This is not a driver issue. Im assuming this is a passport. There could be a problem with the enclosure, however if it is a passport removing it from the enclosure will do you no good. More than likely there is a problem with the drive, possibly in the firm wear or a module. Either way it appears to be a hardware issue with the drive not your computer. USB plug and play should recognize it automatically without the need for drivers, especially if your device manager is recognizing it properly then the driver is not the issue.
SOURCE: i have WD 160GB external hard drive. when i plug
Attach your external HD with some other computer, that will definitely appear normal, the problem is due to a virus in ur HD. Your computer's antivirus software stops it to appear. Back up your data on the other computer, format ur external HD, remove un-necessary files and run a virus scan to the files u copied from HD, Hope this will solve the problem, if not, let me know and tell me what would be the response on the other compuer
Note: The Device Manager shows the device as WD7500AA External USB Device. The model number on the device is WD7500032-000. I did not intend for this question to be posted under the "Problem with Western Digital Accusys ACS-7500" as that is not the device I own.
Thanks.
