StorageTek SL500 on power up, robot arm stops at bottom of library and "service robot" and "service required" LEDs light up. Will not boot up. Any ideas on using the console port for troubleshooting?
Sory to say this, but you need a new robotics unit. TYhe SL500 uses internal barcodes to determine robotics location, and I am pretty sure that your barcode scanner ( part of the robotic hand ) is not active.
The reason I am sure is because I have the same symptoms right now :-(
Posted on Jul 31, 2012
9E 09
Hi Alan
Error 9E - Elevator range of motion out of specification
The Elevator (the part of the robotics assembly that moves in the vertical direction) range of motion out of specification
If possible, check for an obstruction by powering off the library and either removing a magazine or a drive to view the robot. Gently remove the obstruction, replace all magazines and drives and then power up the library.
Re-try the last operation
If you are in the UK and are still having trouble, please click the link below and we will do all we can to help you.
LTO Repair service UK Based All manufacturers of LTO drives repaired
Feb 27, 2014 | IBM Computers & Internet
Proximity detector off failed
Hello!
I had the same problem with our Storagetek L40 library and had to get another robotic hand from a company named Instock Inc.
It was an easy fix. I just had to power off the L40 library, take off the old hand and put the new hand on, then turned the L40 library back on, and it worked great after that.
In the hand is a sensor that goes bad after time.
You should be able to find them on the web at instockinc.com I believe, and they should have the hand you would need.
Jan 26, 2011 | Storagetek L40 DLT Tape Drive
Tiger Electronics 2-XL Robot has no sound or lights
please service your product.Contact a coustemer care and continue.
Jan 17, 2009 | Toys
My Storegtek L80 can't recognize all of its tape drives
That thing required a SCSI terminator pack doesn't it.
If so, is it working properly.
I've had those things go out on me before leaving me to pull my hair out many times.
Jun 14, 2008 | Storagetek L80 DLT Tape Drive
StorageTek L40- Service required Led Blinking always.
Remove the server connection from the library.
power on the library, follow the display in the front panel. The library will do some checks. Note where it fails. Press the select button, it will display the some code message. With the error code refer the manual.
Sep 18, 2007 | Storagetek L40 DLT Tape Drive
StorageTek L40 Tape Library
sounds like your robot is stuck or something may have dropped onto the track on the floor which is restricting it's movement.
Jul 26, 2007 | Storagetek L40 DLT Tape Drive
Service required led blinking
You will need to get a StorageTek engineer out onsite to have a look at the problem, the light will not dissapear until resetted by a engineer.
Jul 10, 2007 | Storagetek L80 DLT Tape Drive
Sn 3250 router problem
Ok, I'm confused... are you sure this isn't router that you're mentioning isn't a SAN Switch? A StorageTek/Brocade 3250 switch... and this is a StorageTek Scalar 100 Tape Library with Fibre aware LTO Drives. The Library Users Manual can be found at http://downloads.quantum.com/scalar/S100/omS100UsersGuide.pdf. Switch information can be found at http://www.storagetek.com/products/product_page2304.html. I'm not a Sun guy, so I would suggest that you contact them to find out which versions of firmware for the switch that they have certified. With HP, there are certain versions of firmware that they certify with HPUX... and specific versions of HBA drivers that work better with HPUX as well. If it is, in fact a Brocade 3250, I would suggest that you start with a "switchshow"... figure out which port drive 4 attaches to... do a "porterrshow #" (# represents the port found) to see the port error statistics... you want to check the loss of signal and link failure count. I would do an "sfpshow #" to see the status of the transciever as well. Let us know.
Oct 04, 2006 | Storagetek StorageNet Router 3250
Computers & Internet Logo
747 people viewed this question
David Payne
David Payne
