My laptop keeps shutting down on me. - Computers & Internet
  • 64 Answers
1. Try this
Press F8 when you start your pc.
A screen will appear.
Select Safe Mode. Let the pc load until you see your desktop.
Then click My Computer, select C:
In C: , select Windows folder
In Windows folder, open system32 folder
Now, double click rstrui to do System Restore to the time before your PC was ok
After system restore, you pc will restart and your files will be restored. Your PC will be ok again.
2. Check for viruses or trojans as well Scan your PC in Safe Mode. Trojans are known to cause PC to shut down as well.
Hope your PC will become well again!
Posted on Nov 11, 2010
Toshiba laptop satellite L645D-4040 keeps shutting down
does it shut down and then just start right back up? If it does then press and hold the power button and make sure it shuts down all the way. Then take the battery out and press and hold the power button after the battery is out for about 5 seconds. Then let it sit like 10 - 15 seconds. After that put your battery back in and turn it back on and see if this solved your problem. I think its in a loop to make it keep restarting. Let me know if this helped. Thanks, Herb Stacey
Oct 04, 2013 | Computers & Internet
My acer 5750 i7 keeps shutting down
The infected laptops encounter random shutdown problem until some maintenance activity is being performed on the system.
Two important things that you should do to fix a laptop which keeps shutting down are:
1- Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes.
For an instant fix use system utility tool Reginout.
WebRepOverall ratingThis site has no rating(not enough votes)
Dec 12, 2012 | Acer Computers & Internet
Asus k52f keeps shutting down randomly
I have seen the odd case where the power supply cannot keep up with the demands when the laptop is running causing it to shut down, but first! remove the main battery to see if that helps, no change! I recommend replacing the power supply adapter in hopes it will correct the problem. Go to www.ebay.com Type make and model of laptop, refine search to power supply and go through the list of prices.
Jul 20, 2012 | ASUS K52F-BBR9 Notebook
Toshiba Laptop L650-12Q will not shut down
Windows needs to be shut down properly to keep it stable, if hibernate mode is being used it eventually corrupt windows causing all kinds of symptoms, I recommend you make a backup recovery disc, and disable the hibernate feature to prevent complete window failure.
May 07, 2012 | Toshiba Computers & Internet
Laptop just keeps shutting down and won't turn on
it may be one of the causes, but the main reason for it is the power supply keeps on fluctuating. You may call Acer for a possible replacement for it..
Jun 19, 2011 | Acer Aspire 5315 15.4-inch Notebook PC
I have a toshiba satellite a215 s7422 and it keeps shutting down on me so i disassembled it and cleaned out the fan but it still keeps shutting down...i recently had the bios reset, i don't know if that...
You should look for the following answers.
(1) Are you operating your laptop in a in a hot and dusty environment (If yes you should know that computers do not like hot and dusty environments and they shut down to avoid a complete burn out of the machine more over the dust particles also can destroy the hardware and block internal fan ventilation ducts in between the CPU and the fan).
(2) When the your laptop PC shuts down place your hand underneath the laptop and try to feel hot spots. If you find areas unusually heated then this is the main cause of the shut down.
(3) If just after the shut down and a good usage the Laptop is cool then underneath than overheating shut down might not be the case.
If you determined that heating is the cause and you cannot change your environment than you should look for other heavy duty laptops that are robustly designed for hot environments.
I do not think that resting the BIOS can cause this.
Oct 06, 2010 | Toshiba Satellite A215-S7422 Notebook
My gateway laptop keeps shutting down. it is brand new
How long have you had it on. If you are not venting the heat out away from the processor, it will shut down to protect it. I suggest either take a small fan and blowing towards the computer. Or they make a chill pads for laptops about thrity dollars.
Oct 12, 2009 | Gateway (MS-6946) Modem
My laptop monitor keep shutting down....
Check the display power settings in Control Panel.
Oct 04, 2009 | HP Pavilion dv4000 Notebook
Toshiba Satellite A105 laptop keeps shutting off for no reason.
I think your fan might be broken....if the fan doesn't cool the pc,the processor or the chipset will automatically shut down the pc to prevent burning hardware.Or your hard drive might keep crashing.Oh yeah and abstract from this i don't recommend ever using mcaffe
Oct 25, 2008 | Toshiba Satellite A215-S7422 Notebook
Computers & Internet Logo
51 people viewed this question
Alun Cox
k24674
