Question about Dishwashers
My Bosch Dishwasher SGS53E72AU has water left in the bottom on the quick programmes, but not on the longer, hotter ones. There is no blockage of the pipes and the pump is working OK. I have to assume that the electronics have dumped some of the programming. Could you confirm that I have to acquire a new timer/electronics package from somewhere? Or is there an easier and cheaper fix? Many thanks. Hope to hear from you soon.
  • 38 Answers
SOURCE: No water filling up in the dishwasher when programme set
your pump needs replacing
Posted on Mar 20, 2007
  • 213 Answers
SOURCE: Bosch dishwasher problem
remove the kick plate below the door. youll see a white tray behind the kick plate. theres water in the tray thats activating a overflow switch. with a towel or 2 remove as much water from tray as possible. this will solve problem
Posted on Nov 20, 2007
textonor
  • 130 Answers
SOURCE: Bosch dishwasher SHU66C02UC
You have water in the base of the machine. There is a flood float in the bottom so if any water gets into the base, it will shut off the water and run the drain pump as long as the power button is on. So shut off the breaker, remove the toe kick, and remove any water that is down there. Now start the machine and see if water is leaking into the base. If there isn't any water, an the dw is still running the drain pump, then with a wooden spoon raise the red plastice stick on the left side of the dishwasher up and down. It is possible that the overfil float is stuck. If this makes the dw start filling, then run cooking oil thru the dishwasher on the scrub cycle to remove excessive detergent. If you are in hard water, then the water deposits have caused this. Run citric acid ( Tang orange drink, Dishwasher Magic, or such) thru the dishwasher to remove this.
Posted on Feb 02, 2008
  • 105 Answers
SOURCE: bosch classixx dishwasher not draining
try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
Posted on Feb 24, 2008
SOURCE: Neff dishwasher continuously attempting to pump out water
I had this problem too, I found a brilliant solution on a website, that worked, just put some towels on the floor and tip the dishwasher towards you, let the water run out and it will work again.............brilliant !!!!!
Posted on May 10, 2008
My Bosch SHU66C02UC dishwasher stopped midcycle with water in the bottom. We checked the fuse and it is fine. I'd rather not pay for a repairman as it is quite expensive.Thank you.
Some suggestions: try pushing the drain/cancel buttons and see if that drains the water; check the filter or trap in the bottom of the dishwasher for blockage; check the hose that links the dishwasher to the under-sink drain pipe for blockage. You could google the model number and find the owners manual, which might have trouble shooting suggestions.
Sep 05, 2017 | Bosch Dishwashers
Bosch SGS6302 Dishwasher failing to complete cycle
Does it heat properly? Was that the cause of the power failure?
Mar 17, 2014 | Bosch Dishwashers
Bosch dishwasher sgs53e72au leaking
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Dec 12, 2010 | Bosch Dishwashers
I need a user's manual for SGS5302 bosch dishwasher. Otherwise would you tell me exactly how the aquastop works? Is there any method to bridge it? What goes on the wires? Signals from or to the...
Please rate this solution if you find it helpful. Thanks!
The Aqua-Stop function is a flood protection feature. You really don't want to be "bridging it"!
It works by using a float switch to detect when the water level gets too high in the wash compartment. It over-rides any wash programme and starts the pump to empty the water out.
Also if water leaks into the bottom of the dishwasher (under the washing compartment) the float will rise with the water level and when it reaches a critical point, it will over-ride any washing programme and run the pump.
However, the pump cannot remove water from under the washing compartment, but as it over-rides the wash programme, it prevents the washer from continuing with any wash cycle, thus preventing any more water from leaking into the bottom of the washer and flooding your house.
For this reason, you should never attempt to "bridge" (whatever that means) modify or disable the aqua-stop feature. If it's been activated, you have a problem which needs to be resolved before you continue to use the washer.
Here is a direct link for downloading your manual from Bosch (free):
http://www.bosch-home.co.uk/quick-links/customer-service/download-product-manuals.html
Oct 16, 2010 | Dishwashers
Bosch shv56c03uc/114 Water is not draining
Check drain hose first.
If you do not find any blockage, then you will need to access the pump, remove pump hose and look for blockage in there.
If there is no blockage at all, then either the water level switch, a faulty pump, a wiring problem, or a faulty timer board can be cause the machine not draining.
Apr 06, 2009 | Bosch 24 in. SHV56C03UC Built-in...
Bosch Running a LONG LONG Time and Watering Remaining
You could try running the machine with the drain hose leading to a large bucket. If it works OK in this situation then the blockage will be most likely where the drain hose joins the house drainage system - often at a junction under the kitchen sink. With the drain hose disconnected you should be able to see the blockage and clear it with a suitable pointy tool.
Let me know if this sorts it. Thanks, D.
Jul 31, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Shu9915uc dishwasher wont drain
it should have water just below filter tray, if it does not actually empty then you have a blockage ,remove left side panel to gain access to drain pipe and side chamber. Regards Engineer
Aug 05, 2007 | Bosch SHU9915UC Dishwasher
Prgramme not starting or finishing
The "mushroom" bottom is just a lever that operate a switch. It seems that a part of the switch's mechanism is broken or release.
Jul 22, 2007 | Bosch 24 in. SGS43C12 Classixx...
Dishwashers Logo
98 people viewed this question
Top Dishwashers Experts
