Question about Hotpoint Dishwashers
Runs through cycles but leaves about a couple of inches on bottom
  • Hotpoint Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Nov 11, 2010
Dishwasher smells
johnnette acree, here are a couple possibilities
1. Look in the bottom of the dishwasher there is a catch basin or cylinder look for large food item that maybe stuck. clean it out.2. Be sure the drain hose is connected with a loop in it that goes up to the top of the cabinet and then back down.3. Run the dish washer empty with soap and heat dry or use sanitize cycle. after cycle completes leave dishwasher open overnight. The smell should be gone in the morning.
Hope this helps
Joe ConnollySealstonetops@gmail.com
Nov 16, 2011 | Frigidaire Dishwashers
Dishwasher won't drain.Leaves several inches of water in bottom of unit after cycle is complete
Check for blockages in the base of the dishwasher under filter etc.
Also make sure the kitchen drain is clear and if you have garbage disposer run it prior to running the dishwasher.
Also need to confirm if the dishwasher pump is actually operating during the drain cycle. If the pump is faulty then it will not drain. Provide full model number of dishwasher if you need further assessment of the problem. Good luck.
Aug 30, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Water is not draining. Several in inches of water in the bottom after running a cycle.
Check the drain hose routing. It must be placed so as to be higher than the drain into which it empties. Also check the filters in the bottom of the unit, around the water tower. They can become plugged with food and other debris and not let the water to drain out as it should. If it seems to be leaving food and such on the plates and silverware, after the wash cycle, it's possible the drain prop has lost one or more of it's fins, or has become loose on the drive shaft.
Jul 03, 2011 | Dishwashers
About one minute after starting machine (Whirlpool Duet WFW9600T01) the machine flashes "SUDS" for a couple minute or so, then the machine locks up with the F35 code. The only way to open the...
this is a suds lock and a very nightmare of a call....... are you using high effeciency soap and do you ever run a clean cycle ....... i prefer an affresh cleaning tablet once a month...... first things first need to drain all water out of washer threw drain hose connected to drain pump .... then check for any float obstructions at bottom of outer tub to drain pump large 4 inch ruber hose at bottom of tub with a plastic ball in it make sure there isnt any lint causing float ball not to seal in pump vacum... then reinstall and reconnect hoses then check pump filter sump trap for debris and reinstalll next open washer and install an affresh cleaning tablet and select hotest water cycle or clean cycle if washer is equipped with this feature and close door and let washer run ...m if code comes back you make have to repeat draining and pump steps a COUPLE OF TIMES TO REMOVE EXCESS SOAP BUILDUP..,. CAUSIN SUDS ERROR LOCK CODE.....
Jan 24, 2011 | Washing Machines
Seems to run it's cycle but there is a couple inches of water on the bottom after it's finished??
It's most likely not level. This keeps the drain from finishing the cycle. It will not do this if not leveled.
Dec 22, 2010 | Dishwashers
Roper dishwasher washes, seems to run normally, but leaves a couple inches of water in the bottom when done
If the drain is stoped this will happen. Is it a new instalation? If into a disposer did you knock out the plug in the disposer. Check the drain line
Oct 17, 2009 | Roper 24 in. RUD4000M Built-in Dishwasher
Water won't drain after cycle is done. Leaves 1-2 inches of water in bottom. Checked hose and its clear. Put hose going to disposal in bucket and water comes out when diswasher is cycling
it is easy track this path of water from bottom of m/c it will b afilter then small hoses to drain pump thenouter hoses <
thanks
Jul 13, 2009 | Dishwashers
Kenmore 20692 top load washer won't spin. The
This is most likely a motor coupling. Pull washer towards you about two feet tilt back, look at floor for black sute. The coupling is attached to the motor to the transmission. It cost about 15.00 and takes a novice less than an hour. There are two 1/4 inch srews, one on top one on bottom , remove these use a scwrew driver to pop off the clips,pry off coupling on both side and replace.
Mar 12, 2009 | Washing Machines
Dishwasher not draining
jeff you can call customer service at 1-800-626-2001 and they can help but it sounds like your timer is missing the drain cycle
Jan 08, 2009 | GE GLDA690MWW / GLDA690MBB Built-in...
Dishwashers Logo
46 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
