Question about Sylvania SMPK4066 MP3 Player
My computer won't recognize my Sylvania, model num. SMPK4083. Can you help??
My computer does not recognize my sylvania smpk4230
Posted on Jan 02, 2011
WHAT TYPE OF SONGS CAN BE DOWNLOADED TO MY SMPK4083?
Hi Avis Edwards...
Your MP3 player requires the following:
Music requires.....MP3 (8kbps ~ 320kbps), or
.WMA (5kbps ~ 384kbps)
for music at Constant Bit Rate
Video requires:
.AMV files
For a user manual for your Mp3 player and a FREE video/music converter download it at the following link..(The converter is inside of the download)
Please take time to rate me
Bud
http://data.manualslib.com/pdf/17/1675/167423-sylvania/smpk4083.pdf?554517b4114fb4184bbf967aef135711
Oct 17, 2012 | Curtis Sylvania Smpk4083 4 Gb Video Mp3...
I bought a sylvania mp3 smpk4083 mp3 player and it orgianlly worked with my computer, but now when I connect it to my computer it turns on my player, but won't be regonized by my computer? How do
Same thing happened to me with an IPOD. When I plugged it in to one of my USB ports, it ******** up all the USB ports. I suggest reinstalling the drivers for your USB Ports. Then install the software that came with your MP3 Player before replugging it in. Good luck :)
Apr 01, 2012 | Sylvania SMPK4083 Digital Media Player
When i installed the media player into my computer. i get a little screen saying usb device not recognized. one of usb devices attachedto this computer has malfunction,and windows does not recognize it....
Hi, smpk4083 mp3 player not recognized by the computer
Why is my smpk4083 mp3 player not being detected by my computer when I connect it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see smpk4083 mp3 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the smpk4083 mp3 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: smpk4083 mp3 Players can connect to your computer in MSC or MTP mode. Exceptions are smpk4083 mp3 player Connect and smpk4083 mp3 Express which only use MTP mode. MTP mode is the recommended and default method for smpk4083 mp3 Players when used with Windows OS.
The smpk4083 mp3 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Hope it helped.
Have a nice day,.
Feb 22, 2011 | Sylvania Audio Players & Recorders
I need to download sylvania smpk4083 software
Driver for Sylvnia SMPK4083 utilities is available under next link:
http://www.curtisint.com/html/CustService/Manuals/SYL_SMPK4083_DRIVER.ZIP
Unzip the zip file.
Open the folder End User Tools_4_25 and run (double click) the Setup.exe file, to install the mp3 player utilities.
SMPK4083 manual:
http://www.curtisint.com/html/CustService/Manuals/SYL_SMPK4083_EN.PDF
( pdf file, readable with Adobe Reader )
Aug 13, 2010 | Audio Players & Recorders
I have a Sylvania SMPK4083. Its not very easy to use but priced right. I have figured out most of it but cannot figure out how to use random, which I assume is the same as shuffle. If you can help it will...
I also have the sylvania smpk4083 player. My problem it has great sound, but my problem is that every song only plays a few seconds then it goes to the next song. I can't figure out how to set it for normal play.
Can you please advise so I can enjoy it before I return it to the store.
Thanks,
Jun 21, 2010 | Audio Players & Recorders
I have the Sylvania SMPK4083 and want to use my imac to load music. I have osx 10.4
Looking at the manual it looks it will only sync with Windows 98-Vista. It's a piece of **** anyway, just get a cheap shuffle, you'll like it better.
May 17, 2010 | Audio Players & Recorders
How can I ''shuffle''my songs on sylvania's smpk4083 model?
The SMPK4083 can shuflle songs, selecting Random:
Follow next procedure:
In PLAYING mode, press M while playing music to enter
the selection menu screen.
Choose Repeat and press M to enter the Repeat menu screen.
Next go to Random using |<< / >>| buttons, while selected Random, press M to choose for random play.
Jan 23, 2010 | Sylvania Audio Players & Recorders
Sylvania SMPK4066  MP3 Player Logo
1,387 people viewed this question
Top Sylvania Audio Players & Recorders Experts
Ravi
ahmad
ahmad
Are you a Sylvania Audio Player and Recorder Expert? Answer questions, earn points and help others
