Question about ViewSonic VX2235WM Monitor
I have opened my viewsonic and I dont have any leaking or buldged caps but the monitor goes off and I have to power it off and back on. What could be wrong
  • 11,361 Answers
All the top of the caps are perfectly flat? Bad cap can have high ESR with no sign of bulging or leaking. You need to check the DC reading on the caps to see if you have the 5vdc and 16~18vdc.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
If you can post the pictures, that will help. Worst case will be the lamp assemblies problems.
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Nov 11, 2010
My monitor comes on for about 15 seconds then goes off. I can turn it back on and then it goes off on its own.
LCD or CRT monitor? Model?
Failed VIEWSONIC: http://s807.photobucket.com/albums/yy352/budm/VIEWSONIC/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 29, 2011 | ViewSonic Computers & Internet
Green power light flashes,screen goes black
Look for bad caps with domed top, worst case will be the lamp assembly, see my pictures here:
http://s807.photobucket.com/albums/yy352/budm/VIEWSONIC/Viewsonic%20VX922/
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
May 27, 2011 | ViewSonic VX922 19" Monitor Flat Panel
My viewsonic vx2235wm-3 goes black after 3hours use, it use to take 6hours before it would go black. If I turn it off for an hour or more it will work for a couple of hours and then go black again. It...
Look for bad caps as shown in my pictures first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Basic LCD monitor troubleshooting guide:
Oct 04, 2010 | ViewSonic VX2235wm LCD Monitor
The screen goes black, if i turn it off and back on the screen will come back, sometimes for a while, sometimes not
Check DC filter caps for leaking/bulging top in the power supply.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Jun 25, 2010 | ViewSonic VX1932wm Monitor
Viewsonic Optiquest Q19wb lcd Monitor goes blank after 2 secs. A couple of posts say replace the 1000uf 16v Cap My problem is i can't find them on the pcb (where are they?)
Look at the board where the AC power connector comes in that is the power supply board, there are more than one versions so it nay not have the same caps value.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Viewsonic/Optiquest monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post pictures or send them to me budmrtn@aol.com
May 15, 2010 | ViewSonic Optiquest Q19wb LCD Monitor
My viewsonic vx2255 wont turn on sometimes i have also found a noise coming from the powerboard and once it goes away the monitor will turn on
You may have caps leaking in the power supply or arcing from the lamp assemblies, you need to open it up.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 16, 2010 | ViewSonic VX2255 Monitor
My VX2235 sometimes goes blank (black) for 2-3 seconds, then back on. This has happened thru 2 M/Bs and 3 Gr.Bds. Happens more on digital connection than on analog. Any ideas?
Common failure in this monitor is bad caps in the power supply or lamps, you need to open it up, post back what you see inside so we can guide you further, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 25, 2010 | ViewSonic VX2235WM Monitor
It's a Viewsonic VX715 Monitor. When it's turned ON, It goes black in 3 seconds.
It can be one of thses: bad caps (bulging top or bottom seal) in the power supply, bad backlight inverter circuits, bad lamps. You need to open it up and lool for bad caps first, then measure the voltages across the filter caps, you should have 5vdc and 12~18vdc (there are two power supplies: 5vdc for logic, 12~18vdc for backlights citcuits) Post back what you find so we can guide you further, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 25, 2010 | ViewSonic VX910 19" LCD Monitor
ViewSonic VX2235WM Monitor Logo
65 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
