Question about Frigidaire Electric Dryer
Why my dryer is not starting and no power connection is coming
  • Frigidaire Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Nov 11, 2010
Will not start
Check your power source, then the cord to make sure it is connected to the dryer properly, and not shorted.
Feb 26, 2014 | Amana NED7200TW Electric Dryer
When I press the button to start the dryer, the water intake starts. The unit is a stacked combo washer dryer. When plugged in and set to wash no water comes in. Only when the dryer button is pressed does...
Hello Julien, thank you for your inquiry!
Based on the symptoms you are describing it sounds like your laundry center is experiencing an issue with the power supply. Either the power supply is not connected correctly or it's an internal power supply issue within the unit. Regrettably, this is not a simple DIY job. I would strongly recommend connecting with a professional to narrow down the precise issue before investing in parts that may or may not be the root cause. You can often locate a qualified service provider through the manufacturer website.
Oct 19, 2013 | Frigidaire FEX831CS Top Load Stacked...
Power going to door switch-light goes off and on with switch, press start switch-switch makes contact but dryer does not come on. So when on switch is pressed unit does not power on.
unplugg dryer,take the 2 wires off of door switch connect them together with electrical tape,plugg dryer back in hit start switch dryer should come on ,that tells you that the switch is bad,this can also done with a tester
Jan 23, 2011 | Dryers
Dryer will not come on
send model number,is it gas or electric?check to make sure you have power where the cord connects to dryer and sent info so i can help you
Feb 24, 2010 | Kenmore Dryers
Push start button will come on. power check good at dryer connection
If motor is stopping as soon as you let start button go problem is bad motor. part # 279827 approx 100 to 125.00
Jan 28, 2010 | Whirlpool LER7646E Dryer
Dryer will not start have replaced the heating element, door switch and on switch
hi, i recommend inspecting the terminal block that the power cord is connect to on the back side of the dryer. this terminal block may be faulty or, the cord could be lose and not connected properly.kindly, inspect this device that is located on the back side of the dryer for lose connections. if the termainakl block is in good conditon and, the power cord is screwed on tight, thsi iwll confirm timer fialuer.
replace the timer in this case.
May 20, 2009 | Kenmore Dryers
Dryer-DEGX2
OK I had this issue as well. I ended up opeing up the dryer and cleaning all the connections. After that it came right back up. It would start with the displaying going haywire. Easy fix and saves you a tech coming out.
1. Take off lid
2. open up the buttons with 2 screws in back
3. Pull electric wire connection and blow out.
4. unscrew 2 screws top front. Covered by rubber stops
5. Lift Lid and blow out. Sensor on the left top.
Worked for me.
Oct 26, 2008 | Fisher and Paykel DEGX2 Dryer
Dryer stpped working
with power disconnected
if any wire disconnected before any test, reconnect & test dryer, reconnect wires after each test
disconnect wires from start button and test, conduct when pushed, no conduct when release
if fail replace start button test dryer
disconnect wires from door switch and test, conduct when pushed, no conduct when release
if fail replace door switch test dryer
follow leads from start button to relay(relay is first device connected to start button), and make sure all wires connected at both ends. If any wires disconnected, test dryer
locate thermostats and thermal fuses on fan housing and ducts
individually disconnect wires from each and test. conduct good, no conduct fail
replace any failed thermal fuse or thermostat test dryer
if all prior test OK
replace relay, test dryer
Oct 10, 2008 | Magic Chef CYE4000AWW Electric Dryer
The Dryer wont start.
Often the main wiring connection from the house at the dryer burns, and the connection breaks. Verify the connection at the back of dryer, and if visually you can't she the brake then check for voltage (240). If there is not enough voltage at the terminal block-replace the terminal block and the cable.
Jul 28, 2008 | Whirlpool LER5636P Electric Dryer
Frigidaire  Electric Dryer Logo
46 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
