Question about Imation Apollo (27223) 250 GB USB Hard Drive
JPG, MP3 and folders no longer accessible. I cannot see them nor use them. When running an undelete file program finds them (about 10000 files) but when recovering them it get stuck and does not finishes its task. It does recover some unusable files though. When trying to run a check (by the way I am running Vista Home Premium 32 bits) from the drive property window I get a message saying it cannot check now because the drive is in use and suggestss to schedulle it for later. But I have nothing active that is using that drive. I have had this imation Apollo 25 PHDD for about a year and never had a problem. Another bit of info, it is running in FAT and not in NTFS. What can I do to recover my files and re-gain use of (what I thought) my backup drive? Thankfully, Icaro
  • Icaro Rosson Nov 11, 2010
    Thanks JEFFXC for your reply.
    I use a laptop running vista and the laptop's HDD runs in NTFS, it is just this external HDD (Apollo 25 PHDD 250GB) that runs in FAT. At this stage I scare to convert it to NTFS as I could never recover my files.
  • 37 Answers
NOT PERTAINING TO YOUR PROBLEM, OR POSSIBLY, RUN VISTA USING NTFS.
Posted on Nov 11, 2010
  • 1 more comment
  • JEFFXC Nov 11, 2010
    OPEN MY COMPUTER RUN IT IN NTFS RIGHT CLICK THE DRIVE , FORMAT, NTFS HOPE THIS HELPS. DO YOU HAVE ANY SOFTWARE THAT RUNS THE DRIVE?
    Thanks Jeffxc, I'll do that, but before though, could you tell me if by changing my drive to NTFS would I loose the ability to recover my lost files?
    TO TELL THE TRUTH NOT SURE BUT I WILL TELL YOU THAT A FLASH STICK (EXTERNAL) DEVICE WILL NOT WORK PROPERLY USING F.A.T. I HAVE VISTA H/P 32 ALSO I RUN EVERYTHING IN N.T.F.S. GOOGLE IT SEE FOR YOURSELF. TYPE NTFS VS FAT AND SEARCH IT HOPE THIS WILL HELP
Cannot see music folder on Mac OS 10.6.6....Fuse veriefies connectivity,goes into "connected" mode then Fuse icon appears,Access to Fuse folders are good. but no content from any of the folders...
moz-screenshot.pngmoz-screenshot-1.pngYou can use a free tool called Win Utilities Free Undelete. This allows you to recover files and folders from any physical storage device. It must support NTFS, FAT (FAT32 and FAT16) volumes. This free tool also allows you to recover files from your hard drive or USB.
First you install the program
Open and click on the privacy and security tab
To your right , you will see a tab at the bottom called "File undelete"
Click on it.
Then you must choose which drive, you want to recover your files from.
Choose drive c:
It will scan your computer for all of the files you have deleted.
When scan is finished, choose which files you want to recover.
The click at the top where it says options.
Then choose the options, you prefer to have.
always restart your computer, after major changes to your computer, to ensure your changes are safely stored!
That's it!!1.
I hope this works out for you!!!
Jan 17, 2011 | SanDisk Sansa Fuse MP3 Player
Tip
Delete An "undeletable" File!
<p><b><u><span>Delete An "undeletable" File</SPAN></U></B><br> <p><b><span> </SPAN></B><br> <p><span>Open a Command Prompt window and leave it open.</SPAN><br> <p><span>Close all open programs.</SPAN><br> <p><span>Click Start, Run and enter TASKMGR.EXE</SPAN><br> <p><span>Go to the Processes tab and End Process on Explorer.exe.</SPAN><br> <p><span>Leave Task Manager open.</SPAN><br> <p><span>Go back to the Command Prompt window and change to the directory the AVI (or other undeletable file) is located in.</SPAN><br> <p><span>At the command prompt type DEL &lt;filename&gt; where &lt;filename&gt; is the file you wish to delete.</SPAN><br> <p><span>Go back to Task Manager, click File, New Task and enter EXPLORER.EXE to restart the GUI shell.</SPAN><br> <p><span>Close Task Manager.</SPAN><br> <p><span>Or you can try this</SPAN><br> <p><span>Open Notepad.exe</SPAN><br> <p><span>Click File&gt;Save As..&gt;</SPAN><br> <p><span>locate the folder where ur undeletable file is</SPAN><br> <p><span>Choose 'All files' from the file type box</SPAN><br> <p><span>click once on the file u wanna delete so its name appears in the 'filename' box</SPAN><br> <p><span>put a " at the start and end of the filename</SPAN><br> <p><span>(the filename should have the extension of the undeletable file so it will overwrite it)</SPAN><br> <p><span>click save,</SPAN><br> <p><span>It should ask u to overwrite the existing file, choose yes and u can delete it as normal</SPAN><br> <p><span>Here's a manual way of doing it. I'll take this off once you put into your first post zain.</SPAN><br> <p><span>1. Start</SPAN><br> <p><span>2. Run</SPAN><br> <p><span>3. Type: command</SPAN><br> <p><span>4. To move into a directory type: cd c:\*** (The stars stand for your folder)</SPAN><br> <p><span>5. If you cannot access the folder because it has spaces for example Program Files or Kazaa Lite folder you have to do the following. instead of typing in the full folder name only take the first 6 letters then put a ~ and then 1 without spaces. Example: cd c:\progra~1\kazaal~1</SPAN><br> <p><span>6. Once your in the folder the non-deletable file it in type in dir - a list will come up with everything inside.</SPAN><br> <p><SPAN style="FONT-FAMILY: 'Tahoma','sans-serif'; FONT-SIZE: 10pt
on Dec 10, 2010 | Computers & Internet
Tip
Delete An undeletable File
At the command prompt type DEL <filename> where <filename> is the file you wish to delete.
Close Task Manager.
Or you can try this
Open Notepad.exe
Click File>Save As..>
click save,
1. Start
2. Run
3. Type: command
4. To move into a directory type: cd c:*** (The stars stand for your folder)
5. If you cannot access the folder because it has spaces for example Program Files or Kazaa Lite folder you have to do the following. instead of typing in the full folder name only take the first 6 letters then put a ~ and then 1 without spaces. Example: cd c:progra~1kazaal~1
7. Now to delete the file type in del ***.bmp, txt, jpg, avi, etc... And if the file name has spaces you would use the special 1st 6 letters followed by a ~ and a 1 rule. Example: if your file name was bad file.bmp you would type once in the specific folder thorugh command, del badfil~1.bmp and your file should be gone. Make sure to type in the correct extension.
on Oct 09, 2010 | Computers & Internet
File deletion problem from Garmin c550
If your undelete program lets you undelete the _P3 folder, do it. Then try renaming it to MP3. See if this helps. This is the folder in which all of your music is stored. If it allows you to change the folder name, you should now see (and be able to delete) all of your music files stored on the GPS.
Sep 24, 2009 | Garmin StreetPilot c550 GPS Receiver
How do I UNDELETE a voice recording I deleted on my sansa e250?
sorry. but i'm pretty sure you can't undelete something. Be careful about what you delete next time
Feb 26, 2009 | SanDisk Sansa e250 MP3 Player
Tip
Delete an undeletable file...
Delete an "undeletable" File.
Close Task Manager.
Or you can try this:
Open Notepad.exe
Click File>Save As..> locate the folder where your undeletable file is Choose 'All files' from the type box
Click once on the file you wanna delete so it's name appears in the 'filename' box.
put a "at the start and end of the filename (the filename should have the extension of the undeletable file to is will overwrite it)
click save,
It should as you to overwrite the existing file, choose yes and you can delete it as normal.
1. Start
2. Run
3. Type: command
on Feb 11, 2010 | Computers & Internet
Tip
Delete an undeletable File
Open a command Prompt window and leave it open.
close all open programs.
click Start, Run and enter TASKMGR. EXE
Go to the Processes tab and End Process on Explorer. exe.
Go back to the command Prompt window and change to the
directory the AVI ( or other undeletable file) is located
in.
Go back to Task Manager. click File, New Task and enter
close Task Manager.
or you can try this
Open NOtepad.exe
click File>Save as..>
choose "All files" from the file type box
in the "filename" box
pur a " at the start and end of the filename
click save,
1. Start
2. Run
3. Type: command
5. If you cannot access the folder because it has to do the following. instead of typing in the full folder name only take the first 6 letters then put a ~ and then 1 without spaces.
7. Now to delete the file type in del ***.bmp, txt,jpg,avi,etc... And if the file name has spaces ypu would use the specific folder throgh command, del badfil~1.bmp and your file should be gone. Make sure the type in the correct extension.
on Jan 31, 2010 | Computers & Internet
Lost my photos
Download a program called FreeUndelete from here and install it but before you open it, connect your MP3 player or insert your SD card. After you start the program up, select the drive letter that represents the memory you want to scan for deleted files. Click the scan button above the list and wait. If there's too many results, then look near the bottom of the window. There should be a "Filter found files" line where you can enter in the file type of the photos you lost. It probably should be this: "*.jpg" Once you have found the files you want to recover, create a folder you want to save them to in your My Documents folder and copy the path to that folder by right clicking on it then clicking properties. The path you need to copy is the line called Location (don't actually copy "Location: ". Just what's after it :p ) Now paste it in the line called "Undelete selected file(s) To" under the "Filter found files" line. Make sure you paste over the existing text. Finally, click the Undelete button to the right and Voila! check the files out in the folder you created in your My Documents folder.
Jul 04, 2008 | Panasonic SV-MP510 MP3 Player
Mp3 player
you can try free program called glary utilities. It can undelete files (Privacy&Security --> File Undelete --> select drive where you deleted files, with a litle luck there are your files )
Dec 10, 2007 | Coby MPC-848 MP3 Player
Tip
Close Task Manager.
Or you can try this
Open Notepad.exe
click save,
1. Start
2. Run
3. Type: command
on Dec 02, 2009 | Computers & Internet
Imation Apollo (27223) 250 GB USB Hard Drive Logo
198 people viewed this question
Top Imation Computers & Internet Experts
Raj Patel
carey w mason
carey w mason
Jax Planet
Jax Planet
Are you an Imation Computer and Internet Expert? Answer questions, earn points and help others
