Question about Milton Bradley Toys
Missing the secret solutions sheet and the middle pole.
  • 1,498 Answers
My name is Mike. A couple times a day I go looking around to give some pointers to our clients (you).
Look at it your question from our point of view, while you have narrowed it down by providing the manufacturer, MB does make a lot of games. We need a little more info.
More is better:
If you are serious about getting an answer, include Make, Model of the product that's misbehaving and what type of product it is.
Describe your problem clearly, concisely and with as much detail as possible.
For future reference:
Often, a problem can be the result of a seemingly unrelated event. It is always a good idea to include a recent history.
Additional information such as what steps have already been taken, has the product ever worked, is it new, etc. can have a bearing on providing the best solution for your particular circumstances.
Remember, you are a key participant in this process. We are not there, you are. We depend on you to be our eyes and ears. We can only respond to what you provide us. Without you, all our talent is worthless. How's that for an ego build?
What you get out of the experience depends on what you put in to it. So help us help you.
It would be also be advantageous in your case to repost your problem so that it is correctly categorized and starts over at the top of the queue. This way it can be directed to someone with expertise in the area you need. They may have the manual memorized. Who knows?
Best regards
Mike
Posted on Nov 11, 2010
How to build a dirt floor 20 by 20 shed
Put posts in ground.
Middle posts taller so roof will have slope
Nail 2x4s across from post to post to hold siding.
One row of 2x4s around bottom, 2 rows 2x4s around middle,
1 row 2x6s or 2x8 around top.
2x6s 2x8 will hold rafters
Nail 4x8 sheets treated plywood onto the 2x4s to make walls.
Install joists across top of structure from one wall to the other wall
Install rafters at correct angle to match slope of roof, be careful to each rafter exactly the same.
Rafters sit on outside wall
http://waterheatertimer.org/images/Pole-barn.jpg
Gene
Sep 01, 2014 | Hardware & Accessories
Fischer paykel c09
The black stuff is called "Scrud".
It builds up over time from a combination of washing detergent and fabric softener.
Reach your hand down the middle of the agitator (middle pole) after removing the cap. There is a plastic wing nut that you can undo with your hand. The agitator can then be lifted out.
The other easy solution is dumping half a box of epsom salts in there (usually in the bath/ medical isle of the supermarket), run the machine empty, on HOT, Full load so that it fills all the way. Usually this cleans most of it out.
A more regular empty hot wash will prevent build up in the future.
Mar 22, 2014 | Fisher Washing Machines
Oki C9650 not printing Yellow
remove the unit
open the cleaning lamp cover (front of unit)
turn O.P.C drum gear and check that toner is always applied to the developer roller
Sep 27, 2012 | Oki Printing Solutions C9650 Led Printer
No instructions giving to erect our tent 6 man regatta hyperdome model no 927/5887
I bought one of these yeaterday. The instructions - for what they are worth are sewn inside the carry bag. So I decided to put it up today. Not as easy as i would have thought, but then this is my first tent of this size. ( saw a nice Outwell Montana 4 in Millets for 225.00 which would have been my tent of choice). But at half price in Argos I couldn't argue that one.
So to put it up.....
lay out the fly sheet in the approximate final position. put poles in as per instructions ..blue to back red to middle and blue to front.. across the tent. ( the pole guides are all colour coded.) Make sure poles are in pins at the base of fly sheet (bending gently to attach). these are attached by the black elastic straps.put in porch pole, put in front to back poles left and right.
Anchor back of tent temporarily with pegs. Lift from porch forward to lift tent. Temporarily peg base of poles, straighten out so that the straps inside tent are approximately perpendicular to each other. Move poles to tension flysheet and tighten anchor points on flysheet using straps buckles to pull flysheet down as far as possible ( to help prevent draughts)., anchor guy lines when happy with final position.
Put up inside ground sheet and attach to points on inside of flysheet. put up rooms starting with the rear yellow hook and work around to front red hook.
These instructions were not specifically provided but this was our first try and probably could be improved on. It requires 2 people for speed if nothing else.
Enjoy
Jul 31, 2011 | Sport & Outdoor - Others
Need secret solution sheet for Sweet Cherub 3d sculpture puzzle
go to hasbro.com and go to customer service and search the instructions and manuals to find the 4 page instructions and secret solution!!!
Apr 17, 2011 | Milton Bradley Sweet Cherubs 3D Sculpture...
I don't know how to set up my travel lite crib bassinet
You're not alone. If you do every step perfectly then it's a breeze. Most of us are human and don't... This frequently results in a major pain.
Most travel cribs print the directions on the pad that lines the bottom of the crib. Unfortunately, this still isn't much help. I'm going to assume that you're like most of us- you've read the directions and you still can't get the thing to cooperate!
I fought with my Graco travel crib many times before I discovered a few secrets:
- Follow the directions precisely, even if a step seems a bit odd.
- If you get going on it and mess up (or it just won't stay up), give it up and start over again from step 1.
- Before you start, make sure that it's completely collapsed. It may look like it is, when it isn't. Here's how you check:
There should be at least one handle near the middle of each top pole that can be squeezed (longer sides sometimes have two). Feel your way across the top pole until you find each lever and squeeze it. This will collapse the pole into two (or more) sections.
Make certain that the poles remain collapsed as you pull the center handle (center of crib where matress will go) towards the sky and squish the whole thing together like you're putting it back in the box (or carrying case.) Now we're ready to start!
1) Gently begin to unfold/open the crib as you hang onto the handle in the center.
2) Continue to hold the center handle with one hand. With the other hand, lift each top pole until it locks into one "solid" pole. NOTE: This is trickier than it sounds! If the center handle drops even half-way down then you won't be able to get all poles to lock and you'll have to start over again.
3) Only after all four top poles have been locked, can you push down the center handle. This will spread the bottom into one flat piece and finish locking everything in place.
Good News!: It's all downhill from here!
4) Put a sheet on the "mattress", if desired.
Otherwise, just unfold it and place it in the bottom of the crib. There are some strange little velcro tabs on the sides of the mattress. These fit down the slits in the bottom of the crib and attach to the underside. This step is important as it keeps the mattress in place and helps to reduce the risk of suffocation.
5) Finally, assemble the canopy, locate all the little snaps on the side, and snap on the accessories.
Whew! Take a deep breath... you did it!
Congratulations on your baby! Enjoy!
Jun 24, 2010 | Graco Travel Lite 9001 Crib
Lost the instructions for circo monster play tent...need to set up for kids asap..
2 short poles A 2 longer poles B 1 medium pole C
Slide one assembled A pole through the pole sleeve at base fold and fasten the velcro tab over the end of the inserted pole repeat with other A pole on other side Slide one assebled B pole through the pole sleeve at rafter. (across the body) fold and fasten velcro tab repeat with other pole slide one assembled C pole through the pole sleeve at top (down the middle of the monster) Put plastic mold at the end of the inserted pole into the pole at front
Feb 19, 2010 | Toys
No Instructions
Peg out the "brown" ground sheet of the inner tent and hold it up like a standard ridge tent.
Put the two shorter upright poles on the inside of the compartment (with something under the feet to prevent damage to the ground sheet). Put the 40mm tubes on the spike that pokes through, and then put the ridge pole on the outside.
Everything should then hold in place while you put the fly sheet over the top with the 2 longer poles at the front.......
tip - line up the seam on the fly sheet with the front of the inner tent as you peg it out....
Good luck
Mar 21, 2009 | Sport & Outdoor - Others
Fan oven replacement
if your new element is missing a terminal it is likely to be the earth terminal so when your new element arrives DO NOT connect the green\yellow wire to anything just wrap it in duct tape. As this is the earth if you connect it to the element you are just making a dead short so will blow element and fuse. The element is touching the oven liner so is earthed by the oven anyway. :)
Sep 06, 2008 | Ovens
Toys Logo
29 people viewed this question
Top Milton Bradley Toys Experts
Nikki  Mclean
Nikki Mclean
Are you a Milton Bradley Toy Expert? Answer questions, earn points and help others
