Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire Front Load Tumble Action Washer Model #LTF2140ES3 Won't spin water out of clothes this washer is 4 years old anyone know want the problem could be. Thanks Lisa
SOURCE: Frigidaire LTF2140ES3 washes, tumbles but won't spin out at higher speed
http://www.fixya.com/support/t1551051-will_not_spin_water_will
Posted on Jan 31, 2009
buffalonyman
  • 1865 Answers
SOURCE: front load washer
Possibly the door switch...check for adjustment or replacement
Posted on Apr 18, 2009
SOURCE: Frigidaire Tumble Action washer won't complete the
Had the same problem and fixed with ease. The problem is with the door lock. There is a secondary locking mechanism that kicks in for the final spin due to the high speed. When the secondary lock goes bad the washer will not do the final spin. The replacement part is under $40 @ AppliancePartsPros.com .
Posted on Feb 02, 2010
kel1guy2002
  • 3740 Answers
SOURCE: frigidaire tumble action washer will not agitate
Yes there are several balance switches in the unit and if the shock is broken at least one switch has been activated. If you were to some how bypass the switch the unit would be very dangerous to even be near during the spin cycle as it would try to walk, tumble or jump across the room! The switch is a safety feature for all concerned.
Please get your machine repaired.
Thanks for using FixYa!
Kelly
Posted on Mar 10, 2010
Jahn27
  • 1554 Answers
SOURCE: frigidaire frontend washer LTF2140ES3 will drain not spin
There is an auxiliary switch in the door lock and switch assembly that is activated at the end of the wash cycle to advance to the spin cycle. When the machine works except advancing to the spin cycle, it signifies that this auxiliary switch cannot be activated and the door lock and switch assembly is faulty. Replaced the door lock and switch assembly (part #131763202) to fix the washer.
Disconnect power to the machine. Open the washer door then look for the retaining hoop securing the door seal around the lip of the door opening. Stretch the retainer spring of the door seal retaining hoop then remove it.
Carefully peel off part of the door seal from the lip of the door opening near the door lock and switch assembly. Remove enough of the door seal to gain access to the door lock and switch assembly.
Remove the screws securing the door lock and switch assembly to the front panel. Once the screws are removed, lift the door lock and switch assembly then pull it away from the front panel.
Take the door lock and switch assembly out of the machine. Disconnect the wires from its terminals then connect it to the new door lock and switch assembly.
Put the new door lock and switch assembly back into position in the front panel and secure it with the securing screws.
Properly put the eased part of the door seal back over the lip of the door opening then secure it with the retaining hoop.
I have a front loading clothes washer model ltf2140es3 it use to work great, we moved and now it does not spin , whats up ? it was born in 2006
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | Frigidaire 24 in. FDB510LC Free-standing...
I have a 7 year old Frigidaire washer (Model #GLWS1349AS1) and the water drains really slow and the spin starts before all the water is drained and then the washer leaks as water is still in it during spin...
you have a restriction in the drain somewhere or there is something inside the pump housing,chk every line from the tub to pump to drain pipe and hoses for blocks or kinks
Apr 09, 2010 | Frigidaire FTF2140ES King Size Front-Load...
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Kenmore Front Load "tumble action washer"
Our Sears repair guy says the tub bearing needs to be replaced. Get a new washer? Don't buy another Frigidaire...
Jun 20, 2008 | Kenmore 43142 Front Load Washer
Front Load not spinning
The back of washer has a access panel with screws that you can remove,once removed you can check if tghe belt broke or not.
May 23, 2008 | Frigidaire ATF6000ES Front Load Washer
Load noise in final spin cycle
turn the tub on the inside if it feels ruff as it turns and makes a noise then most likely you have a bad rear bearing, if it is smooth in turning and no noise then turn to drain or spin possibly something stuck in drain pump. the drain pump will start up first if you hear the noise then the drain pump is accessed from the front lower cover, if its the rear bearing probably not worth fixing about 400.00 in parts and alot of work.
Feb 14, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Frigidaire Front Load Washer Shrinking clothes
check to make sure you water line arnt hooked up backwards. if hot is to cold and cold to hot your washing in hot water when your trying to use cold
Nov 20, 2007 | Frigidaire 14 Cycle Tumble Action Washer
Frigidaire ATF6000ES Front Load Washer Logo
77 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
