Question about Magic Chef Microwave Ovens
Microwave acts like there is no power. Is there a fuse ?
  • 5,911 Answers
There is usually a 125V, 20 AMP line fuse inside the microwave, mounted at the point where the power cord enters the back of the unit. It will either be in line with the power cord, or on a small circuit card called a line filter. Unfortunately, you will need to uninstall the oven (if this is an over the range model), UNPLUG it and remove the exterior case to access. The case comes off in various ways depending on manufacturer and model. Parts are available at any of the following websites: searspartsdirect.com pcappliancerepair.com appliancepartspros.com repairclinic.com The first three sites include illustrated parts listings that can help you locate and properly identify any parts you may need. The microwave oven may also equipped with various thermostats that (if blown) can cause similar symptoms to that of a blown line fuse. So, if the line fuse is NOT blown, you may want to check all the thermostats to see if they are still good. You will need to remove each one and measure across the terminals with a multimeter. A good reading is 0 ohms. NOTE: The thermostats typically will trip if the oven cavity has been overheated. Cooking items that are high heat producers such as popcorn or baked potatoes in rapid succession can often cause this problem. Allowing the oven cavity to cool a few minutes with the door open between cooking can prevent this from occurring.
If the line fuse is blown, you can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Ceramic Slow Blow fuses are recommended.
If you have any questions, or need additional assistance troubleshooting, please post back with your MODEL NUMBER and let me know. I hope you find this information helpful.
NOTE: Make sure you take any resistance readings with the microwave UNPLUGGED and the component under test isolated (removed) from the circuit. These ovens can blow a fuse by simply sitting idle. This can occur from any power fluctuations, brown outs, voltage spikes, etc. Or, it could be the symptom of a component that may have failed. If you find the internal fuse blown and replace it, only to have it blow again, you have a more significant problem than a simple blown fuse.
Posted on Nov 11, 2010
Interior light bulb burned out previously; now no power at all.
I have had to change the fuse in a handful of my microwaves,usually when they get to be about 10 years old.If you take the housing off,you should find an inline fuse holder on the power cord just as it enters the housing.Read the info on the fuse,and replace it with the same size/type(the ones I've seen are ceramic fast acting fuses)I also like to take another spare and tape it inside the housing near the fuse holder so I don't lose the spare.
Jan 01, 2012 | Magic Chef Jade Microwave Ovens
Has power but not working.
Many newer microwaves will have power to the control panel but have the magnetron
fused. The fuse is an automotive type fuse (old style). It has a ceramic center instead of
clear. It is a slow acting fuse. Make sure unit is unplugged before servicing and
be mindful of the capacitors (metal or plastic cylinders with two connections on them)
They can hold quite a charge. The fuse will be in a holder and the voltage and amperage
are stamped on the metal ends. About 2 dollars at the appliance parts store. You may
need a security driver to remove the cover screws.
Hope this helps.
Mar 27, 2011 | Microwave Ovens
Is there a reset button on frigidaire microwaves. have already checked the circuit breakers but still not working
nope sure isnt, if it doesnt turn on you may have just blown either the load in fuse or the high voltage fuse down the bottom, remove the cover should be a couple screws round the outside and check fuses if you know how (MAKE SURE ITS UNPLUGGED FROM THE POWER FIRST) (NEVER START THE MICROWAVE WITHOUT THE METAL COVER ON AS THIS ACTS AS A RADIATION SHIELD)
Mar 26, 2011 | Frigidaire FGMV185K Microwave Oven
My Advantium suddenly stopped working while using it. Acts as if it is unplugged. I checked the electric circuit and surgeprotector they are okay. It acts as if it blew a fuse, but I don.t know where...
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Mar 02, 2011 | GE Advantium 120 Convection/Microwave Oven
665.68601890 Acts as though it is not receiving power but breaker is not thrown. Is there an internal reset. Nothing responds - no lights, fan or microwave. Panel is black and non responsive
ther is on most microwaves a fuse inside usually located behind display panel located in a fuse block or will be on the control board itself.. normally a 20 amp fuse...try that first if not then make sure you have power to control and if so and no display most likely the display control board...
may luck out and be just the fuse though....good luck
Jan 08, 2011 | Kenmore Microwave Ovens
Acts as if there is no power but power at the outlet. Neither micro nor vent fan nor light work. Please advise.
Their is a fuse insite the body behind the control panel. You need to replace the fuse.
Sep 29, 2010 | Sanyo EM-S8000 Microwave Oven
GE Microwave stops running
Mostly with GE I find this to be bad connections at the fuse holder or a bad fuse due to a bad fuse holder. It will break connection and reset the unit when the connection gets hot and expands and then opens and stops power from getting to the unit.
Aug 14, 2017 | GE Microwave Ovens
Blowing Fuses
never put higher fuse then what is already there can cause a fire microwave are being made more disposable now either use warranty or buy a new one i am lucky if i get one to last a year before it starts acting up cheaper to buy new one then to have it repaired
Dec 03, 2008 | Microwave Ovens
Microwave Ovens Logo
146 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
charles
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
