Question about Dell Latitude D600 Notebook
Blue screen on start up tech information stop:0x000000024
  • 15 Answers
Try safe mode, if you can get into safe mode try sys restore if still same hold the Fn key down while sys is off and then press the power button like turning the computer on to run diagnostics - if sys fails with an error code like 0142, 0143 or 0146 its hard drive failure. you have to replace the drive but if it passes the test you have to reinstall windows.
Posted on Nov 11, 2010
I keep getting this stop error after Windows loads?!
Seriously, contact Toshiba Tech Support. Give them the information you put up here. If you need to you can use a PC in the local library, or a friend's PC, to contact them. Or, just call them on the phone.
Have you tried going into Safe Mode?
-a.
Jun 23, 2012 | Toshiba Computers & Internet
When turning on it will only go to a blue screen says go to safe mode or get tech support but even in safe mode it will only go back to blue screen. Can't download anything or do anything. At the...
Try uninstalling a few unnecessary programs
Just run fewer programs or buy additional RAM click start right click on my computer select properties you will see all imformation about your computer including installed ram
or processor upgrades. Your computer is running past its specified limits. But remember that in this case the blue screen of death should happen extremely infrequently. If you see the physical memory dump blue screen much more often then the issue is clearly
click start right click on my computer,properties advanced scroll down to system and recovery open settings write and debugging information the drop down button select none
ideally, it should already be the default debugger for your system.
The Dr. Watson debugger program logs all information related to failed processes to the Drwtsn32.log file. In addition to this, the debugger program can be configured to create memory dump files related to the failed processes. You can refer these dump files to analyze the reason behind a process failure.
Perform the following steps to configure Dr. Watson as the default debugger program to record user-mode program errors:
  1. Open Start menu, select Run, type Drwtsn32.exe -I and then press Enter. This command sets Dr. Watson as the default debugger.
  2. Next, run the Drwtsn32.exe command.
  3. In the Dr. Watson for Windows dialog box, select the following check boxes:
    • Append to Existing Log File
    • Visual Notification
    • Create Crash Dump File
  4. Now, when your computer restarts after the STOP 0xC000021A error is generated, run the Dr. Watson command.
  5. Here, view the paths to the Dr. Watson and User.dmp logs.
  6. Open Windows Explorer, navigate to the log files and then open them.
  7. Here, check the cause behind the STOP 0xC000021A error.
also you might download and use this registry cleaner it is 100%totally free to use
http://download.cnet.com/ccleaner/
hope this helps you
Jul 24, 2011 | Computers & Internet
Blue screen appears at start up boot screen and restarts again
press "F8" while statrting , and then select "safe mode"
Feb 01, 2011 | Computers & Internet
I have a compaq c700 that contually crashes with a blue screen showing a data dump - it restarts ok but can crash again without notice. Dennis
I think you will need to do a long process to make your sys. work again.To start look here , but read below --> (HP Support & Drivers )
If you still get the BS (Blue Screen), then you have two choices. One is to reinstall the entire OS, Second is to take your machine in to have the hardware tested. If you reinstall the OS you'll lose all the information on there, such as pictures, programs, videos, etc... And if you still have the blue screen, then you know beyond a doubt that the problem is hardware related. If you reinstall the OS and it works then great! You've fixed your machine! If you choose the second option first and have it tested at a shop, or a personal PC Tech, and he finds nothing wrong, you'll have to reinstall the OS to correct the issue losing all of your information. If you choose to have a tech look at your machine and he repairs the hardware problem, then you haven't lost any information, and only an hour of two of your time, but your computer is working again. The decision is up to you.
Remember to make a checklist to start with if you have this problem. Follow the one below for starters.
  1. Check cpu for dust
  2. Run virus scan
  3. Check power supply
  4. Check other hardware such as memory
Oct 20, 2010 | HP Presario C700T Notebook
I TURN MY KIDS PC ON AND IT STARTS UP BUT THEN IT GETS TO WINDOWS AND IT LOOKS LIKE IT IS ABOUT TO COME COME UP BUT GOS TO THE BLUE SCREEN FOR 1 SECOUND AND STARTS BACK UP AGAIN OVER AND OVER.
A blue screen or Blue Screen Of Death, BSOD, is generally caused by a corrupt driver or a bad software installation.
First, you need to determine the STOP code that is on that screen.
  • Start in safe mode, press F8 repeatably as the computer starts up,
  • check Disable automatic restart on system failure (This prevents Windows from automatically restarting if an error causes Windows to fail.)
OK, now the BSOD will stay there so you can determine what caused your problem. Report back the stop code and any information about a driver that caused the problem so we can be of further help.
Sep 14, 2010 | Computers & Internet
0x000000024 blue screen
Corrupt windows files. Use the install disc to repair the installation then run checkdisk
Feb 09, 2010 | Microsoft Windows XP Home Edition
I am getting a blue screen with error message: stop: 0x000000024 (0x00190203, 0x8A7DC5B8, 0xC0000102, 0x00000000) message I have run many diagnostic tests and all come back normal. it will not start in...
You cannot see HD because there are no apropriate SATA drivers included in windows XP CD. So you need to create custom windows XP installation CD
To install windows XP in that laptop u will need to create custom windows XP CD, how will you do that:
  1. Download nlite from http://www.nliteos.com/
  2. Download drivers for that laptop
  3. Download service pack 3 for windows XP
  4. Install nlite for windows XP and run
  5. Follow instructions and include SP3 for XP, all the drivers for laptop and create ISO Image
  6. Burn ISO Image
  7. Install Windows XP
  8. Good Luck
Nov 25, 2009 | HP Pavilion dv5-1140us Notebook PC
Uploading windows vista upgrades command was to restart system for changes to take effect. On restart screen went blue and showed Tech info *** STOP: 0x0000C1F5 (0x00000000, 0x00000000, 0x000000000,...
Press F8 continuously while starting the computer. When black screen appears eventually (right before Windows loads), choose Last Known Good Configuration.
Aug 06, 2009 | HP Computers & Internet
Blue screen of death
post_old.gif The error is a software error in the NT File System which is the format that you have installed on your computer. The repair is to boot to the CD installation disc or a copy of the boot discd (K)s and open the repair console to repair the file system....since you are unable to boot to the repair console then your only option is to reformat and reinstall....I hope that you have your system backed up!
Jan 11, 2009 | Dell Inspiron 4100 Notebook
Dell Latitude D600 Notebook Logo
130 people viewed this question
Clive
Clive
Alun Cox
