Question about Olevia LT42HVi 42 in. LCD Television
I have the Olevia TV model #237-T12. When I turn on the TV the blue light starts flashing and the TV will not come on. I unplug the set and plug it back in then turn it on and will will start playing. What does the flashing light mean?
I just watched a video about fixing a similar problem. I am going to try it tomorrow after I pick up a couple of capacitors. If he is right, then it will cost me about $5 to fix this darn TV.
Here is the video
Good Luck!
Terry
My website
Posted on Oct 23, 2012
My Olevia tv just showing vertical color lines.
Posted on Dec 30, 2011
  • haziespencer Dec 30, 2011
    My Olevia tv is showing vertical color lines and no picture.
Olevia tv 237-t12-shuts down and needs to be unplugged for some time before it works again
How long does it run before it shuts off, and does the power light in the front go off like its unplugged or does that stay on when it shuts off?
Mar 25, 2017 | Olevia Televison & Video
Olevia TV Model 237-S12 P/N FM1-037000EGS29 S/N
Good day!!!
Usually that problem is appear after the firmware update failure or not completed,..
I need to know if your TV having sounds?
Did already update the firmware?if that so where did you find the firmware?..
Jan 08, 2012 | Olevia Televison & Video
My Olevia 237-s12 TV won't turn on. When we push the power button, the blue power light flashes on/off repeatedly. We have unplugged the TV to reset the system but no change. Is it shot?
Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope this helps in solving the problem.....
May 07, 2011 | Olevia 237T 37 in. LCD TV
Where can I find stand for Olevia 237-t12
Hello; I would try Jimmy's parts dot com. He has tons of stuff. You can also contact Olevia for the part, but it will probably be more expensive. John
Nov 22, 2010 | Olevia 237T 37 in. LCD TV
My olevia 237-t12 won't turn on. The blue power light flashes but can't power it on. Any solutions?
It may abe in the safety shutdown mode due to short circuits in the power supply or in the backlight inverter board.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Sep 07, 2010 | Olevia LT32HVM 32 in. LCD Television
Olevia 237 t12 has hummmmmmmm in the sound
Does the hum go away when you mute or turn down the sound completely? If it does then the issue might be one of the sources connected to it IE: DVD, Cable Box, Satellite receiver..
Nov 17, 2009 | Olevia 237T 37 in. LCD TV
What kind of bulb goes in the olevia 237-t12
LCD TV backlights, which are not user-serviceable, are a special CCFL (cold-cathode fluorrescent lamps) that is a model-specific repair part from the manufacturer. A LCD panel typically has multiple CCFL tubes, and it depends on the size of the screen.
Oct 20, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Firmware update Failed
I had the same problem with my olevia 242-T11. I flashed it with the wrong firmware and the TV would not even turn on. The blue LED light would still light up and my PC would still recognize a connection when i hooked it up to the USB cable connected to the TV.
I was fortunate to download the appropriate software. The software is called MTK_DownLoad1.exe. I know this is the correct software to use for Olevia 242-T11 and Olevia 237T. I do not know if this will work with other models.
Here is the link to the MTK_DownLoad1.exe
http://rapidshare.com/files/17475900...load1.zip.html
You will also need to install the USB to Serial driver before you are able to use the MTK Download Utility. The USB Driver is located at
http://rapidshare.com/files/17475900...river.zip.html
BE SURE ONLY TO UPDATE YOUR TV WITH THE CORRECT SOFTWARE OR YOU WILL BRICK IT. I was lucky enough to recover my TV and finally able to upgrade it to the correct firmware but my TV was non functional for about a week and this has been a huge headache and if i could go back in time i would definitely not do it so please ask yourself if its even worth it risking upgrading the firmware of a TV who parent company is reorganizing after declaring bankruptcy.
If you still want to do this, here are the firmwares for all the various Olevia models.
http://olevia.ftpaccess.cc/support/OLEVIA/
I hope this helps all the people who need to recover / unbrick their Olevia TV's. If the links are down or you need any help please ask for help in avsforums. My id is sammykismail on avsforums and i will try my best to help you.
Jun 23, 2008 | Olevia LT42HVi 42 in. LCD Television
Remote control codes
Go to Best Buy and buy the DirectTV Universal Remote Control ($20 and works with all cable and satellite services) Model RC64. It will control all the functions on the Olevia TV and Satellite box, except the A-B-C-D buttons for the User Guide.
The remote codes are:
RCA Satellite Box - 00392
Olevia 237-T12 - 11610
Enjoy
Nick from Ft. Myers
Feb 08, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Olevia LT42HVi 42 in. LCD Television Logo
996 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
