Heatilator model GCDC60 will not ignite burner/logs when wall switch is turned on. Pilot light is on and visible. Last season experienced a delay of a fewseconds after flipping on the wall switch before ignition. Also, last season we would fan air directed at lower part of unit before the logs would ignite. Any ideas?
  • Jeff T Oct 25, 2011
    Has anyone solved this problem yet?
SOURCE: Pilot Light
i had this trouble with a different fryer. We had lpg instead of natural gas. check youre using the correct gas.
Posted on Oct 20, 2008
jeffk14
  • 16 Answers
SOURCE: I have a Dayton gas heater Model 3E225
Does the main blower fan kick on? Also, if the heater is vented outside via a flue pipe, there may be a small (about 3 or 4 inches in diameter) vent fan that kicks on to ensure the exhaust fumes are evacuated through the flue pipe. If there's a problem with that fan, the burner won't light either.
Posted on Nov 20, 2008
  • 69 Answers
SOURCE: wall heater burners wont ignite
you may have a bad gas valve
Posted on Dec 19, 2008
picatudo
  • 239 Answers
SOURCE: pilot light won't ignite, gas company came out, got gas
the glow plug or thermocopler is bad
Posted on Jan 03, 2009
  • 2558 Answers
SOURCE: main burner will not ignite Tempstar(NTC5075BFD1)
try cleaning the pilot oriffice it sounds like the flame is weak
Posted on Jan 17, 2009
Napoleon Fireplace propane Pilot won't light main burner even though gas flows in?
  • I'm going to assume your fireplace has a pilot light.
  • Follow the little holes in the burner that lead to the pilot light.
  • Make sure the pilot flame is pointing directly at the closest burner hole. (adjust if necessary).
  • Often, you will need to sprinkle a layer of "glowing embers" in this area. The embers will help the gas travel to the pilot light and ignite.
  • Always start your propane appliance on "High" never "Low". Cold propane likes to drop to the bottom of the firebox and accumulate until it reaches the pilot (this is called delayed ignition). Keeping it on "high" will help the fuel travel over to the pilot without buildup.
Jan 21, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
I have a Model CGN250TE.The pilot light stays lit but when you turn control valve on it stays lit for 5 seconds and then shuts right down,even the pilot light goes out.I have tried venting the room and...
I would first check the gas pressure to your furnace. Then make sure that burners are clean and watch flames when burner first ignites. I have seen burners that were dirty cause delayed ignition that would create a suction when they came on and extingush pilot and burners.
The next thing I would do is change gas valve. Thank you
Dec 19, 2010 | Williams 2509612 Ceramic Mid-Size Heater
I have a heatilator gas fireplace model gcdc60 and the flame is not high anymore. This fireplace has two settings low and high. The high setting is like having low on and the low setting is almost not...
Take a thin stiff wire and run it thru each flame port of the burner a few times each then if you can take a vacuum after setting it right on the ports-tap on the burner with a object while vacuuming it-if that does not work -is there a place that looks like a nut over each flame port? if so spray with a lubricant like WD40 to loose the nut and remove and clean flame ports that way and vacuum it then same way then
Sep 30, 2017 | Home
How do I turn on my superior ventless fireplace
I'm not sure about that brand, but I finally figured out how to turn the one in the house I just moved into. The only visible control if you have not accessed the fireplace controls before is the switch on the wall. The wall switch is strictly an on off switch, but it only works if the pilot light is already lit, and the pilot light will not go out by turning off the wall switch. To access the controls, first pull out the vent covers, they are simply held in place with pressure buttons on each end. Behind the lower vent are the controls for the pilot light and fire intensity, mine also contained a metal plate with the instructions printed on it. Open the glass door by opening the four latches, two on top and two on bottom, and then swinging it out on its hinge. You will find the gas spout for the pilot light hidden between the logs. Turn on the main gas line by turning the straight edge of the red handle parallel with the gas line. Turn the gas control to pilot, by pushing in and turning, and then push in all the way to start gas flowing. I like to have a match already lit next to the valve when I start the gas. After the pilot light has been on for about 60 seconds let go of the button and it will return to its normal position. Then turn the control to on and turn on the wall switch, the main burners should start lighting. Close the glass and put the vent covers back in place and your ready to enjoy the fireplace :)
Nov 27, 2010 | Heating & Cooling
My Majestic DVR36RN gas-log fireplace insert will not start. No ignition when striker is depressed, no flame lit at all. Gas inlet line open, pilot switch to "pilot" as directed. Maybe...
Majestic DVR36RN: Here's what you need to do: Verify gas line is open. (You said you already have done that). Next turn the switch to pilot (you said you did that too). Make sure wall switch is on also. Now press and hold the pilot switch and hit the ignitor. Once it lights you need to continue to hold the pilot switch for roughly 1 minute. Release the knob and the flame should stay lighted. Now, turn the knob to on. You should be all set now.
Nov 09, 2010 | Heating & Cooling
Used since 9/23/05 and was fine. Now I can light the pilot and it stays on fine. Turn on logs and NOTHING! I have a remote and it has new batteries and turns the switch and you can hear the poomp when the...
Hi, when you say that when you turn on the switch to the on position to fire the logs, is this poomp you hear a short burst of gas igniting? If it is and it doesn't stay on, this is a sign of your manifold pressure being to high, or also the burners are plugged as we call this poomp, pre- ignition, or delayed. We know that the thermocouple is good as the pilot is staying light and you have a good strong pilot flame, so if the main gas valve is trying to lite by this poof you are hearing, the problem would more then likely be dirty or plugged burners/burner and that's where I would be looking to clean out. Now, if you hit the switch and you hear a noise but no gas starts to flow, the problem would be in the main gas valve coil opening for a split second or just clicking and not opening. In this case, your gas valve has failed you. It would be a standard valve that you could pick up at any appliance parts house, millivolt that you could replace your self. In any case, it just sounds as though you need to get to the burner or burners and check to see if the have built up soot over the last 5 years. I don't believe it is anything serious that you can't repair. A little TLC should take care of your problem. Please don't forget to rate me, and please leave a comment for me under my user name below. I would really like to know what you find and I will be hear if this doesn't solve your problem, but I am confident it will if you do the things I have asked.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Oct 08, 2010 | Heating & Cooling
Intalled an overhead 130K BTU Mr. Heater last
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Dec 01, 2009 | Mr. Heater Heating & Cooling
Delay in oven burner to light after pilot is lit.
Usually delayed lighting on a standing pilot system is caused by a gas pathway that is dirty from spilled food or grease. If you can remove the burner assembly and clean it that will correct the problem. If there is a removable plate above it then you can remove that and get access instead of removing it. Pilot ignitions work by creating a column of gas between the pilot and the burner that is established when the burner is turned on kind of like a fuse. A small tube my be used to establish the column of gas between burner and pilot and it may get blocked with food that overflows. Sometimes the pilot is just located right next to the burner and may get partially blocked or the orifice in the burner next to the pilot may be blocked. Cleaning all this helps. Be very careful with gas. Work in a well ventilated area. Turn on gas very briefly to run an ignition test. Turn off the gas and vent it off if it fails to light in about 5 seconds. Unburned propane drops to the floor and collects. Natural gas rises. Be aware of this when you ventilate.
Dec 23, 2008 | Magic Chef Ovens
Heating & Cooling Logo
895 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
