Question about Weber Grilling
Instuctions to assemble Arana BBQ - Weber Grilling
Need assembly instructions for a jackaroo flinders 4 burner bbq
It is a discontinued product so you are probably going to have to just lay all the parts out and guess. You could also look for assembly instructions for a similar BBQ made by Weber. They all follow a logical sequence.
I did find reviews, you could ask if anyone has the manual and when you ask a question, the question is sent to those who have reviewed already.
Jackeroo Flinders 4 Burner
Dec 28, 2015 | BBQ Guys Grilling
Char Broil Gas BBQ Knobs just spin, no propane coming out.
Just a wild guess but I think on a Char Broil you have to push in the knob and turn it to the setting.
Feb 24, 2013 | Grilling
Can i get parts to convert my capn cook 4 burner bbq grill to lp
The BBQ's Galore grills are the only ones that are approved to be field converted. All you need a 4 LP Gas Burner Orifices and a Hose Regulator Assembly to hook to a LP Gas grill tank. You can buy the orifices from BBQ's Galore and the Hose/Regulator Assembly from any hardware store or home improvement center that sells grills & accessories for about $30.00. Gas grill burner orifices are pretty universal, so any LP Gas ones should work.
Hope this helped you and thanks for choosing FixYa.
Aug 17, 2011 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
Need a manual for a Jumbuck Endeavour 4 MKII BBQ.
Need assembly instructions for a Voyager 4 Jumbuck BBQ, no more than two years old. Our daughter recently moved, the BBQ was dismantled by the removalists and she is now unable to find the assembly manual.
Many thanks
Rod Gilbert - rod.gilbert@hotmail.com
Apr 20, 2010 | Grilling
New BBQ chaged from propane to NG
Hello. The conversion of any gas appliance usually requires changing orifices, regulator and burner. Then once those changes are made you can adjust the gas flow. The difference in the orifices is this.
Natural gas orifices are larger than liquid propane orifices simply because the gas pressure for the natural gas is lower.
I would double check to be sure that you have installed the correct orifice. Also, you can adjust the amount of gas by turning the orifice in or out, using that socket.
Please call the uniflame technician directly if you still have a problem 800-762-1142 Joe
Mar 11, 2010 | Uniflame Corporation LP Gas Outdoor...
No assembly instructions to build the bbq
Go here to get manual.
http://www.ducane.com/manuals/
Good Luck and Please Rate FixYa!
Mar 21, 2009 | Ducane Affinity 3100
Chain
It is used to maually light the burner with a match. The match goes in the "loop" part. It is attached so that it isn't lost/
May 12, 2007 | George Foreman GP324 Stainless Steel Grill
Grilling Logo
82 people viewed this question
Top Weber Grilling Experts
paulcarew
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Weber Grilling Expert? Answer questions, earn points and help others
