Question about Milwaukee Tool Master Heater 70,000 BTU Kerosene Salamander / Torpedo Heater B70ET
Fan runs for a minute but heater will not fire. Glow plug lights up. I changed the kerosene and cleaned the nozzle.
  • Milwaukee Tool Master
  • 43,501 Answers
Here is a tip about troubleshooting Torpedo Heaters
Reddy Heater - Troubleshooting Torpedo Heaters
heatman101
Posted on Nov 11, 2010
Heater would not start this morning It tried for a second and then just would not ignite. it was running fine yesterday
Take the top cover off of the unit. Plug it in and look at the ignitor for a bright glow or spark, depending on your ignition source. This should happen before the fan starts. Once the fan starts you should be able to see fuel spraying out of the spray nozzle. If there is no fuel, check the fuel screen, air output from the pump, air filters on the pump, and the correct air pressure from the pump. The nozzle can also be dirty. Check for air leaks on the pump by spraying soapy water on the pump while the blower fan is running.
Jan 18, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
I have a All-Pro 115,000 btu multi fuel heater. When first plugged in fan runs, fuel sprays out the nozzle but heater won't fire. Any suggestions?
You probably have already checked this but is the ignitor trying to fire or not working at all ? Just curious. Thank you
Dec 17, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
I get fuel flow and the glow plug is lite but it will not fire off. what can i check next?
Make sure blower motor is operating and air filters in
back are clean. Clean the oil nozzle and make sure fuel line is air tight. If you still dont think you are getting fuel. Gently pull fuel line hose off of tank and make sure it isclear.
Feb 14, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater not firing
Take air preassure from an air hose to turn the fan blades to loosen everything up. Time for afull service, like change the vanes in the pump, 3- filters fuel--2 air.
Dec 15, 2009 | Reddy HEATER RH125T 125,000-BTU...
Heater turns off leaving lots of smoke and is hard starting
If this is a kerosene heater,the wick is most likely not adjusted up enough,or the wick is contaminated.The fuel could be contaminated also.Remove the old wick and replace it,and refuel it with clean kerosene,after you pour the old out.
Oct 14, 2009 | Heating & Cooling
Master 110 torpedo heater will not start , kerosene type
Odds are, your air pump is locked up. Remove the cover on the back of the fan motor, remove the pump cover and carefully remove the air pump rotor and blades. If the motor spins freely and will start when plugged in, the pump housing plates probably have a bit of corrosion on them. Lightly clean the pump housing end plates with fine grit sandpaper, wipe clean and re-assemble. Should fix the problem. Does the breaker trip when this happens?
Jan 01, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
30'000 btu spark style will not lite
  1. clean the fuel filter
  2. clean the nozzle
  3. set the air pump pressure.
It should fire off, unless you have developed an air leak, worn nozzle, bad fan, or a motor that is not turning rpm's.
Nov 10, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Heating & Cooling Logo
1,338 people viewed this question
Top Milwaukee Tool Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Milwaukee Tool Heating and Cooling Expert? Answer questions, earn points and help others
