Question about Whirlpool Dishwashers
I can't get the whirlpool w10073650 dishwasher to start! How do I turn it on?
  • J Harry Oct 25, 2012
    I'm having exact;u the same problem - the latch would not work and I found some debris so I cleaned it out and checked everything I could think of, but it will not start up - seems like some sort of micro switch, perhaps?
    New Friend:
My whirlpool dishwasher not starting need help to start on..
Posted on Jan 14, 2016
Turned on the 1 hr button and it did start but after a few minutes it stopped. None of the controls are lit and the water is just standing in the bottom. What do I do to get it started again?
If it fills with cold water, it will pause and try to heat the water... if there is no heater function, it will never achieve wash temperature.
To invoke the Diagnostics Cycle, perform the following while in standby:
? Press any 3 keys in the sequence 1-2-3-1-2-3-1-2-3 with no more than 1 second between key presses.
? The Service Diagnostics Cycle will start when the door is closed Whirlpool Dishwasher High Limit Thermostat WP661566 , Whirlpool Dishwasher Heating Element W10518394 , Whirlpool Dishwasher Control Board W10751502
Jul 12, 2016 | Whirlpool Dishwashers
Dishwasher WHIRLPOOL DU930PWPQ2 stays locked and doesn't start. Even when i push on "heated dry" during 5 seconds. What can i do ? Some one gets an answer ? Thank you
washer Will Not Turn On - How To Fix ...
removeandreplace.com/2014/.../dishwasher-will-not-turn-on-how-to-fix/
Oct 6, 2014 - If your dishwasher won't turn on or start, here are a few things to check yourself ... Frigidaire, Kenmore, Whirlpool, and Bosch) work the same way. ... This door switch is also sometimes called a door lock or door interlock switch. ... All the lights light up on my dishwasher but the thing doesn't turn on at all.
Troubleshooting Why the Dishwasher Won't Start ... - YouTube
? 3:58
https://www.youtube.com/watch?v=8ZrtcdtmyEk
Jun 20, 2012 - Uploaded by PartSelect
In this video you'll learn what happens when the dishwasher won'tstart. ... Here are a few things you should check if yourdishwasher won't start: ... Replacing the Thermal Fuse & Harness (Whirlpool #675813) - Duration: 6:01.
Whirlpool Dishwasher DU930PWPQ2 Troubleshooting ...
Jan 14, 2016 | Whirlpool Dishwashers
My Whirlpool W10073650, starts up, runs through a wash cycle, but does not drain. I have cleaned the filters. The air gap is clear. We have a disposal. I think the main panel needs to be reset or cleared?...
to reset the pcb you will have to determine the circuit breaker it is connected to and cycle the power there. leave it off for at least 60 seconds. generally if there is a short in the pcb it will be a reoccuring problem not solveable with a power cycle. the cost of replacement of the pcb is comparable to replacement of the entire unit in the majority of cases
Sep 26, 2013 | Whirlpool Dishwashers
We have the Whirlpool dishwasher ,Model: ADG6 955. used it smoothly last night but this afternoon, it just will not start up. The green 'START" button keeps flashing and the dishwasher just does not...
Try turning off power to the dishwasher completely by either unplugging it or turning off the circuit breaker for a few minutes, then power it back up. Sometimes this will reset it.
Oct 11, 2017 | Whirlpool Dishwashers
It wont switch on when i press button to start
I have the Whirlpool Dishwasher DU915PWP50, Series: FR4412916. I cannot get my dishwasher to start. It seems to be on lock, but I have done what it says to so on the side of the door to take it off lock. I still can't get it to turn on.
Denise Kusturin
Apr 05, 2010 | Whirlpool 24 in. DU915PWP Built-in...
Whirlpool dishwasher model DU920PFGB4 will not start.
my dishwasher is only 2years old and will not start. the lights on the panel come on but wont start.
Sep 26, 2009 | Dishwashers
Whirlpool dishwasher ADG 957. The manual says " Open the door and turn on the water tap". Where is the water tap and what does it look like?
They mean to turn on your water faucet at the kitchen sink and let the water get hot before starting the dishwasher cycle this insures you start the wash with hot water.
Aug 22, 2009 | Whirlpool Dishwashers
My whirlpool gold dishwasher GU180 wont start
I had the same problem with the exact same model - put your washer on the lowest wash setting - press and hold the start button for about 3 seconds. THe washer will run for about 5 seconds and then turn off (do not have the heated dry setting on when you do this).
Turn it off (turn the dial), and then try to re-wash.
Dec 25, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Flashing light
I had this problem at home too, it turned out to be a kink in the water outlet pipe. I straightened out the kink in the pipe, put duct tale around it to strenghten it and the dishwasher has been working perfectly since.
Aug 08, 2008 | Whirlpool 24 in. ADP5962 Free-standing...
Whirlpool Dishwasher Fills and then Stops
  Check your connection where you connected dishwasher to power cord.
Oct 25, 2007 | Whirlpool 24 in. GU2500 XTP Built-in...
Dishwashers Logo
863 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
