Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
When installing new drive belt on ModelYTH 1848XP how do you get the new belt over the the electric clutch pulley.
  • 293 Answers
This is going to be a fun project, just kidding this is a pretty difficult job. I am glad you are asking.
The first thing is, you can't get the belt over the clutch. You need to disconnect the battery and the two wire connector going to the clutch. Then you need to remove the colt holding the clutch on. Be carefull not to drop it, it is about 10 lbs, so be ready for it to fall off when the bolt is removed. There will be a flat washer that comes off too, just remember the order when reinstalling. That was the easy part. Now you have the drive pully on the bottom of the engine, this is going to be fun again ( just kidding, I have done.....well alot of these and they all are frustrating at one point or another), the pully just "slides" down the crankshaft. Well, it is suposed too. If it is old, or sat outside......it will probably not just "slide" off. You need to get this pully slid down because there are belt keepers stamped in the tractor frame or engine base, that wont allow you to get the belt off or put a new one on. If you use a pry bar to "help" the pully slide down, be careful not to pry too hard, the pully is soft, and will bend. If this happens the tractor will be jerky or worse.
Now after you decide you cant get it off without destroying it, and please stop just short of that. There is a way to take a short cut. Remember if you bend the pully and it is truely stuck, you will have to remove the engine and use a torch and cut it off. After that you will have to replace the lower engine oil seal too.
With the remove the engine statement, I was refering to disconnecting everything ( fuel lines, starter cable, exaust, throttle and choke cables). Now I am refering to making your belt replacement easier by lifting the engine and leaving the pully on.....only if you cant remove it.
First remove the 4 mounting bolts under the tractor securing the engine. Next use a prybar and pry the engine up, only about 2 inces just enough to remove the drive belt. Then install the new one the same way. Then reverse the process. You may have to wiggle the exaust pipe back into the muffler.
Hope this helps
Posted on Nov 11, 2010
How to i change the drive train belt on my cub cadet z force 50
  1. First park your mower on level ground and apply the parking brake.
  2. Remove the deck drive belt from the PTO clutch.
  3. Remove the electric PTO clutch. This is done by disconnecting the electrical wires first. Then removing the center bolt using an impact wrench. A pull bar can used but you must prevent the engine from turning by blocking the flywheel.
  4. Remove the tension on the drive belt idler.
  5. Remove the drive belt from around the pulleys. Be careful as the engine may try fall off depending on if it isn't seized on yet.
  6. Installation is the reverse of the above instructions.
  7. After install the PTO clutch tighten the center bolt to 55 ft lbs using a torque wrench (not your impact wrench) with the flywheel blocked from moving.
Dec 28, 2014 | Cub Cadet Garden
I need a serpentine belt diagram for a 1999 ford escort
SECTION 303-05: Accessory Drive 1999 Escort/Tracer Workshop Manual DESCRIPTION AND OPERATION Procedure revision date: 06/06/1998 Accessory Drive Component Locations -2.0L SPI with A/Ca27194a.gif
Item Part Number Description 1 6B209 Belt tensioner 2 10344 Generator pulley 3 8620 Belt 4 3A733 Power steering pump pulley 5 8678 Belt idler pulley 6 2E884 A/C clutch pulley 7 6316 Crankshaft damper
Component Locations -2.0L SPI without A/Ca27193a.gif
Item Part Number Description 1 6B209 Belt tensioner 2 10344 Generator pulley 3 8620 Belt 4 3A733 Power steering pump pulley 5 6316 Crankshaft damper
Item Part Number Description 1 10300 Generator pulley 2 19A216 Belt idler pulley 3 3D673 Power steering pump pulley 4 8509 Water pump pulley 5 6B209 Belt tensioner 6 19703 A/C clutch pulley 7 6B320 Crankshaft pulley damper 8 19A216 Belt idler pulley 9 8620 Drive belt NOTE: Drive belts (8620) with automatic drive belt tensioners (6B209) do not require adjustment.
NOTE: When a new drive belt is installed or a drive belt is re-installed after a service procedure, the drive belt does not fully seat into the pulley grooves until engine has run for several minutes.
This vehicle is equipped with:
  • a V-ribbed serpentine accessory drive belt.
  • an automatic drive belt tensioner.
New drive belts must be of the same type as originally installed.
Check the drive belt condition at 96,000 km (60,000 miles) then after every 24,140 km (15,000 miles).
Mar 06, 2011 | 1999 Ford Escort
Belt routing diagram
SECTION 303-05: Accessory Drive 2006 Taurus Workshop Manual DESCRIPTION AND OPERATION Procedure revision date: 03/29/2005 Accessory Drive adobe.gif Printable View (137 KB) Accessory Drive Belt Routing
Item Part Number Description 1 10346 Generator pulley 2 8678 Belt idler pulley 3 3A733 Power steering pump pulley 4 8620 Drive belt 5 19D784 A/C clutch pulley 6 6B209 Drive belt tensioner pulley 7 6A312 Crankshaft pulley 8 8A528 Coolant pump pulley This vehicle is equipped with:
  • automatic drive belt tensioner(s).
  • a V-ribbed coolant pump belt.
New drive belts should be of the same type as originally installed.
2010&c18=modelyear&c20=n891472&c35=wsm%2caccessory%20drive%2cs6h%2c303-05%2cdescription%20and%20operation&s=1366x768&c=32&j=1.3&v=y&k=y&bw=995&bh=428&ct=lan&hp=n&[aqe] ddll111_5.jpg
Dec 31, 2010 | 2006 Ford Taurus
Serpentine belt routing for 2001 ford taurus
what engine? Please rate if this helps. Took a lot of time to dig out.
here's 2002 3.0L 2 valve
Item Part Number Description 1 10346 Generator pulley 2 8678 Belt idler pulley 3 3A733 Power steering pump pulley 4 8620 Drive belt 5 2E884 A/C clutch pulley 6 6B209 Drive belt tensioner pulley 7 6312 Crankshaft pulley 8 8509 Water pump pulley
4 valve
Item Part Number Description 1 3A733 Power steering pump pulley 2 8620 Drive belt 3 2E884 A/C clutch pulley 4 6316 Crankshaft pulley 5 6B209 Drive belt tensioner pulley 6 10344 Generator pulley
water pump 4 valve
Item Part Number Description 1 6A359 Camshaft drive pulley 2 8K543 Drive belt 3 8509 Water pump pulley 4 8W508 Drive belt tensioner pulley
Dec 20, 2010 | Ford Taurus Cars & Trucks
Belt diagram
Accessory Drive adobe.gif Printable View (62 KB) Component Locations 3.0L (2V)a0007698.gif
Item Part Number Description 1 3A733 Power steering pump pulley 2 8620 Drive belt 3 19D784 A/C clutch pulley 4 6A312 Crankshaft pulley 5 6B209 Drive belt tensioner pulley 6 10344 Generator pulley
Item Part Number Description 1 6A359 Camshaft drive pulley 2 8K543 Drive belt 3 8A528 Coolant pump pulley 4 8W508 Drive belt tensioner pulley
Nov 28, 2010 | 2004 Ford Taurus
The belt dry rotted and flew off without me being able to remove it myself, now I need to know how to install the new drive belt.
To install the drive belt you will have to remove the drive belt first.
Follow the procedure: ---
Park the tractor on a level surface. Set the parking brake and remove the key from the ignition. Study the belt replacement guide decal located underneath the left foot board for proper belt routing instructions.
Remove the mowing deck by first moving the attachment clutch lever to the disengaged position (toward you). Move the attachment lift lever all the way forward to lower the mower housing to its down position.
Crawl beneath the tractor and roll the drive belt off engine pulley (it hangs directly beneath the engine). Remove small retainer clip that holds the clutch spring to the pulley bolt located at the center of the mowing deck. Remove the large retainer springs (two of them), then slide the belt collar away from the mower housing and off the housing bracket.
Disconnect the anti-sway bar rods from the chassis brackets by removing the retaining cotter pins. Disconnect front links from the mower deck by removing retaining cotter pins. Disconnect the suspension arms from the rear mower deck brackets by removing the two cotter pins.
Move the attachment lift lever all the way to the forward position to raise the mower suspension arms to the full up position. Slide the mower deck out from beneath the tractor.
Crawl beneath the tractor and roll the drive belt off of the stationary idler pulley and the clutching idler pulley. They are both located immediately adjacent to the engine pulley. Be sure the belt is already away from the engine pulley, as well.
Push the drive belt slack toward the rear of tractor. Remove the drive belt from the Trans axle pulley by taking it over the trans axle pulley while compressing the movable belt keepers surrounding it. Remove the old belt from the tractor by pushing it clear of the center span keeper (located beneath the Trans axle pulley).
Install a new drive belt by following the reverse of the instructions for removal. Test the tractor and mower for normal operation.
 Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jul 19, 2010 | Garden
High pitched howling and screeching (yes two different noises). The howling appears to happen when the air conditioning compressor pulley engages. The screeching, my guess would be from the belt. Any...
When the AC compressor kicks on, an electrical load is placed on the alternator and the drive belt that turns the alternator pulley, if not tight enough, can cause the belt to squeal. Replacing the belt should help with that noise if the belt is stretched from wear. The screeching noise can be from a bad idler pulley, a bad belt tensioner pulley or a bad alternator pulley or a failing clutch on a very old ac compressor and rarely a water pump pulley. To check pulleys remove the drive belt and turn them individually to see if they can be tilted up down or sideways with play in the "bearing" of the pulley. Also, you may wish to visually inspect the clutch on the ac and look for melted black rubber around the bolts that secure the clutch to the compressor (stinks,smokes and melts these rubber areas if ac compressor clutch fails).
Jun 06, 2010 | 1996 Saturn SL
Serpentine belt diagram 2002 ford escape picture of serpentine belt pattern
CLICK on the following LINK. It has the Belt Diagrams you will need.
If you would: Before Clicking: Let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/2002/make/ford/model/escape/2002_ford_escape_drive_belt_routing_diagram.htm
Feb 27, 2010 | 2002 Ford Escape
The 2001 Windstar we have here only has 7 pulleys and the diagram dosnt match any ides.
here you go. please rate, thanks
Item Part Number Description 1 8620 Drive Belt 2 10300 Generator Pulley 3 6C348 Idler Pulley 4 6B209 Drive Belt Tensioner 5 3D673 Power Steering Pump Pulley 6 2E884 A/C Clutch Pulley 7 6A312 Crankshaft Vibration Damper Pulley 8 8A528 Water Pump Pulley
s1w~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: The drive belt tensioner has no provision for adjustment and will be damaged if forced to travel beyond its operating range. Automatic tensioners are calibrated at the factory to provide the correct amount of tension to the belt. There is no need to check tensioners for proper tension.
NOTE: Drive belts (8620) with automatic drive belt tensioner (6B209) do not require adjustment.
NOTE: When a drive belt is installed new or reinstalled after a service procedure, the drive belt does not fully seat into pulley grooves until engine has run for several minutes.
  • automatic drive belt tensioners.
Drive belt chirp is a regularly occurring chirping noise that occurs due to:
  • pulley misalignment.
  • excessive pulley runout.
It can be a result of a damaged pulley or an incorrectly replaced pulley that was not correctly aligned.
To correct drive belt chirp:
  • determine the area where the noise comes from.
  • check each of the pulleys in that area with a straightedge to the crankshaft pulley (6312) for front accessory drive and the water pump drive pulley to the water pump.
  • look for the accessory pulley to be out of position in the fore/aft direction or at an angle to the straightedge.
Drive belt squeal is an intermittent noise that occurs when the drive belt slips on a pulley during certain conditions such as:
  • engine start-up.
  • rapid engine acceleration.
  • A/C clutch engagement.
Drive belt squeal can occur under the following conditions:
  • The A/C discharge pressure goes above specifications:
    • The A/C system is overcharged.
    • The A/C condenser airflow is blocked.
Feb 27, 2010 | 2001 Ford Windstar
Belt diagram
2 valve
Item Part Number Description 1 8679 Belt idler pulley 2 10344 Generator pulley 3 8620 Drive belt 4 3A733 Power steering pump pulley 5 6312 Crankshaft pulley 6 8509 Water pump pulley 7 2E884 A/C clutch pulley 8 6B209 Drive belt tensioner pulley
4 valve
Item Part Number Description 1 19A216 Belt idler pulley 2 10300 Generator clutch pulley 3 8620 Drive belt 4 3A733 Power steering pump pulley 5 6316 Crankshaft pulley 6 8A528 Water pump pulley 7 19D692 A/C clutch pulley 8 6B209 Drive belt tensioner pulley 9 19A216 Belt idler pulley
Oct 26, 2009 | 2003 Mercury Grand Marquis
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
187 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
