Question about Delfield Undercounter Freezer - 407
We have a Delfield 407 freezer that will freeze when initially plugged in, fan running, gets nicely down to zero. After the unit gets down to temperature, the fan does not kick in again and the unit temperature rises until everything thaws. Unplugging and replugging the unti starts the fan again.
    Top Expert:
  • Delfield Master
  • 9,472 Answers
You will need to replace the temperature assembly on the unit. If you can post the model number, I will be able to direct you to the parts you need. The model number will be something like "18648-BUC".
Regards,Richard
Posted on Dec 03, 2011
  • Lisa Browne
    Lisa Browne Dec 03, 2011
    Model number 407. Is the part number 2194817KT? That's what I was thinking, and what I told the place the church paid to fix it. All they did was recharge the freon. Again, it ran for a few days and failed again. I hate to haul it back to them, and if it is a part I (I repair/rebuild sewing machines} could replace I was hoping I could give it a try.
How can i change a delfield 407-dhl from a freezer into a cooler
Refrigerators and freezers are almost identical except for more controls on a freezer. Just raise the thermostat to the temperature you need. If it won't adjust that high, you will need to replace it.
Dec 02, 2013 | Freezers
Causes freezer compressor freeze up
with such limited information, I can only answer generic. Most of the time it is because the evaporator fan(s) are not running or the evaporator is frozen over. With further info such as model, serial, or more details on behaviors, I could probably helps some further.
Aug 05, 2013 | Delfield Freezers
Can a delfield model 407 using r12 freon be modified with a new compressor to use current refrigerants
yes it can. if the model is a techumseh find the local dealer.
give them the compressor model # and get the new 134a model
equivelant. no oil change . replace the filter drier when you replace it .the refrigerant charge will be about 90% of the original r-12 charge
Nov 08, 2012 | Delfield Freezers
This is a freezer with Danfoss type temp and defrost control, customer complain that unit is tripping braker about once a day , when switching to defrost or from defrost to freeze cycle, controller is...
There is definately a ground fault in this unit. Also according to the service manual this is an "Electronic Defrost Control" similar to an "
Adaptive Defrost Control" which determins the defrost initiation by the amount of run time. You cannot set this yourself.
Dec 08, 2010 | Delfield Freezer 6151XLSR Stainless steel
Delfield mini freezer for restaurant is not freezing. Unit has power and cabinet fan runs but comp tries to kick on then you here a click and it immidietly shuts off before it can really ever start. Hi...
Compressor is locked up. You have an outside chance of getting it to come back if you install a hard start capacitor. When a locked compressor tries to start it gets hot really fast and kicks the power off to prevent wires from overheating. You can get a hard start kit from wwgrainger or refrigeration supply company. Many times they won't sell direct to the end user. The hard start kit gives it an extra boost when it tries to start. Most times this won't work. Usually the compressor has to be replaced because it is burned out internally. The hard start kit is less than $20.00, so its worth a shot.
Sep 21, 2010 | Delfield Freezers
Delfield MD # 6151 - S Sr # 206156-T not pulling down to Temp set at -10 and only pulling down to 24 freon is good
Take the top cover off that is next to the compressor,. That cover is about 30 by 30 inches. You will see two fans and an evaporator coil. Several things can happen. First these fans won't come on until the coil is somewhere around 10 degrees or if the door is open. So, once the freezer has been running look under the big cover and be sure both fans are running. If one or both are not running it won't pull down to 0. Also look at the coils and see how much frost has accumulated. If your defrost timer is not working it may be frozen over. When that happens air is blocked from reaching the inside of the freezer. While you are at it, fell of the coils if they are only partially freezing, you may be low on freon. If you have gauges to check the freon charge, check both the high side and the low side pressures. If the high side is less than 200 psi, you have some freon, but maybe not enough. If the high side pressure is 300 psi, you have something blocking the freon from returning to the compressor. Usually a blocked cap tube or a malfuncting expansion valve. Finally check the condenser coils which is the radiator thing out where the compressor is located. If it clogged with dust and grease, it will not dissapate the heat from the freon and will intefere with the operation of the entire unit. Clogged condener coils are probably the number one cause of burned out compressors. Good luck.
Sep 17, 2010 | Delfield 113.28 cu. ft. Commercial Freezer...
Need run pressures
You have to give more info. What refrigerant, where is the unit located so ambient temps can be considered, is there a cap tube or txv.
http://www.delfield.com/docs/uploaded/del/manuals/DM6000XL.pdf
Try this web site from Delfield. It should be you manual. It says your unit has 404-A. Check it out and let me know if you need more info.
Dec 16, 2009 | Delfield Freezer 6125XL-S
How do I adjust the defrost system?
http://www.delfield.com/docs/uploaded/del/manuals/archive/dm6000.pdf
this is the site with a manual for the 6151S unit.
here is another manual for the XL-S unit.
Hope this gets you what you are looking for
Jul 30, 2009 | Delfield Freezer 6151XLSR Stainless steel
Delfied Freezer6000XL freezing temps are not hold
Sounds like a refrigerant restriction in the system. Recover the refrigerant, replace the filter drier and pull a deep vacuum on the system before recgarging.
Mar 21, 2009 | Delfield Freezer 6151XLSR Stainless steel
I worked on an old delfield freezer hat had r12 in it and the condensor fan and compressor would turn on when I plugged it in but the evaporator fan motor would not come on. I ran 120 vac to it and it ran,...
some older models ran power throughthe door/ light switches, for the evaporator fan, or perhaps even ewired through the defrost thermostat( reason for that is if evap is warm no need to run a fan and circulate hot air through the cabinet did you try letting run for a while mighttake 20-30 min to get cold enough to trip the defrost thermo.I usuallly hit it with a shot of the freon just ot freeze it shut real quick
Apr 02, 2008 | Refrigerators
Delfield Undercounter Freezer - 407 Logo
152 people viewed this question
Top Delfield Refrigerators Experts
Dennis Boxerman
Marvin
Marvin
Are you a Delfield Refrigerator Expert? Answer questions, earn points and help others
