How would i access the registry? - Computers & Internet
    Guru:
  • 610 Answers
Start >>> Run >>> type regedit then click on Ok. That should open up the registry editor.
Posted on Nov 11, 2010
Speed up PC.-no virus/spyware,disk,
If you are determined to risk registry cleaning, you might try Wise Registry Cleaner, Glary's registry cleaner, or the registry cleaner in CCleaner or the commercial Advanced System Mechanic. You may use Revo Uninstaller to completely remove the programs you installed immediately before trouble emerged or resort to accessing the registry backup you created before cleaning. Many of the cleaners allow creation of such backups from within the software..
Sooner or later, registry cleaning seems to result in a "gotcha." You will be glad you had system restore points when that day happens. I try to leave registry junk alone, use portable apps to avoid installs affecting the registry, and make a restore point prior to every software installation.
How do you determine what is safe to clean? Well, Wise Registry Cleaner rather gives you a screen which suggests what is purportedly completely safe to remove by the screen colors indicating safe ones. If you have any doubts, don't remove the registry entry.
Not that the advice will keep you completely safe! Backup your critical data files to an external hard drive before engaging in too much registry tampering. As you chase performance, cleaning suites sound like a good option, right up to the point you crash, then you are chasing recovery options.
Use of Sandboxes and Virtual Drives avoid some garbage collection but that far more than you have requested to know about.
Adding ram sped up XP machines more than registry tweaks ever did.
Feb 13, 2015 | HP Desktop Computers - Hewlett-Packard...
How to enable registry-editor in windows 8
Go to Search, and type in gpedit.msc, and press enter.
In Group Policy Editor, select User Configuration. Then select Administrative Templates, then select System. Then double click on "Prevent access to registry editing tools". A pop-up window will come up with two tabs, select "Settings" tab. Click on the radio button that says "Disable" and click on OK button. It sounds stupid, but you will be "disabling the prevention of access to the registry editor." If Registry Editor is not immediately available, you may have to restart to computer. Good luck!
Aug 26, 2013 | Computers & Internet
Device media is write protected
To disable writing access to USB drives and make all USB drives has only read-only access, follow these steps:
  1. Run Registry Editor (regedit).
  2. Navigate to the following registry key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
  3. Create a New Key named as StorageDevicePolicies.
  4. Highlight StorageDevicePolicies, and then create a New DWORD (32-bit) Value named as WriteProtect.
  5. Double click on WriteProtect, and set its value data to 1. write-protect-usb.jpg
Once set, all users on the computer is now blocked and prevented from copying, transferring or writing any files, documents and data to the USB disk drives, without the need to restart or reboot computer. Any attempt to download or copy files to USB drive will return the following error message:
The disk is write protected.
The media is write-protected.
Remove the write protection or use another disk.
usb-removable-disk-write-protected.jpg To revert and remove the blocked write access to USB drivers, just delete the StorageDevicePolicies registry key, or delete the WriteProtect registry entry, or change the value data for WriteProtect to 0.
For user who doesn't want to manually editing the registry, simply download the following registry registration files to enable or disable the write protection (block writing attempt) to USB removable drive. Double click the .reg file unpacked from the .zip archive to merge the registry key entries.
Download DisableWriteToUSB.reg
Download EnableWriteToUSB.reg
The trick works in Windows XP SP2 and SP3, Windows Vista, Windows Server 2003 and 2008.
Feb 27, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How to enable and disable registry access using MS Visual Basic?
you'll get some disagreement on this I suppose but I've read numerous articles on leaving the registry alone as all the registry is is a record of what has happened on your machine. Changing the registry can really do damage to your operating system.
Feb 07, 2010 | Microsoft Windows XP Professional SP2
I have Dvd drive problem
Manually delete the registry entriesNote Before you use this method, uninstall all CD or DVD writing or recording programs. Deleting the corrupted registry entries might cause problems with any other CD or DVD writing or recording programs that are installed on your computer. Uninstalling these programs before you start will help you avoid any problems that removing the registry entries might cause. You can reinstall these programs after the problem is resolved.
This method provides step-by-step instructions for how to use Registry Editor to delete the following corrupted Registry entries:
  • UpperFilters
  • LowerFilters
Step 1: Start Registry Editor loadTOCNode(3, 'whattotry'); click on Start menu : Run : type regedit : press enter
Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'whattotry');
  1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE.
  2. Expand SYSTEM, and then expand CurrentControlSet.
  3. Expand Control, and then expand Class.
  4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
  5. In the details pane of Registry Editor, on the right side, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only.
    • If you see the UpperFilters registry entry in the details pane of Registry Editor, go to step 6.
    • If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to "Step 3: Delete the LowerFilters registry entry."
  6. On the Edit menu, click Delete.
  7. Click Yes when you receive the following message: Are you sure you want to delete this value?
The UpperFilters registry entry is removed. Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'whattotry');
  1. In the details pane of Registry Editor, on the right side, click LowerFilters.
    Note You might see a LowerFilters.bak registry entry. You do not have to remove that entry. Click LowerFilters only.
    If you do not see the LowerFilters registry entry, unfortunately this content is unable to help you any more. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  2. On the Edit menu, click Delete.
  3. Click Yes when you receive the following message: Are you sure you want to delete this value?The LowerFilters registry entry is removed.
  4. Exit Registry Editor.
Step 4: Restart your computer loadTOCNode(3, 'whattotry'); Restart your computer. After you have done this, try to access the CD or DVD drive. If you can access the CD or DVD drive, and if you do not receive an error message, the problem is resolved. You can reinstall your CD or DVD writing or recording software.
If you cannot access the CD or DVD drive, or if you receive an error message, unfortunately this content is unable to help you any more. Go to the "Next Steps" section for information about how you can find more solutions to the problem.
Regards
Chittaranjan
Jan 05, 2009 | Lenovo (40Y8623) DVD±RW Dual Layer Burner
Lg dvd-rom play cd not play dvd
Step 1: Start Registry Editor loadTOCNode(3, 'whattotry'); Start Registry Editor.
Click on Start button than click on run and type in regedit and click on OK.Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'whattotry');
Dec 28, 2008 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
My laptop dvd/cd-re combo does not work it says it a code erre
Click on Start button than click on run and type in regedit and click on OK. Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'whattotry');
Dec 22, 2008 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
Error accessing the registry
Access registry:
goto google and search for "unhookexec.inf", u will get the download from symantec website. download it on your desktop, right click on the unhook icon and click 'install'.
now goto run and type regedit, u should be able to access registry.
Jul 23, 2008 | Microsoft Windows XP Home Edition
Trouble installing HP officejet 5610 all-in-one
slbcsp.dll - this registry does not exist
sccbase.dll - this registry does not exist
gpkcsp.dll - this registry does not exist
Enum - installer can not access
Oct 22, 2007 | HP Officejet 5610 All-In-One InkJet...
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
