Question about Insignia IS-LCDTV32 32 in. Television
The screen blinks constantly. I have checked all connections and they are tight but continues to blink.
  • Insignia Master
  • 8,457 Answers
The tv power light LED indication flashes?The tv power supply board is dead.That board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Nov 11, 2010
    Genius:
  • 1,112 Answers
Hi:
You have a fault either on the power supply or inverter board.. Check all caps on the PS and inverter for swollen capacitor tops.
Vizio xvt472sv screen flickers after a few minutes of use. I have reset and disabled all of dimming functions. capacitors looks all good. There is a constant blinking red light on its inverter board.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Jul 29, 2016 | Vizio Televison & Video
How to fix a LT55265 Mitsubushi LED Flat Panel TV that has a constant blinking green light?
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Jan 15, 2016 | Televison & Video
I have a Sharp 70" (LC-70LE632U) LED TV. When you turn it on, the front led is on, but no screen. After a few seconds, the front led starts 5 short and 2 longer blink and continue this way constantly.
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location
Nov 12, 2015 | Sharp Aquos LC-70LE632U 70 Inch 1080p...
Continuous blinking
MY LG LSD TV SCREEN IMAGE IS CONTINUALLY BLINKING AND A GREEN VERTICAL LINE ABOUT 3 IN SHOWS CONSTANTLY IN THE SCREEN
Jan 08, 2014 | Maxtor OneTouch III 300 GB Hard Drive
My sony trinitron will NOT turn ON, and blinking standby light is constantly blinking... what is the common problem with this?
If you let us know how many times the light blinks, that will let us know whereabouts the fault area lies. Her is the list. I hope it is helpfull.
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Jan 19, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
When I turn on My RCA L40fhd41 40" television, the LCD screen constantly blinks on and off like a strobe light. The power light stays on constantly, but the screen continues to blink
Dec 12, 2010 | RCA L40FHD41 40. in HDTV
Two Red lights blinking constantly. unable to
Epson -R 230 desktop printer. Two Red lights blinking constantly on the control panel (beside main switch). unable to print.
Oct 24, 2009 | Epson STYLUS R230 InkJet Photo Printer
Light constantly blinks
One or both print head are defective.Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
Oct 20, 2009 | HP DeskJet 3520 InkJet Printer
Constantly Blinking WAN light
the wan should always be blinking
if your computer screen is blinking there is something wrong with the screen
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 20, 2009 | D-Link AirPlus DI-524 Wireless Router
Compaq presario dvd writer light blinking, dvd not working
check if power jack working right. Try to change it with other jack. Sometimes the pins inside jack are loose. try to tight them.
May 12, 2008 | HP Compaq Presario SR1300NX (PP195AA) PC...
Insignia IS-LCDTV32 32 in. Television Logo
135 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
