Question about Canon PIXMA MP600 all-In-One InkJet Printer
I have a Canon iP1500 Photo Printer. The waste ink absorber needs to re replaced. Where is this item located in the printer, and where can a replacement be purchased? In addition, can it be cleaned and reused again? Thanks, Ray
  • Canon Master
  • 4,338 Answers
How to clear E27 Waste ink absorber full
1.With the printer powered off but connected to a power source,
press the Power button while pressing and holding the Stop/ Reset button.
2. When the Power is lit, press the Stop/Reset button two times
while pressing and holding the Power button.
3. When releasing the Power button and the Stop / Reset button (regardless of order),
the printer will move into a service mode. (Waiting for menu selection)
4. When the on/off lights in green, press the Stop/Reset button the
specified number of time(s) according to the function listed in the table below.
(Each time the Stop/Reset button is pressed, the LED lights alternately in orange
and green, starting with orange.)
Note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5.Turn off the printer.( it must be turn off) then turn it on again
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Nov 11, 2010
The waste ink absorber is fll. Can I get one and exchange it?
Ink Counter Reset - Canon IP1000/1500
1st Option
1 Unplug power cord
2 Press and hold power button
3 Plug in power cord and switch on power - still holding power
button
4 Still holding power button press resume button 8 times
5 Release power button
6 Press power button to turn on
2nd Option
1 Turn off printer and disconnect power cable
2 Press and hold power button, reconnect power cable and switch power on
3 The indicator (LED) should be GREEN
4 Press and release resume button, still holding power button, the indicator (LED) should be ORANGE
5 Press and release resume button again, still holding power button, the indicator (LED) should be GREEN
6 Release power button
Oct 12, 2010 | Canon PIXMA iP1500 InkJet Photo Printer
What do I do when my printer says ":waste ink absorber full". what do I have to do.
if its the first time, the absorber usually may still be good. this means that the printer counters has reached its limit. the pad needs to be replaced. you need to take your printer to cannon for a replacement.
Jun 19, 2010 | Canon PIXMA iP1500 InkJet Photo Printer
Printer won't print. Says to contact service
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Dec 10, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
I appear to need to replace the waste ink absorber on my Canon Pixma iP1500. Any help please.
Canon built several models like yours that you can't get an ink absorber for. They are only exchanged during the warranty period where they send you a new printer. After warranty it is considered a throw away printer.
Nov 18, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Waste ink tank full
Here's the steps for reseting "Waste Ink Full" problem at iP1000
Step 1: Manual for Service mode (1st method)
1. Unplug POWER and USB cables.
2. Open door, PRESS and HOLD the POWER button.
3. Connect the POWER cable.
4. Close door, then release POWER button.
5. Power ON your printer a usual (It should not blinking anymore)
Step 1: Manual for Service mode (2nd method)
2. PRESS and HOLD the POWER button,
3. Release the the POWER button
4. Power ON your printer a usual (It should not blinking anymore)
Step 2 : Software for Permanant (1st method)
1. Reconnect the USB cable and turn ON your Printer
2. Open "General Tools for iP1000",
http://www.printersiam.com/data/download/iP1000%20Service%20Tool.zip
3. Select (USB PORT)
4. Choose (SET DESTINATION 1)
It should be reseted already, but somehow it start blinking again if you ever unpluging AC POWER cable. So try the 2nd method by using ServiceTool for IP1500
Step 2 : Software for Permanant (2nd method)
2. Open "General Tools for iP1500",
http://www.printersiam.com/data/download/iP1500%20Service%20Tool.zip
4. Choose CLEAR WASTE INK COUNTER - MAIN
5. Choose CLEAR WASTE INK COUNTER - PLATEN
It should be working, coz my printer now now work normally
I tell you what. Before you decide to reseting the waste ink counter, you should really clean up the ink absorber, or else you will find the ink watse absorber overflow...
Aug 25, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Waste toner receptical problem
The waste ink absorber is inside under the printer, you need a shop to replace them and reset the counter.
Jul 15, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Waste ink absorber almost full
You will need to take this into a certified repair tech. You can contact Canon through their website for the closest repair center. It should only cost you around $50 to $100 for them to replace the ink absorber pad.
Jun 18, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
I have cannon pixma ip1500 printer sold in good working condition buyer wants refund saying the waste absorber is full, therefore dont workHELP
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 15, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Pixma IP1500 stops
Temporary Fix
This always works in case you need your printer for Emergency ^_^.
  1. Turn off the printer
  2. And unplug the printer power cable
  3. Press and Hold the POWER button
  4. Plug the power cable again
  5. The indicator (LED) should be green
  6. Press and Release the RESUME button, the indicator (L.E.D.) should be orange
  7. Press and Release the RESUME button again, the indicator (L.E.D.) should be green
  8. Release POWER button
  9. Windows will detect new printer and you just have to install it again.
  10. It will create a copy of Canon i320 printer. Just delete the old one and rename the copy.
  11. You are done.
Mar 20, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Canon pixma ip1500
How do I change the "Waste Ink Absorber" on my Canon Pixma IP 1500? Where do I get the absorber part? Thanks.
Jan 31, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Canon PIXMA MP600 all-In-One InkJet Printer Logo
89 people viewed this question
old marine
old marine
