Question about KDS K717s 17" LCD Monitor
Why does the monitor keep "Adjusting" and how do I
    Problem Solver:
  • 19 Answers
In the setup Menu you probably have the auto adjust enabled.
go into the setup menu and locate the screen adjustments disable the auto adjust and see if that fixes your problem, if it doesnot call the Manufacturer technical rep. and ask them, it might need repair.
good luck...
Posted on Nov 11, 2010
2 Suggested Answers
bradyb109
  • 18 Answers
SOURCE: stop auto adjusting of monitor/screen. the screen
Make sure your resolution is set to the native resolution of the monitor. In this case, 1280x1024
Posted on Mar 01, 2011
How do i stop auto adjusting
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 31, 2014 | Computers & Internet
My monitor keeps opening monitor menu and keeps auto adjusting
As you have already used a cleaner spray, this is a sign that the monitor is on its' way out. I had one that went the same way.
Apr 13, 2013 | Computers & Internet
Stop auto adjusting of monitor/screen. the screen keeps on auto adjusting... how do i stop it?
Mar 01, 2011 | BenQ FP72E 17" LCD Monitor
Benq T52WA LCD MONITOR SMPS OUTPUT VOLTAGES?
Hi
My Benq t52wa wide screen monitor works fine for some time and then its goes off for a few seconds and then comes back in regular intervels. This keeps on happening. Also im unable to get the auto adjusting thing that comes on the screen to go off. IT keeps adjusting.
I checked for the drivers and it says all drivers are up to date. Any suggestions please?
Feb 13, 2011 | BenQ FP553 (White) 15" LCD Monitor
Asus 19inch LCD monitor keeps auto adjusting and turn off after 2secs. . i do reset it . . nothing happens. .it keeps auto adjusting itself repeatedly . . pls help me
The Auto knob maybe mechanically stuck or the internal switch may be defective. Try pressing the Auto switch firmly 10-15 times,If monitor works now the switch is defective and needs replacement. Do rate the solution.
Samir
Feb 07, 2011 | ASUS 19 Inch Sxga 1280X1024, 5MS,...
The "Quick View" keeps popping up and there I
- I have this monitor before and already tried it to another system and it still doing it
- HP w2207 Monitor is known for this issue perhaps checking a stuck button on the monitor could fix the issue because the quick view feature is a built in feature in this monitor.
Nov 25, 2010 | HP w2207 Monitor
Benq monitor keeps auto adjusting over and over. help!!!
The problem may be that the computer video is on a setting that is out of range for the monitor. To quickly test this, boot to the setup screen. If it is ok, that is your problem. If it still keeps auto adjusting, there is probably a bad component in the monitor. If possible, try it on a different computer. If bad, you will most likely find that replacement is less expensive than repair.
Jul 25, 2009 | Computers & Internet
Dell D177FP monitor - think it's the resolution
Are you using Windows Display Properties or the Intel driver to change resolution? Anyway, you might be able to resolve the issue by installing the latest driver here, as it has fixes for several issues in previous versions.
May 09, 2009 | Dell E177FP LCD Monitor
Auto adjust
In case you have connected both the DVI and VGA cables to the back monitor can cause this problem. Try unplugging one of the cables and check if the problem gets resolved
Dec 22, 2007 | Dell E176FP 17" LCD Monitor
KDS K717s 17" LCD Monitor Logo
609 people viewed this question
Top KDS Computers & Internet Experts
RobertFonner
RobertFonner
daibras
Level 1 Expert
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
