Question about Bosch Classixx KGV28323 Bottom Freezer Refrigerator
Freezer not working
The freezer should be frost free.
The freezer will frost up and block the vent so that the cold air cannot be blown into the fridge to cool the fridge.
There is no lights on to show the temperture of the freezer.
Same problem but electronic temperture on in fridge but keeps flashing
Posted on Jul 20, 2008
My whole bottom freezer is frosted over what should i do
When a (frost-free) freezer is frosted, it is either not closing/closed properly - allowing (outside) air to get in ... or, there is a "leak" (in the freezer) allowing (moist) air to get into that chamber, and/or, the "fan" (system) that circulates/removes (moist) air from the freezer is not working properly or the "vents" are blocked.
Check the freezer door "closing" possibility first ... and if it's not the case, (get a technician/repair person to) check out the freezer circulation system.
Jul 16, 2014 | Maytag Refrigerators
Top shelves in freezer not freezing food. Also no ice from ice maker. Seems cold air has stopped coming out of top vent
We had the same problem with our refrigerator just yesterday. Defrosting (even tho frost-free) cleared up the airflow problem-- If it's frost-free, when it defrosts enough to allow air flow, the automatic defrost can take over. Cause was stored food blocking the vent between the freezer and lower part of fridge.
Mar 02, 2013 | Freezers
I have a kitchenaid, KSRS25RSMS01, refrigerator and the freezer is fine and the fridge is not cooling. I have checked the evaporator and it has normal frost, and the fan is turning fine, but the air coming...
Your frig has the classic symptoms of a frig with a clogged or blocked vent between the
freezer section and the refrigerated section. This clog can occur due to (a) stuff in the freezer blocking the vent, or (b) ice in the freezer blocking the vent, or (c) both of the above.
The way a refrigerator works is it cools the freezer, and the warmest air in the freezer is vented out
to the refrigerator section. If this vent is blocked (and everything else is working), your refrigerator
just became a eye-level small freezer atop a well-insulated section of dangerously warm food.
May 13, 2011 | Refrigerators
The freezer works well but the fridge is not cooling.
Classic symptom of: the connection passageway between the freezer and the fridge compartment
has closed off - usually due to ice buildup - or something clogging/blocking the passageway.
Your Refrigerator works by releasing cold air into only the freezer, then this cold air passes thru
a passageway into the fridge compartment to cold (but not freeze) the fridge compartment contents.
If this passageway is blocked, then just the freezer works, and cold air never makes it into the
fridge compartment. In the old days, you'd be told to defrost your freezer, since the blockage
was ALWAYS caused by frost buildup. Today, we have frost-free freezers, and your freezer may
simply have too much stuff inside - there has to be some room to allow some air flow around
items in the freezer, and whichever item is blocking the air passage to the fridge compartment -
just move it away from the passageway opening.
Mar 15, 2011 | Westinghouse Refrigerators
Fridge/freezer. Freezer works great but fridge is
Air from the freezer is blown into the fridge by a fan, some new type frigs have electronic controls that open and close a vent to frig. the older ones have two vents in the frig from the freezer and when covered with frost or ice the air will not reach the frig. check for ice or just defrost the freezer if there is ice or frost, also check for food or plastic over vents in freezer. Also check that the freezer fan is running as these sometimes become blocked or defective motor.
Mar 07, 2010 | Electrolux Freezers
Freezer cold, fridge isnt. Vent issue. Please Help before thaw!
Is there any ice/snow whatsoever built-up on the rear panel of the freezer ????(very important to know this).
If so, you have a problem with the frost free part of your fridge,causing it to ice-up,
and blocking the air flow to the fridge section.
Repost, and we should be able to go from there.
Wigo.
Mar 04, 2010 | KitchenAid Refrigerators
Refrigerator not working but freezer is
You have two vents between the freezer and fridge. The one the cold air from the freezer comes through(blown by the fan) and the other vent is a return vent back to the freezer. On a side/side they're at the top and bottom. It sounds like the bottom one may be blocked by food or frosted closed by ice.
Aug 22, 2009 | Refrigerators
Refrigerator is barley cold, still makes ice, condensation inside of frostless freezer
Hi: The fact that it still makes ice tells me the freezer is a zero degrees. When you said condensation in the freezer did you mean frost? If your defrost heater fails it will cause the frost free freezer to build up frost. The frost will build up and block the vent that supplies the cold air to the fresh food. The defrost heater is behind the metal wall at the back of the freezer, at the very bottom. A glass tube with a metal coil in it. The coil can break and stop the defrosting. Replace that. Use a hair dryer to melt the frost from behind the panel. All of it top to bottom. You need to remove all the frost to free up the airways. I hope this helps, Jeff
Jun 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Frost Free, freezer ok but fridge warm
If all else fails I would completely defrosted the unit.If there is any blockage this will open up all the tubes.Unplug it open the doors put pans of hot water in the freezer to speed up the process.
Make sure your fan is still working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refridgerater may be blocked.With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open 12 to 24 hrs this will free up any clogged tubes. Good luck.
Len West
Feb 16, 2009 | Westinghouse Refrigerators
Frost free fridge/freezer - not cold in fridge
The most common problem with refrigerators not cooling when the freezer cooling is the fan which supplies cold air to the freezer. Not easy to get to in most cases. Another problem is the vent to the fridge part is blocked or not operating with the adjustment control.
Nov 27, 2008 | Freezers
Bosch Classixx KGV28323 Bottom Freezer Refrigerator Logo
830 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
