MY LAPTOP OS CANNOT START BECAUSE WHEN GET INTO THE BIOS SCREEN (MANUFACTURER) , BUT IT STOP THERE AND HOLD. HOW TO SOLVE IT? OT THIS NECESSARY TO UPDATE THE BIOS? AND HOW TO UPDATE IT?
    Guru:
  • 610 Answers
If your computer freezes even during BIOS, It indicate a hardware problem. You might need to get a local technician to check which hardware part is failing.
Posted on Nov 11, 2010
Reset bios settings
restart the computer HOLD the keys CTRL or FN +F2 or F11 or f12 depend of your mark+ or f8 safe mode with network an download the BIOS update +chipset from your manufacturer supplier and repair , model, and go to BIOS setup , or go to restore the factory default.
God bless you
Jul 29, 2013 | LG Computers & Internet
Online pc scan
You could run the chkdsk disk utility
Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your Hard Drive.
or an easier way to run the chkdsk utility
Windows 7 chkdsk
http://www.w7forums.com/use-chkdsk-check-disk-t448.html
Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again.
Optimizers and Diagnostics.
http://download.cnet.com/360Amigo-System-Speedup-Pro/3000-18512_4-75332741.html 5E3422139C19CBED35C14826A44D4605
Improve your PC performance and fix errors.
if the problem is still persisting
Your computer's BIOS screen can be incredibly useful when you need to make certain hardware or system configurations.
How to access the BIOS on your laptop varies from manufacturer to manufacturer and model to model.
Even though Acer laptops are created by the same manufacturer, not all models access BIOS in the same manner.
While accessing the BIOS setup screen in and of itself is not difficult all you need to do is press a key the difficulty is in figuring out which key to hit.
Restart or power on the laptop.
Hit the "Pause/Break" key the moment the Acer boot screen (not the OS start-up screen) appears.
If the OS start-up screen appears before you can hit Pause/Break, you will need to restart the laptop.
Press "F2" or "Del" to access the BIOS set-up screen.
Depending on the age of your Acer laptop, you may need to instead press "Ctrl," "Alt" and "Esc" simultaneously to access BIOS.
Using the arrow keys navigate failsafe or optimized defaults press F10 to safe to cmos and exit to restart.
Jul 15, 2013 | Acer Aspire Computers & Internet
Code error 0xc0000185
Follow these steps
First you should Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including BSODs.
- Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in safe mode then update your graphic drivers from the manufacturer site of your laptop
Let me know if it helps you.
Use system utility tool like RegInOut to remove unwanted files , fix registry and windows errors which causing blue screen
Jul 03, 2013 | Sony VAIO Computers & Internet
Screen say resuming windows
Try to start your laptop in safe mode
if you able to start in safe mode then Update drivers for your hardware from the site of your laptop manufacturer(in the support section) .Most black screen are hardware or driver related so updated drivers could fix the cause of the STOP error.
-Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues,
-If this didn't help you then simply get the Intel software partner Reginout to fix all the errors which black screen
Jun 17, 2013 | HP Computers & Internet
Reset bios 4052lci cmos 2310
May 06, 2013 | Acer TravelMate 5760 156 500GB 4G...
I have an aspire one netbook windows 7 has stopped working after error msg i am left with a black screen and white curser, i know i need to reinstall os so I have bought an external unit to do this but all...
to solve your black screen with just cursor
1. disconnect all (external) devices on your netbook 2. remove battery and adapter then press and hold the power button to drain flea power for about a minute 3. put the battery and adapter back in. 4. power on (as soon as you hit power button tap "F8" key) 5. advance boot options>safe mode (after loading still black screen and just cursor: press alt + ctrl + del then access task manager - new task > run > explorer.exe (should bring up your desktop) 6. access system restore under start > accessories > system tools > system restore 7. restore to an earlier time
to solve your re-installation of OS
1. boot to bios by pressing "F2" or "Del" (depending on your manufacturer) 2. once in bios look for restore defaults 3. save and exit 4. boot options under "F12" highlight media drive press enter and continue pressing enter until you see windows loading screen
Mar 23, 2011 | Computers & Internet
I have a Fujitsu-siemens lifebook E-7010 laptop. The screen is not lighting up when i switch on the machine. The laptop hums normaly. the green light comes on, but the screen is not lighting up. Please...
You will remove the battery and unplug the dc adapter.After complete those hold down the power switch for 30 seconds.
Now install the battery and plug the dc adapter to laptop again and hold down the power button.I Nhope your problem will solve.
Dec 24, 2010 | Computers & Internet
Black screen: acer aspire one laptop starts with error to run with in safe mode, safe with network, or safe with command or to run normally...once i choose an option and press enter, it appears to load...
Looks like your OS on the hard drive has crashed. Therefore the bios has no bootable file to start your session. You can pull the hard drive out dongle it off another pc pull ur pictures, music, and data files off. Then reload the operating system on fresh. If you can not load a fresh copy because you get stop errors then your hard drive is bad you would need replace it.
Sep 17, 2010 | Computers & Internet
Computer shutsdown and restarts automatically
solution your problem
First you change powersupply if restrat problem is not solve then cheque RAM if restrat problem is not solve then cheque BIOS Battry And clear the BIOS & Go to BIOS load default setting Bios if restrat problem is not solve then install os if restrat problem is not solve then cheque mother board and restore the OS ok now will solve your problem
Yours
Pradip Sisodiya
Jun 08, 2008 | Computers & Internet
Problem of starting the Window XP
Hi can you disconnect the hdd or to make it simpler disable the hdd in cmos configuration and boot the PC , if you still see the same web address on your screen as you have mentioned then you have to program your PC Bios otherwise it is not necessary to Update the Bios but it is indeed very much necessary to clean HDD and reinstall the OS.
May 13, 2008 | ASUS P4S8X-MX Motherboard
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
