Question about Panasonic CQ-DP133U CD Player
I've bought an adapter thing, but I don't understand how to wire these wires.
  • 35 Answers
  • Yellow - To the car battery of continuous +12VDC
  • Red - To ACC Power, +12VDC
  • Black - Ground, to bare metal or clean part of the car
  • Dark Blue - Motor Relay control lead for Antenna
  • Dark Blue / White Strip - Amp Relay Control lead
  • White - Front/Left Positive Speaker
  • White / Black Strip - Front/Left Ground Speaker
  • Gray - Front/Right Positive Speaker
  • Gray / Black Strip - Front/Right Ground Speaker
  • Green - Rear/Left Ground Speaker
  • Green / Black Strip - Rear/Left Ground Speaker
  • Violet - Rear/Right Positive Speaker
  • Violet / Black Strip - Rear/Right Ground Speaker
Posted on Nov 11, 2010
My 96 Toyota Camrys windows don't go down or the
You need to see a wiring diagram to see how the ignition switch allows or sends power to that 30 amp fuse. The switch may turn on a relay (maybe the ignition relay) that sends power to the fuse panel. Or the run wire out of the switch may itself turn power on at the fuses. You may have a loose connection behind the fuse panel.
Get a test light, pull the fuse, and check for power at the fuse terminals, with key on. One terminal for the fuse should have power. If not, power is lost between the ignition switch and that fuse. If it does have power, and windows still don't work, check the wire from fuse panel to the master switch-loose or poor connections, maybe a partially broken wire. If it looks good, check the ground wire for the windows. The ground wire originates at the master switch and will go back into the cabin to a nearby ground, possibly behind the left kick panel. If still no help, someone may need a volt- ohmmeter to start checking continuity of wires, voltage drops, etc.
Jun 18, 2013 | Cars & Trucks
Kawasaki ninja zx7 wiring diagram
When you say it keeps doing the same thing do you mean the wires keep burning, sounds as though you need to be finding a new wiring loom am sorry, if you carry on riding the bike you will eventually cook all of your expensive charging/and ignition components rendering the bike as scrap
May 20, 2013 | Motorcycles
I bought a metra wiring harness for my 93 mustang to put in an aftermarket stereo..stereo powers up but can not get sound to speakers..i triple checked all wires i spliced..all colors match..any...
Don't know the model. Be aware that Ford is whimsical when it comes to color codes and even varies from model to model. Whichever pair the adapter uses for the left door speaker, connect the + wire to the ORG/LT GRN wire and the - wire to the LT BLU/WHT wire. For the right door speaker, connect the + wire to the WHT/LT GRN wire and the - wire to the DK GRN/ORG wire. For the left rear speaker, connect the + wire to the PINK/LT GRN wire and the - wire to the PNK/LT BLU or TA/YEL wire (same wire). For the right rear speaker, connect the + wire to the PINK/LT BLU wire and the - wire to the DK GRN/ORG or BRN/PNK wire (same wire). REMEMBER, the colors of the Metra adapter may not match what's in your car
Sep 27, 2012 | Car Audio & Video
95 volvo 850 drivers door inside wont open
got the panel off?, i'm gonna assume it's power not a hand crank and that you've also closely checked your fuses, the only thing left is maybe a wire has come off the contact or you've burnt out the switch and that may need to be replaced but I'm sure if you inspect and follow the wires it may lead you to a problem along those lines. If nothing is wrong with the wiring, it could be the switch itself I don't know either how to nail down the issue so you could find out, maybe use a battery with some wires and try touching the leads and just give it power and if the door unlocks then you know it is your switch. Good luck
Sep 21, 2011 | 1995 Volvo 850
Hey, I bought the Wireless n adapter for my xbox 360 and I don't understand how to connect it please help
hello my brother i'm don't have xbox and too I'm dont know lot about xbox . But youtube know how to slove your broblem from here
thank you
Jul 23, 2011 | Computers & Internet
Re: Cabana Kitchens, model #DML27S, Serial #286-21. Problem: The 2 button igniter does not produce a spark to light the LP gas. I've replaced the 2x 9-volt batteries as I did last year. Help? ...
Don, the first thing that comes to mind, is that the ignition module has lost it's ground. Trace the wires behind the module, to see if there is a loose one. If so, more than likely it's the ground wire.
Hope this helps you to get back up and grilling.
Jul 09, 2011 | Cabana Kitchens DML27S
The red lead wire on the back of the alternator has pulled away from somewhere and I need to know where it attaches to. This is on a 1997 Chevy Cavalier 2.4 engine. When I took the bolt off of the red lead...
That heavy gauge red wire (called a B+ wire) runs from the positive side of the battery directly to the back of the alternator. On yours, if it goes to the starter, the starter main battery terminal would essentially do the same thing. (both connections are always hot and always come directly from the battery). If you meant that it became disconnected when you said "pulled away", you need to find the wire it disconnected from and re-connect it. If it just came out of a loop that was securing it, you don't necessarily need to find the loop but can secure it with a tie wrap, making sure it stays away from the manifold.
You could actually make a new wire and connect it between the battery (+) terminal and the alternator, using the same gauge wire, but I'd be concerned that the loose end coming from the starter could possibly touch something and cause a direct short. At the least, you should find the loose end and cap it off. The battery cannot charge with the wire disconnected.
Anything I've just written that you don't understand, just ask and I'll clarify it for you.
Jun 22, 2011 | 1997 Chevrolet Cavalier
I bought a nintendo wii,and I don't know if I need a wii LAN adapter to get internet and I have a wired network,but my friend told me she has internet and her network is wired and she doesn't have...
The only network adapter integrated into the Wii is wireless, you will need a network adapter to use a wired network.
Please see the official site for more details: http://www.nintendo.com/consumer/systems/wii/en_na/acc/wiiLAN.jsp
Thanks, and as always a vote/feedback is appreciated. =)
May 30, 2011 | Nintendo Wii Console
Broken car adapter plug
every car plug should have a nozzle like thing, thats the front, if the wire is pulled out it doesn't matter. no problem with +ve or -ve. you join anywhere no probs.
Jun 03, 2009 | Samsung SGH-D500 Cellular Phone
IP address
I had the same problem with my Xbox and Netgear DG834 v4 (wired) router. I bought a Belkin F5D7632 wireless router and that did not work either. I then bought an Xbox wireless adapter and it connected ok. I do not know why the wired connection does not work. The cable length is 10m.
Dec 30, 2008 | Microsoft Xbox 360 Console
Panasonic CQ-DP133U CD Player Logo
148 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
