Question about Fossil VT2654 Pocketwatch
Need to open Fossil watch
I can't seem to pry the back off like other watches I have had. I need to replace the battery. I read somewhere that it twists off and needs a special tool. I went to Wal-mart, but they aren't allowed to touch it.
  • 2,794 Answers
Here is the customer care number for fossil:
800-449-3056
They should be able to help you out.
Posted on Jun 17, 2008
Need watch battery size for a fossil blue watch model number Tl-5073
  • Remove back
  • Find battery mounting. Note for later battery installation
  • Read battery type (not size)
  • Obtain exact battery replacement
  • Remove old battery; install new
  • Check operation
  • install back
  • Set watch
Sep 09, 2016 | Fossil Watches
How do u open back to fix an fossil black 5 atm fs-4351 hand watch
Jerry, If its smooth on the back cover, you have to pry it off carefully. Get a magnifying glass and look around the cover edge, there should be a small under cut. Pry at this point with a penknife blade or similar. If the cover has 6 or 8 small indentations in it then it likely unscrews but you may still need to see a watch shop for the tool to unscrew it.
Fossil watches have a 2 year warranty so if its inside this, take it to a dealer.
Nov 03, 2014 | Fossil Watches
I want to change out batteries
1. Lay the watch upside down on top of a towel or cloth on a flat workspace. Use a small flat head screwdriver or blade to pry under the watch backing, then lift the backing from the watch. Slide the battery cover to the side to access and remove the battery.
2.Take the battery to any electronics store to purchase a replacement. Bringing the old battery will ensure you install the correct type of battery in your Fossil watch.
3. Replace the battery and the battery cover. Apply pressure to the backing until it "pops" back into the watch.
THANK YOU FOR VISITING FIXYA
Aug 05, 2010 | Fossil Dress - Analog Glitz Red Dial Watch
Fossil ch2360 can not figuare out how to get to the battery
mcdevito75 here, Most Fossil Watches have a press fit back cover. First locate ant tab, or indentation that is on the back cover linning up with the case itself, Carefully use a steak knife under that tab or in the indentation, slot in the cover abd pry up. From there you may need a jewlers screwdriver to loosen the battery hold down plate to remove the battery. BEST BET, look for a small watch repair shop in your area to change the battery.
Jul 31, 2010 | Fossil Watches
I have a fossil watch model fs4255 leather strap dress amber dial and I want to open back to remove old battery and replace with a new. i have a watch repair tool kit and replace all my own watch batteries...
mcdevito75 here, Even with the proper tools we still have to improvise at times, Instead of useing your case opener from your tool kit, use a steak knife or similar with a sharp edge inside that groove you"ve described, the cover will pry off.
Jul 04, 2010 | Fossil Strap Dress Amber Dial FS4255 Watch...
WHAT TOOL DO I NEED TO REMOVE THE BACK OF FOSSIL BLUE #BQ-9232 AND HOW AVAILABLE ARE THE BATTERIES FOR REPLACEMENT?
Most watch backs either screw off with a special case opener that every wachmaker uses or pried off with a knife like case opener or sometimes a knife. Take this to your local watchmaker for battery replacement. Batteries are readily available but are a bit tricky to install properly and are best installed by a qualified watchmaker.
Nov 29, 2009 | Fossil Metal Chronograph White Dial ES1793...
How do I remove the back off a fossill watch to replace the batteries
If it doesn't have the indentations for a tool used to screw off the case back then its a pry off type and you need to use a sharp tool and pry off under the case against the band post
Nov 06, 2009 | Fossil Metal Chronograph White Dial ES1793...
CH2301 battery replacement. How open compartment?
There are 2 ways that Fossil closes the caseback on their watches.  It is either a 'pop-off' caseback that you will need to pry off.  Get something very small and thin, such as a small flathead screwdriver.  There is usually a small groove somewhere around the edge of the caseback where you can insert the blade.  The other type screws off.  You will need to unscrew the caseback.  You can determine if it screws off by looking for 6 notches around the outside edge of the caseback.  You will use these notches to insert a tool to rotate the caseback off.  Without a specialized tool called a watch-wrench, I suggest bringing it to a store such as Precision Time or Tourneau.
Jan 18, 2009 | Fossil CH2331 Wrist Watch
Need to change the battery on my fossil watch but can't seem to remove the back of the watch to do so
good morning ! if your watch is waterfroop design that`s have a tread so if you want to open the case back you need a wrench or opener, but if your watch is snop in design you need a knife to open the case back,and change the battery,thank you,
Aug 27, 2008 | Fossil Watches
Fossil VT2654 Pocketwatch Logo
344 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
