Question about Jandy Stealth 2 HP UR Pool Pump SHPM2.0 SHPM20
Pump not taking prime. I have a lot of pine leaves or nettles some of which may have got past the strainer. after it took prime it did not seem to have good flow,.
  • 310 Answers
This is indictive of a clogged impeller or blown shaft seal or possibly both.
To clean out the impeller, simply removing the 8 securing bolt that hold the wet end against the seal plate and motor housing. Then remove the diffuser assembley. You should now have access to the impeller. Remove any debris from inside the impeller and impeller cage.
Reassemble , fill with water, and try to reprime.
If prime still fails, take apart again and remove impeller to replace the shaft seal.
Note:
1. Make sure the filter connected to this pump is clean and not causing the problem before following these instructions.
2. Here is the link to the exploded parts diagram for easy reference to part names. It is also good to look at previous to dissassembley so that you have a good understanding of what is where.
Posted on Nov 11, 2010
Not pumping strong. Filter pressure gauge is going low.
Could be air entering the pump on the suction side - dead giveaway is a stream of bubbles entering the pool, possible causes are damage/faulty pipe joint, leak at strainer basket - is the o-ring clean and in place, is the lid craked? Other possibility is leaves etc caught in the impeller caused by damaged or missing strainer basket.
Jan 23, 2011 | Pentair 011515 WhisperFlo FullRated Energy...
I have intelliflo VS+SVRS pool pump, after stopping for 4 days i want to start again & after start it goes to priming & then alarm & it says clear the drain & restart
There is either something blocking the suction side of this pump (blocked valve, strainer, strainer basket, leaves on main drain.) or the pump is not getting primed in the aloted amount of time. You can increase the priming time on the pump, or manually prime it, or just turn off the svrs feature temporarily until you get a good prime again. If you need the manual to figure out how to do these things, here is the link.
http://www.pentairpool.com/pdfs/IntelliProVS+SVRSOM.pdf
Jan 19, 2011 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Losing pressure after about 15 mins pool pump stars really well but then seems to lose pressureleaf catcher before pemp seems to get air in it is this pump or pipes
If the inlet strainer gets air in it, the pump will lose prime. Fill the inlet strainer basket with water, make sure the cover is on air tight. Start the pump and watch the inlet strainer, the amount of air trapped should not increase, if it does, you have a leak somewhere on the piping between the pool and the pump.
Nov 19, 2010 | Plumbing
I have a brand new hayward e series and it will not hold prime
When you say it won't hold prime I assume you mean when you turn it off either manually or on a time clock? If this is the case you must have an air leak somewhere in your piping system or in your pump. Could the pump seal be leaking. Gasket on pump strainer ("O" ring) Is the strainer basked crecked. I've found several pump strainer assemblies with small cracks that won't even prime at all if there is much lift. Check for cracks on all threaded fittings, IF the fittings were overtightned then it can crack the fitting, like in pump inlet and outlet. Listen for a hissing, sucking sound when you turn the pump off.
Jul 14, 2010 | Hayward SAND FILTER, PRO SERIES
Help low pressure in pool pump and filter
I can relate so well to your problem. My pool is surrounded by pines and deodora trees... all the needles seem to find their way through the baskets, strainers and into the inlet of the pump. It became a daily routine of having to reach into the inlet and clean the debris if I wanted a filtered pool.
Here' s a solution that will work!
Purchase an extra debris scoop ...the kind you put on the pole and scoop debris from the bottom of the pool.
Cut the net out of the frame and wrap the netting around the skimmer's debris basket and secure it with an oversized rubber band or zip ties, then replace the basket back in the skimmer.
Your skimmer will keep the debris out of the pump!
This will make a world of difference in your pump's pressure!
Give it a try and see if you're not working better!
Jun 03, 2010 | Sta Rite STA-RITE IMPELLER 2HP FULLRATE &...
Pool Pump does not Prime.
CRAIG .. IF ITS A STA RITE PUMP DURA GLASS YA GET IT FIXED ! SHOULD COST ABOUT 75.00 SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP REPAIR GUY . ASK IF HE DOES FREE MOTOR TESTING
May 20, 2010 | A.O. Smith SQ1102 Pool Pump Motor
Internal fuel pump strainer has fallen off
the first question is--is the pump good= is it working properly if it isnt than replace the pump and fuel filter
Apr 26, 2010 | 1987 Volkswagen Cabriolet
1999 merc e300 turbodiesel splutters when starting from cold and misfires for about a minute. car is worse to start when hot and often fails to start heater plugs are ok no air in the fuel all seals and...
It sounds like the fuel strainer is clogged or one of the filters is clogged. start by taking the fuel primer pump and attempt to prime system if the pump handle sucks back down when you attempt to pump there is a clog in the system. There is a lot of water in diesel fuel and they build up algea over a number of years and generally the fuel strainer(part at fuel tank that the feed line attatches too) clog up. you can remove them and clean them. Good luck
Aug 30, 2009 | 1999 Mercedes-Benz E-Class
Removing a staRite pump
a picture on how 2 remove sta rite , remember to prime the pump after any repair !.. the shaft seal used on this pump is a 100 or a 200 . i use pac seal mechanical shaft seals cost about 10$.. go kits are not required on 90 % of repairs $$
Apr 13, 2009 | Sta Rite GO-KIT-6 Sta-Rite P2RA DuraGlas /...
Jandy Stealth 2 HP UR Pool Pump SHPM2.0 SHPM20 Logo
337 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
