Question about Iomega Prestige 1 TB USB 20 Hard Drive
Hi. The computer doesnt recognize the usb, and on my mac it says imoega takes too much battery so the usb has been deactivated. What to do? Stefanie
    Brigadier General:
  • 10,406 Answers
Connect your computer to its AC power-adapter, to provide more power to your computer, and thus to activate the USB ports. You may need to restart, to enable the USB port(s).
Posted on Nov 11, 2010
My ipod doesnt want to read in my computer as soon as i dowloaded itunes. I'm running windows operating system but I didn't seem to have problems until now. I can't access the usb driver. My...
Try restarting the iPod and connect it again. If it doesn't recognize it try it on another PC, if it still isn't detected it is the iPod. Buying a Mac wouldn't help nor hurt the situation, it would just be an expenditure.
May 23, 2011 | Computers & Internet
My mouse doesn't work with my mac for some reason. I tried new batteries and i tried putting it on my friend's mac and it worked and i tried switching the USB hub and still it doesnt work. it was working...
Try bypassing the USB hub and plugging the receiver directly into a USB port on the computer. Sometimes devices won't recognize properly if they're going through a hub.
Nov 25, 2010 | Logitech Cordless TrackMan Optical...
Failure in the camera's USB ports
Finally I solved it!!!!
Situation: My Computer (MAC And PC) wasn't recognizing the FLIP ULTRA HD, because it has a corrupted file, but couldn't format because there was no communication between camera and computer
Solution:
1. Charge your batteries until get the FULLY CHARGED icon (Green Battery)
2. then remove the batteries without unplugging the USB 3. Voila...computer recognize the USB
4. Format the Camcorder with the Following tutorial: http://www6.nohold.net/CiscoFlip/ukp.aspx?vw=1&docid=763c871b45fc4b20b5a671b24c909
20e_Reformatting_and_Reinstalling_FlipShare_
on_a_Flip_Camcorder.xml&pid=4&respid=0&sni
d=2&dispid=0&cpage=search
5. Install software in camera...
6. CONTINUE VIDEO CLIPPING!
Jun 28, 2010 | Flip Video Flip Ultra Camcorder
My computer does not recognize my flip cam anymore when I insert the usb.. it used to work fine now the software does not open..
Solution:
Feb 18, 2010 | Pure Digital Flip Video Camcorder
My EasyCAP doesnt work!~
hi there,
if your usb port is not recognized by your computer anything you want to install in your usb will not function,try to check your usb on device maneger and updated your driver through website,
if your game controler is not recognized by your computer go to control panel click game controler and add your device follow the wisard instruction and install your controler,controler is plug and play device.have a nice day,regards
Jul 10, 2009 | DekCell (CPA-1040)
Can't get photos from MAC to load to Digital Photo Frame
To connect to a Macintosh computer:
1 Plug in and turn on the digital picture frame.
2 Connect the small end of the usb cable to the usb port on the side of the digital picture frame.
3 Connect the larger end of the usb cable to a USB port on your Macintosh computer. The Macintosh will recognize the digital picture frame as an external storage device, and an icon will appear representing the device.
4 Drag and drop your photos on to the icon...
5. After you finish, press the eject button, and disconnect the usb cable once the icon has dissappeared
If there is still a problem, try restarting the macbook. and make sure no other programs are running in the background that may interfere with the process. Also, make sure the laptop is plugged in, or the battery power is sufficient.
Hope this helps!
Let me know!
enov8
Feb 19, 2009 | Computers & Internet
Want to connect a Mac laptop to a EpsonStylus Photo R340 printer.
Hi
Try connecting the printer to a different usb port if you have extra port and make sure the connection is direct from printer to your mac
Hope this helps
Nov 14, 2008 | Epson Stylus Photo R340 InkJet Printer
How to set up and use targus wireless computer mouse model#amw26
Under the mouse there should be a usb stick attached to the mouse which most likely should slide out from the mouse. It also appears that the plastic cover behind the two buttons (this cover has targus written on it) Should come off. After you remove the usb stick there might be a button somewhere on the bottom of the mouse that you should be able to press to get the battery cover to pop up. Then you should be able to pull up on the battery cover and remove it from the mouse. This mouse takes two AA batteries. Once the batteries are installed then plug the usb stick into any of the usb ports on the computer. The computer should recognize the drivers for this mouse (if you are using Windows 2000, XP, Vista, or Mac OS X [or higher]). If the drivers are not immediately recognized then restart your computer and the computer should then recognize the mouse. If this still does not happen then let me know. Also there is software that can be downloaded from the Targus website for the tilt wheel as it has some added capabilities that can be set using this software. The link for that software is here ------> http://www.targus.com/us/product_details.asp?sku=AMW26US
I hope this helps, and enjoy that mouse, it looks pretty nice!
Sep 20, 2008 | Computers & Internet
I have a "My Book", Essential Edition, External drive, which a friend set up for me with a lot of information on it. When I plug in the USB and the addaptor (after having my MAC Book booted up),...
gud day...does ur mac book support any plug and play device? if it is then try to plug it to ur another usb port if it doesnt work...there sumthing wrong with your mac book.,it means that your mac book doesnt recognize the hardware to attach on to it...or ur mac software doesnt support the external hard drive...mac book operating system doesnt work with your essential edition external drive
Jan 14, 2008 | Computers & Internet
Iomega Prestige 1 TB USB 20 Hard Drive Logo
64 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
