plug the power back in wait until the unit reads "Scanner Bulb Warming Up" Unplug the unit. Repeat this step 5 times.
This should move the scanner assembly back to its home position.
link to this post : http://forums11.itrc.hp.com/service/forums/questionanswer.do?threadId=989123
Oct 20, 2010 | HP LaserJet 3330 All-In-One Printer
After about ten minuites of playing the amp shuts down and goes to protect mode.. I can then wait 2 minuites and turn it back on and it goes for a while again before repeating the sequence. Is it my...
Amps shut down due to, A: Short circuit, B: Overload. C: Over Heating. It is possible that the Output devices inside the Amp. get too hot during use, Are your speaker "Leads" "Big" enough? Is you Power Positive wire the same, Also as you say, Check your Earth. Sometimes a Fan on the output devices helps.
Mar 10, 2010 | Car Audio & Video
Microwave starts beeping, four times then displays SE
Sounds as if it may be getting hot look at the back and under the unit there will be a grid of sorts sometimes at the back and//or the bottom or side/s of the machine check to see if this is free of dust etc if not clean and try again remember microwaves can give a nasty bite//please switch off and unplug first..
Dec 29, 2009 | Microwave Ovens
Our GE countertop microwave key pad does not work. The start and clear button does not work. owners mamual jes1651 . unit is 2 years old.
HI. Kindly, unplug the unit for five minutes. this will drain all power, and reset the main board. Once the five minutes have passed, simply plug the unit back into the power outlet. If the error continues, the touch pad should be replaced asap.
Oct 19, 2009 | GE Microwave Ovens
Lg lrm-519 went into demo mode. Can't get it back
follow directions from the owners manual. while unit is powered up, unplug power cord from back of unit - wait 5-seconds. Depress the DVD open/close button while re-plugging the power supply cord to the unit. LG splash appears onscreen and unit goes into re-set. you do not loose any of you programing or settings.
Jul 18, 2009 | LG Electronics LRM-519 Digital Media...
VR357 is froze up
Try resetting the unit.
Press and hold FF and RW on the player (not the remote).
Jan 21, 2009 | Samsung DVD-VR357
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
