Will not spin, but do hear motor running - Washing Machines
  • Washing Mach... Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Nov 11, 2010
Drum barely spinning, maybe the belt is worn?
Is it just the spin cycle or all the way through?
Could be worn or loose or both. Does it spin without a load in the manchine. Do you hear the motor running at a higher pitch than normal (means it's running without any load to it) or does it sound the same? Worse senario, If the motor is an "Indution Motor" then a coil may have gone o/c. If it is a brush motor (if you hear sparking)could need new brushes
Oct 01, 2014 | Washing Machines
My dryer will not spin
If you can hear the motor running but the drum is not spinning then you probably have a broken belt. If the motor is not running could be anything from a bad door switch to a bad motor. Hope this helps
Aug 30, 2011 | Whirlpool Dryers
AGITATOR WILL NOT SPIN, WATER WILL DRAIN BUT NO SPIN
Does your motor sound like it is running in the agitate or spin cycle or is it quite? If the motor makes no sound, then you need to replace the lid switch with this part.
If you hear the motor running in the agitate or spin cycle but you don't see any action, then replace the motor coupler with this part.
Dec 25, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a frigidaire washer model fws777ghs0.after the spin cycle the water is drained but the clothes are too wet.there is a smell of burning rubber.when I open the lid I could see a slight smoke.could it...
probably burned up your motor coupling! see if you can hear the motor running either on the agitate or spin cycle,if you hear the motor running but no movement then it's gonna be the motor coupling it's plastic and rubber! cost about $20
Jan 11, 2010 | Washing Machines
Drains but will not spin. I can hear the motor
The machines spin motor winding may be short circuited kindly replace the motor
Dec 23, 2009 | Frigidaire Affinity ATF7000E Front Load...
Belt borken. Should I hear the motor spinning
Good day,
Yes the motor will run with or without the belt. The blower discharging air out of the back of will still work,
as well.
Dec 21, 2009 | Kenmore 62602 Electric Dryer
Won't spin anymore. Comes on, but barrell won't spin. dead motor?
Do you hear the motor running? It may just be a broken belt. If it is in fact the motor it can be replaced.
May 28, 2009 | Kenmore Dryers
GE washer wssr2070v1 will not spin.
If you hear the motor running but nothing is happening then check the belt on the bottom of the machine and the brake to make sure that the belt is not broken or stretched and also that the brake is not holding the drum
May 23, 2009 | General Electric WBSR3000G Top Load Washer
Drain pump starts and stops prior to final spin cycle
Jayron, is the motor jogging? start to spin, stop, start to spin stop. If so, your motor is jogging between the high and low start windings. The motor during spin should start on the high speed windings and stay there until most of the water is drained. GE came out with a new motor, harness and run cap because of this. If you have a meter, there should be a white and white/red wire going to the motor. If you have a steady 120V and it's doing this jogging, replace the motor with the kit...Let me know if this the issue, Catriver..post back.
Nov 05, 2006 | GE WWSE5200B Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
