Question about Samsung Televison & Video
It takes ages for the tv to turn on -makes a clicking noise and takes approx. 20 m-30 mins to show any picture.
  • 11,361 Answers
That is a sign of dying power supply, you should inspect the power supply for caps with leaking/bulging tops first.
Please read my guide before trying DIY repair.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Nov 11, 2010
Testimonial: "Thanks so much-will get a proper technician to fix it:)Thanks again for your help."
WhenI turn on my Samsung LE46N8 there is a clicking noise for approx 20secs. before the picture comes up. Once started there are shadows obscuring the picture which last for approx 10 - 15 mins then once...
You likely have a power supply problem. If you can take the back off of the set and trace the AC cord to the power supply look for bulged capacitors on the board. Capacitors are cylinder shaped components standing upright and the bad one will have a bulge or domed at their top instead of flat. If you see any this way you could replace them by soldering in some with equal value of microfarads and voltage or match the part number on ebay (Model search on ebay) and replace the whole module if you can't solder. The module unscrews and unplugs.
May 20, 2011 | Samsung LN-S4692D 46 in. LCD HDTV
Sony Wega TV
The picture tube may be showing its age this is common if the tv is up there in age with a lot of hours on it. you might.also check the voltage available at the outlet as that could cause a problem.Make sure heavy power users such as refridge, microwave etc are not on the same circuit.It should be very close to 115 volts (use a digital meter )
Good luck
Rich
Jun 06, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
DVD player in 1913-TDXB makes noise and won't allow TV to operate. First the DVD player quit working and now it makes a clicking noise when the set is turned on and set won't go past the DVD. Can the DVD...
Take the tv aparts,take some Q tips with some rubbing alcahol clean the DVD laser eye.Should help the DVD player side to work,than the tv might go in to the functional modes.
Apr 14, 2010 | Televison & Video
After tv is on for approx 20-30 mins it starts to make a loud high pitched squeal or whine. once turned off for approx 10-15 mins can turn it back on for another 20-30 mins before squeal will return....
Sounds like a problem I had with a Polaroid t.v. Take the cover off the back and look for capactors that are buldging on the top. The top should be slightly concave. If they are convex at all, you can buy new one at Radio Shack and replace them for under $5.00
Apr 10, 2010 | Emerson EWF2004 20" TV
KP53S35 when tv turned on picture was
You TV has a bad CRT, a red CRT by the sounds of it. This TV is rather old, perhaps 11-13 years of age? Your TV has given you many years of service and I do applaud you for the care you have given it and the TV for it’s reliable in your home. The trouble you face with a rear projection CRT set of this age is that you can’t just change 1 CRT tube and expect it to be reliable and produce a good picture. All 3 tubes should be replaced, as they have all aged the same. The lives of these tubes are only about 7 years. A tube is not any easy or inexpensive repair on any RPJ TV. When you are faced with the cost of 3 tubes, which may not even be available in the market place… You should consider retiring this old friend and keep the manufacture in mind as you make a new purchase.
Mar 14, 2010 | Televison & Video
Tv takes forever to turn on sharp television LC-32SB23U
This problems very common with sharp tv.The Main Turner Signal board have problems.Keep using it,when it stop and completely dead 20-30 on-off no backlight show up and picture.U know ur Tuner board signal board is dead, have to replaced it.
Jan 06, 2010 | Sharp LC-32SB23U 32 in. LCD TV
KV-32FS120 makes a loud noise and green tint when turned on
Loud noise is possibly made by Degausing Coil to demagnetize picture tube and its normal.
Green tint shows picture tube is bit weak in electron emission due to its age and takes time to present good white balance result (good colors)
Sep 11, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Problems with my sony kv32fx20u tv
sony kv36xbr400 wega I have a 5inch black line across top and bottom & gray side to side making a smaller picture.
Nov 16, 2007 | Televison & Video
RCA P52753AT tv will not turn on
the High Voltage splitter needs to be replaced
Oct 06, 2007 | RCA P52939 52" Rear Projection Television
Hitachi 43FWX20B picture problem
yea take the set to a tech reprogram.or take out the plug and plug it in after 30 min.if the problem does not go.do as i say.good luck.
Apr 04, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Televison & Video Logo
401 people viewed this question
Jerry Greenberg
Jerry Greenberg
