Recently bought samsung multi split 3 rm air conditioner. 2 of the room air con working fine but the 3rd room fan coil seems to be blowing only cool air not like the other 'aircon' feel coolness. Got the technician to top up gas but same problem persist. Help!
  • 81 Answers
Doesnt sound like a gas problem. theres a vavle they opens and closes inside the unit that might be playing up either the vavle or the indoor pc board. did it ever cool ? might also be the vavle on the outside unit were not open with the alan keys so theres no gas going to them .
Posted on Nov 11, 2010
  • azmanbmn Nov 15, 2010
    thanks for the post, redstorm. I called the tech guy to look into the problem. After checking, they said my room too big and needed bigger fan coil to cook the entire room. Also, I got them to relocate my fan coil for better aircon circulation in my room today. Shall try it again tonight. Hopes it resolve part of my problem! ?
3 split units run from one compressor one is not cooling
If there is 3 indoor units from one condensing unit
(6 pipes at outdoor unit) this is classed as a multi unit
All units will run correctly as long as they all require same mode, cooling or heating, if one unit decides to heat it will shut down until master unit decides to heat then it will start, for each unit to individually heat and cool there would have to be 3 pipes to each indoor,
Dec 19, 2015 | Fujitsu 9RLS 9000 BTU Split System Air...
Why is my portable air conditioner blowing out room temperature air?
Make sure the filter(s) have been cleaned (Washed) and that the thermostat is set to the correct temperature. If the room temp is the same as the setting on the air con, it wont cool or heat. Just the fan will be operating.
Sep 10, 2014 | Heating & Cooling
Haier air conditioner won't cool the room anymore
i bought the air conditionor new and it will not cool what can i do
Jul 05, 2012 | Haier ESA406K 6,000 btu ECO-Friendly...
Our split system is not blowing cool air all the time? Can you tell me what the problem might be. Thanks
To get proper cool, keep cool mode. Temp setting minimum 3 degree less than room temp.Check indoor coil,air filter and blower wheel are cleaned.
Check gas pressure is good by keeping your hand on suction pipe (bigger size) which gives chillness.
Hope, helpful.
Jan 28, 2011 | Samsung Heating & Cooling
Air con is working, but not cooling the air
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 05, 2011 | Samsung AS18A6RB Air Conditioner
LG neo plasma air conditioner does not blow cold air
Thanks. Helpful?
Jan 04, 2011 | LG LS-J0910HL Heat & Cool Mini Split Air...
Conia 3 HP, 5 yr old air con/ condensation from wall unit
NOW, THE EVAPORATOR COILS NEEDS CLEANNING OR THE DRAIN LINE PLUGGED,OR JUST CLEAN THE FILTER.
Nov 30, 2009 | Heating & Cooling
Fan Coil Unit is Cycling on and off. But the room is still hot.
Check electrical connection at the T'stat and the indoor blower . Sounds like a loose connection.
Sep 11, 2009 | Cfm Daikin R410a Split System Air...
Fan coil unit won't cool or heat in room1 while room2 runs well
could be undercharged, or overcharged, or wires weren't put back on valves in unit.
Feb 16, 2009 | Cfm Daikin R410a Split System Air...
Soleus KFGHP-09-ID Mini Split
This is normal operation for these styles of minisplits. The thermostat is not in the remote but is located on the return air of the indoor coil, so the air needs to be flowing in order for the thermostat to measure the rooms temperature. Set your fan speed to auto and the fan will slow down when setpoint tempurature is met.
Phil Hodges,
Tech support Soleusair
May 18, 2008 | Soleus KFS18GW 18,000 BTU Heat & Cool 230V...
Heating & Cooling Logo
117 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
